path: root/include/fsl-mc/fsl_dpmac.h
2017-12-06driver: net: fsl-mc: flib changes for MC 10.3.0Yogesh Gaur
Existing MC driver framework is based on MC-9.x.x flib. This patch migrates MC obj (DPBP, DPNI, DPRC, DPMAC etc) to use latest MC flib which is MC-10.3.0. Changes introduced due to migration: 1. To get OBJ token, pair of create and open API replaces create APIs 2. Pair of close and destroy APIs replaces destroy APIs 3. For version read, get_version APIs replaces get_attributes APIs 4. dpni_get/reset_statistics APIs replaces dpni_get/set_counter APIs 5. Simplifies struct dpni_cfg and removes dpni_extended_cfg struct 6. Single API dpni_get_buffer_layout/set_buffer_layout replaces dpni_get_rx/set_rx, tx related, tx_conf_buffer_layout related APIs. New API takes a queue type as an argument. 7. Similarly dpni_get_queue/set_queue replaces dpni_get_rx_flow/set_rx_flow , tx_flow related, tx_conf related APIs Signed-off-by: Yogesh Gaur <yogeshnarayan.gaur@nxp.com> Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-01-27driver: net: fsl-mc: flib changes for MC FW 9.0.0Prabhakar Kushwaha
MC firmware version 9.0.0 contains - Support of new APIs - Update in existing APIs - Change in Major and minor version of DPAA2 objects This patch contains modifications in FLIB files to support new MC firmware version. Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Reviewed-by: York Sun <york.sun@nxp.com>
2015-11-30driver: net: fsl-mc: Add APIs for DPMAC objects in FLIBPrabhakar Kushwaha
DPMAC object of Management complex controls Physical MAC and MDIO controller. It provides APIs for MDIO and link state updates. It also provides APIs for PHY/link configuration. Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
