path: root/include/fpga.h
2019-04-16fpga: Replace char * with const char * for filenameTien Fong Chee
Ensure the string for filename is always constant, otherwise it can be corrupted by the writing. Signed-off-by: Tien Fong Chee <tien.fong.chee@intel.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-06-01cmd: fpga: Add support to load secure bitstreamsSiva Durga Prasad Paladugu
This patch adds support to load secure bitstreams(authenticated or encrypted or both). As of now, this feature is added and tested only for xilinx bitstreams and the secure bitstream was generated using xilinx bootgen tool, but the command is defined in more generic way. Command example to load authenticated and device key encrypted bitstream is as follows "fpga loads 0 100000 2000000 0 1" Signed-off-by: Siva Durga Prasad Paladugu <siva.durga.paladugu@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2017-12-14fpga: allow programming fpga from FIT image for all FPGA driversGoldschmidt Simon
This drops the limit that fpga is only loaded from FIT images for Xilinx. This is done by moving the 'partial' check from 'common/image.c' to 'drivers/fpga/xilinx.c' (the only driver supporting partial images yet) and supplies a weak default implementation in 'drivers/fpga/fpga.c'. Signed-off-by: Simon Goldschmidt <sgoldschmidt@de.pepperl-fuchs.com> Tested-by: Michal Simek <michal.simek@xilinx.com> (On zcu102) Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-01-27fpga: Add bitstream type BIT_NONESiva Durga Prasad Paladugu
Add bitstream type BIT_NONE to the bitstream type enum. This might be useful while loading bitstreams in respective drivers. Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2015-01-21fpga: Export fpga_get_desc for SPLMichal Simek
SPL needs to detect FPGA device which will be used for loading bitstream. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2015-01-21fpga: Remove extern prototypes from .hMichal Simek
This problem is reported by checkpatch.pl Warnings: CHECK: extern prototypes should be avoided in .h files Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2014-05-20fpga: Added support to load bit stream from SD/MMCSiva Durga Prasad Paladugu
Added support to load a bitstream image in chunks by reading it in chunks from SD/MMC. Command format: loadfs [dev] [address] [image size] [blocksize] <interface> [<dev[:part]>] <filename> Example: fpga loadfs 0 1000000 3dbafc 4000 mmc 0 fpga.bin Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2014-05-20fpga: Add support to load partial bitstreamsMichal Simek
Added support to load partial bitstreams. The partial bitstreams can be loaded using the below commands Commands: fpga loadp <dev> <addr> <size> fpga loadbp <dev> <addr> <size> The full bit streams can be loaded using the old commands(fpga load and fpga loadb). Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2014-05-20fpga: Define bitstream type based on command selectionMichal Simek
Clean up partial, full and compressed bitstream handling. U-Boot supports full bitstream loading and partial based on detection which is not 100% correct. Extending fpga_load/fpga_loadbitstream() with one more argument which stores bitstream type. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2013-05-06fpga: Remove all CONFIG_SYS_* fpga related optionsMichal Simek
All these macros are completely unused by any code. CONFIG_FPGA is not a bitfield anymore. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Tom Rini <trini@ti.com>
2013-05-06fpga: Check device name against bitstream nameMichal Simek
Ensure that wrong bitstream won't be loaded to current device. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Tom Rini <trini@ti.com>
2013-05-06fpga: Change the first parameter in fpga_loadbitstreamMichal Simek
All fpga functions use devnum as int. Only fpga_loadbitstream is using it as unsinged long dev. This patch synchronize it. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Tom Rini <trini@ti.com>
2013-05-06cmd: fpga: Move fpga_loadbitstream to fpga.cMichal Simek
In bitstream decoding you can directly check device which you want to load and in fpga.c are fpga_validate and fpga_dev_info functions which should be used for it. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Tom Rini <trini@ti.com>
2013-04-01Consolidate bool typeYork Sun
'bool' is defined in random places. This patch consolidates them into a single header file include/linux/types.h, using stdbool.h introduced in C99. All other #define, typedef and enum are removed. They are all consistent with true = 1, false = 0. Replace FALSE, False with false. Replace TRUE, True with true. Skip *.py, *.php, lib/* files. Signed-off-by: York Sun <yorksun@freescale.com>
2011-08-01fpga: constify to fix build warningWolfgang Denk
Fix compiler warning: cmd_fpga.c:318: warning: passing argument 3 of 'fit_image_get_data' from incompatible pointer type Adding the needed 'const' here entails a whole bunch of additonal changes all over the FPGA code. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Andre Schwarz <andre.schwarz@matrix-vision.de> Cc: Murray Jensen <Murray.Jensen@csiro.au> Acked-by: Andre Schwarz<andre.schwarz@matrix-vision.de>
2010-10-13FPGA: add support for downloading Lattice bitstreamStefano Babic
The patch adds support to load a Lattice's bitstream image (called VME file) into a Lattice FPGA. The code containing the state machine delivered as part of Lattice's ispVMtools is integrated. The FPGA is programmed using the JTAG interface. The board maintainer must provide accessors to drive the JTAG signals TCK, TMS, TDI and to get the value of the input signal TDO. Signed-off-by: Stefano Babic <sbabic@denx.de>
2009-10-03fpga: Remove relocation fixupsPeter Tyser
PPC boards are the only users of the current FPGA code which is littered with manual relocation fixups. Now that proper relocation is supported for PPC boards, remove FPGA manual relocation. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2002-08-21Initial revisionwdenk
