path: root/include/fsl-mc/fsl_mc_private.h
2019-12-26drivers/fsl-mc: Support DPSPARSER object and apply spb commandFlorinel Iordache
Add support for DPSPARSER object (create/destroy, open/close, apply spb) which is required to configure Soft Parser by using MC. Also add uboot command to apply Soft Parser Blob with command: fsl_mc apply spb <spb_load_addr> Signed-off-by: Florinel Iordache <florinel.iordache@nxp.com> Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com>
2018-05-09driver: net: fsl-mc: updated copyright infoYogesh Gaur
Updated copyright info for the issues reported after running check-legal test. Signed-off-by: Yogesh Gaur <yogeshnarayan.gaur@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-12-06driver: net: fsl-mc: flib changes for MC 10.3.0Yogesh Gaur
Existing MC driver framework is based on MC-9.x.x flib. This patch migrates MC obj (DPBP, DPNI, DPRC, DPMAC etc) to use latest MC flib which is MC-10.3.0. Changes introduced due to migration: 1. To get OBJ token, pair of create and open API replaces create APIs 2. Pair of close and destroy APIs replaces destroy APIs 3. For version read, get_version APIs replaces get_attributes APIs 4. dpni_get/reset_statistics APIs replaces dpni_get/set_counter APIs 5. Simplifies struct dpni_cfg and removes dpni_extended_cfg struct 6. Single API dpni_get_buffer_layout/set_buffer_layout replaces dpni_get_rx/set_rx, tx related, tx_conf_buffer_layout related APIs. New API takes a queue type as an argument. 7. Similarly dpni_get_queue/set_queue replaces dpni_get_rx_flow/set_rx_flow , tx_flow related, tx_conf related APIs Signed-off-by: Yogesh Gaur <yogeshnarayan.gaur@nxp.com> Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2015-11-30driver: net: ldpaa: Use DPMAC as net devicePrabhakar Kushwaha
As per current implementation of DPAA2 ethernet driver DPNI is used as net device. DPNI is tangible objects can be multiple connected to same physical lane. Use DPMAC as net device where it represents physical lane. Below modification done in driver - Use global DPNI object - Connect DPMAC to DPNI - Create and destroy DPMAC Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-11-30driver: net: fsl-mc: Create DPAA2 object at run-timePrabhakar Kushwaha
Freescale's DPAA2 ethernet driver depends upon the static DPL for the DPRC, DPNI, DPBP, DPIO objects. Instead of static objects, Create DPNI, DPBP, DPIO objects at run-time. Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-11-30driver: net: fsl-mc: Add DPAA2 commands to manage MCPrabhakar Kushwaha
Management complex Firmware, DPL and DPC are depolyed during u-boot boot sequence. Add new DPAA2 commands to manage Management Complex (MC) i.e. start mc, aiop and apply DPL from u-boot command prompt. Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-04-23driver/ldpaa_eth: Add LDPAA Ethernet driverPrabhakar Kushwaha
LDPAA Ethernet driver is a freescale's new ethernet driver based on Layerscape architecture. Every ethernet driver controls on DPNI object. Where all DPNIs share one common DPBP and DPIO object to support Rx and Tx flows. Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> CC: Cristian Sovaiala <cristian.sovaiala@freescale.com> CC: Bogdan Hamciuc <bogdan.hamciuc@freescale.com> CC: J. German Rivera <German.Rivera@freescale.com> [York Sun: s/NetReceive/net_process_received_packet] Reviewed-by: York Sun <yorksun@freescale.com>
2015-04-21driver/fsl-mc: Add support of MC FlibsPrabhakar Kushwaha
Freescale's Layerscape Management Complex (MC) provide support various objects like DPRC, DPNI, DPBP and DPIO. Where: DPRC: Place holdes for other MC objectes like DPNI, DPBP, DPIO DPBP: Management of buffer pool DPIO: Used for used to QBMan portal DPNI: Represents standard network interface These objects are used for DPAA ethernet drivers. Signed-off-by: J. German Rivera <German.Rivera@freescale.com> Signed-off-by: Lijun Pan <Lijun.Pan@freescale.com> Signed-off-by: Stuart Yoder <stuart.yoder@freescale.com> Signed-off-by: Geoff Thorpe <Geoff.Thorpe@freescale.com> Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com> Signed-off-by: Cristian Sovaiala <cristian.sovaiala@freescale.com> Signed-off-by: pankaj chauhan <pankaj.chauhan@freescale.com> Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
