path: root/include/fm_eth.h
2013-10-24net/fman: add a fm_enable_port functionValentin Longchamp
This can be useful if one wants to disable an interface in u-boot because u-boot should not manage it but then later reenable it for FDT fixing or if the kernel uses this interface. Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> [York Sun: fix conflict in fm_eth.h] Acked-by: York Sun <yorksun@freescale.com>
2013-10-16SGMII:fix PHY addresses for QSGMII Riser Card working in SGMII modeZhao Qiang
Fix PHY addresses for QSGMII Riser Card working in SGMII mode on board P3041/P5020/P4080/P5040/B4860. QSGMII Riser Card can work in SGMII mode, but having the different PHY addresses. So the following steps should be done: 1. Confirm whether QSGMII Riser Card is used. 2. If yes, set the proper PHY address. Generally, the function is_qsgmii_riser_card() is for step 1, and set_sgmii_phy() for step 2. However, there are still some special situations, take P5040 and B4860 as examples, the PHY addresses need to be changed when serdes protocol is changed, so it is necessary to confirm the protocol before setting PHY addresses. Signed-off-by: Zhao Qiang <B45475@freescale.com>
2013-05-14Fman/t4240: some fix for 10G XAUIShaohui Xie
1. fix 10G mac offset by plus 8; 2. add second 10G port info for FM1 & FM2 when init ethernet info; 3. fix 10G lanes name to match lane protocol table; Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com> Signed-off-by: Roy Zang <tie-fei.zang@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2012-10-22fm/mEMAC: add mEMAC frame workRoy Zang
The multirate ethernet media access controller (mEMAC) interfaces to 10Gbps and below Ethernet/IEEE 802.3 networks via either RGMII/RMII interfaces or XAUI/XFI/SGMII/QSGMII using the high-speed SerDes interface. Signed-off-by: Sandeep Singh <Sandeep@freescale.com> Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com> Signed-off-by: Roy Zang <tie-fei.zang@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2012-10-22powerpc/mpc85xx: Add T4240 SoCYork Sun
Add support for Freescale T4240 SoC. Feature of T4240 are (incomplete list): 12 dual-threaded e6500 cores built on Power Architecture® technology Arranged as clusters of four cores sharing a 2 MB L2 cache. Up to 1.8 GHz at 1.0 V with 64-bit ISA support (Power Architecture v2.06-compliant) Three levels of instruction: user, supervisor, and hypervisor 1.5 MB CoreNet Platform Cache (CPC) Hierarchical interconnect fabric CoreNet fabric supporting coherent and non-coherent transactions with prioritization and bandwidth allocation amongst CoreNet end-points 1.6 Tbps coherent read bandwidth Queue Manager (QMan) fabric supporting packet-level queue management and quality of service scheduling Three 64-bit DDR3/3L SDRAM memory controllers with ECC and interleaving support Memory prefetch engine (PMan) Data Path Acceleration Architecture (DPAA) incorporating acceleration for the following functions: Packet parsing, classification, and distribution (Frame Manager 1.1) Queue management for scheduling, packet sequencing, and congestion management (Queue Manager 1.1) Hardware buffer management for buffer allocation and de-allocation (BMan 1.1) Cryptography acceleration (SEC 5.0) at up to 40 Gbps RegEx Pattern Matching Acceleration (PME 2.1) at up to 10 Gbps Decompression/Compression Acceleration (DCE 1.0) at up to 20 Gbps DPAA chip-to-chip interconnect via RapidIO Message Manager (RMAN 1.0) 32 SerDes lanes at up to 10.3125 GHz Ethernet interfaces Up to four 10 Gbps Ethernet MACs Up to sixteen 1 Gbps Ethernet MACs Maximum configuration of 4 x 10 GE + 8 x 1 GE High-speed peripheral interfaces Four PCI Express 2.0/3.0 controllers Two Serial RapidIO 2.0 controllers/ports running at up to 5 GHz with Type 11 messaging and Type 9 data streaming support Interlaken look-aside interface for serial TCAM connection Additional peripheral interfaces Two serial ATA (SATA 2.0) controllers Two high-speed USB 2.0 controllers with integrated PHY Enhanced secure digital host controller (SD/MMC/eMMC) Enhanced serial peripheral interface (eSPI) Four I2C controllers Four 2-pin or two 4-pin UARTs Integrated Flash controller supporting NAND and NOR flash Two eight-channel DMA engines Support for hardware virtualization and partitioning enforcement QorIQ Platform's Trust Architecture 1.1 Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Andy Fleming <afleming@freescale.com> Signed-off-by: Roy Zang <tie-fei.zang@freescale.com> Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2012-08-23fm-eth: add function fm_info_get_phy_address()Timur Tabi
Function fm_info_get_phy_address() returns the PHY address for a given Fman port. This is handy when the MDIO code needs to fixup the Ethernet nodes in the device tree to point to PHY nodes for a specific PHY address. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2012-08-23powerpc/85xx: add support for FM2 DTSEC5Timur Tabi
Unlike previous SOCs, the Freescale P5040 has a fifth DTSEC on the second Fman, so add the Fman and SerDes macros for that DTSEC. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2011-10-03fm-eth: Add ability for board code to disable a portKumar Gala
The SoC configuration may have more ports enabled than a given board actually can utilize. Add a routinue that allows the board code to disable a port that it knows isn't being used. fm_disable_port() needs to be called before cpu_eth_init(). Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-09-29powerpc/85xx: Add support for FMan ethernet in Independent modeKumar Gala
The Frame Manager (FMan) on QorIQ SoCs with DPAA (datapath acceleration architecture) is the ethernet contoller block. Normally it is utilized via Queue Manager (Qman) and Buffer Manager (Bman). However for boot usage the FMan supports a mode similar to QE or CPM ethernet collers called Independent mode. Additionally the FMan block supports multiple 1g and 10g interfaces as a single entity in the system rather than each controller being managed uniquely. This means we have to initialize all of Fman regardless of the number of interfaces we utilize. Different SoCs support different combinations of the number of FMan as well as the number of 1g & 10g interfaces support per Fman. We add support for the following SoCs: * P1023 - 1 Fman, 2x1g * P4080 - 2 Fman, each Fman has 4x1g and 1x10g * P204x/P3041/P5020 - 1 Fman, 5x1g, 1x10g Signed-off-by: Dave Liu <daveliu@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com> Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Roy Zang <tie-fei.zang@freescale.com> Signed-off-by: Dai Haruki <dai.haruki@freescale.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Signed-off-by: Ioana Radulescu <ruxandra.radulescu@freescale.com> Signed-off-by: Lei Xu <B33228@freescale.com> Signed-off-by: Mingkai Hu <Mingkai.hu@freescale.com> Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Shaohui Xie <b21989@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
