path: root/include/fsl-mc/fsl_dpmng.h
2015-08-03drivers/fsl-mc: flib changes for mc 8.0.0Prabhakar Kushwaha
MC firware version 8.0.0 contains new command flags. This patch contains modifications in FLIB files to support the new command flags. Signed-off-by: Itai Katz <itai.katz@freescale.com> Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-07-20drivers: fsl-mc: Update flibs to mc-0.6.0.1Prabhakar Kushwaha
Update flibs changes to mc-0.6.0.1 for dpmang, dprc, dpni and dpio objects Also rename qbman_portal_ce/ci_paddr to qbman_portal_ce/ci_offset in dpio_attr. These are now offsets from the SoC QBMan portals base. Signed-off-by: J. German Rivera <German.Rivera@freescale.com> Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-04-21driver/fsl-mc: Add support of MC FlibsPrabhakar Kushwaha
Freescale's Layerscape Management Complex (MC) provide support various objects like DPRC, DPNI, DPBP and DPIO. Where: DPRC: Place holdes for other MC objectes like DPNI, DPBP, DPIO DPBP: Management of buffer pool DPIO: Used for used to QBMan portal DPNI: Represents standard network interface These objects are used for DPAA ethernet drivers. Signed-off-by: J. German Rivera <German.Rivera@freescale.com> Signed-off-by: Lijun Pan <Lijun.Pan@freescale.com> Signed-off-by: Stuart Yoder <stuart.yoder@freescale.com> Signed-off-by: Geoff Thorpe <Geoff.Thorpe@freescale.com> Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com> Signed-off-by: Cristian Sovaiala <cristian.sovaiala@freescale.com> Signed-off-by: pankaj chauhan <pankaj.chauhan@freescale.com> Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-02-24drivers/mc: Migrated MC Flibs to 0.5.2J. German Rivera
Upgrade Manage Complex (MC) flib API to 0.5.2. Rename directory fsl_mc to fsl-mc. Change the fsl-mc node in Linux device tree from "fsl,dprcr" to "fsl-mc". Print MC version info when appropriate. Signed-off-by: J. German Rivera <German.Rivera@freescale.com> Signed-off-by: Lijun Pan <Lijun.Pan@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
