Fixes non-working CFI Flash on the Inka4x0 board.
Signed-off-by: Bartlomiej Sieka <tur@semihalf.com>
The following patch adds support for non-CFI flash ROMS, by hooking into the
CFI flash code and using most of its code, as recently discussed here in the
thread "Mixing CFI and non-CFI flashs".
Signed-off-by: Michael Schwingen <michael@schwingen.org>
Merge to two at45.c files into a common file, split to at45.c and spi.c
Fix spelling error in DM9161 PHY Support.
Initialize at91rm9200 board (and set LED).
Add PIO control for at91rm9200dk LEDs and Mux.
Change dataflash partition boundaries to be compatible with Linux 2.6.
Signed-off-by: Peter Pearse <peter.pearse@arm.com>
Signed-off-by: Ulf Samuelsson <ulf@atmel.com>
offset to go into CFI mode)
* Adds support for AMD command set Top Boot flash geometry reversal
* Adds support for reading JEDEC Manufacturer ID and Device ID
* Adds support for displaying command set, manufacturer id and
device ids (flinfo)
* Makes flinfo output to be consistent when CFG_FLASH_EMPTY_INFO defined
* Removes outdated change history (refer to git log instead)
Signed-off-by: Tolunay Orkun <listmember@orkun.us>
- Map in a additional chip selects CS4 and CS5.
- Modify the port configration, configure six UARTs and no PCI,
ATA and USB.
- Add custom flash driver to handle specific byte swapping
- Add IXP4xx NPE ethernet MAC support
- Add support for Intel IXDPG425 board
- Add support for Prodrive PDNB3 board
- Add IRQ support
Patch by Stefan Roese, 23 May 2006
[This patch does not include cpu/ixp/npe/IxNpeMicrocode.c which still
sufferes from licensing issues. Blame Intel.]
- Add Intel legacy lock/unlock support to common CFI driver
On some Intel flash's (e.g. Intel J3) legacy unlocking is
supported, meaning that unlocking of one sector will unlock
all sectors of this bank. Using this feature, unlocking
of all sectors upon startup (via env var "unlock=yes") will
get much faster.
- Fixed problem with multiple reads of envronment variable
"unlock" as pointed out by Reinhard Arlt & Anders Larsen.
- Removed unwanted linefeeds from "protect" command when
CFG_FLASH_PROTECTION is enabled.
- Changed p3p400 board to use CFG_FLASH_PROTECTION
Patch by Stefan Roese, 01 Apr 2006
* Changes/fixes for drivers/cfi_flash.c:
- Correctly handle the cases where CFG_HZ != 1000 (several
XScale-based boards)
- Fix the timeout calculation of buffered writes (off by a
factor of 1000)
Patch by Anders Larsen, 31 Mar 2006
- add support for Analog Devices Blackfin BF533 CPU
- add support for the ADI BF533 Stamp uClinux board
- add support for the ADI BF533 EZKit board
Patches by Richard Klingler, June 11th 2005:
Patch by Stefan Roese, 1 Mar 2006
* Add env-variable "unlock" to handle initial state of sectors
(locked/unlocked).
Only the U-Boot image and it's environment is protected,
all other sectors are unprotected (unlocked) if flash
hardware protection is used (CFG_FLASH_PROTECTION) and
the environment variable "unlock" is set to "yes".
Patch by Stefan Roese, 28 Feb 2006
* Update drivers/cfi_flash.c:
- find_sector() called in both versions of flash_write_cfiword()
Patch by Peter Pearse, 27th Feb 2006
* CFI support for a x8/x16 AMD/Spansion flash configured in x8 mode
Patch by Jose Maria Lopez, 16 Jan 2006
* Add support for AMD/Spansion Flashes in flash_write_cfibuffer
Patch by Alex Bastos and Thomas Schaefer, 2005-08-29
We *should* check if there are any error bits if the previous call
returned ERR_OK (Otherwise we will have output an error message in
flash_status_check() already.) The original code would only check for
error bits if flash_status_check() returns ERR_TIMEOUT.
Patch by Marcus Hall, 23 Aug 2005
- Add CFG_FLASH_PROTECT_CLEAR on drivers/cfi_flash.c
- Prohibit buffer write when buffer_size is 1 on drivers/cfi_flash.c
Patch by Sangmoon Kim, 19 Aug 2005
* Fixes for drivers/cfi_flash.c:
- Fix wrong timeout value usage in flash_status_check()
- Round write_tout up when converting to msec in flash_get_size()
- Remove clearing flash status at the end of flash_write_cfibuffer()
which sets Intel 28F640J3 flash back to command mode on CSB472
Patch by Tolunay Orkun, 02 July 2005
Patch by Kurt Stremerch, 18 Apr 2005
Patch by Marc Leeman, 04 Mar 2005
- Enable booting directly from flash
- fix CMC_PU2 flash driver
* Fix mkimage usage message
Add support for WindRiver's SBC8560 board
* Patch by Nicolas Lacressonniere, 24 Jun 2004
Small Bugs fixes for "at91rm9200dk" board:
- Timing modifications for SPI DataFlash access
- Fix NAND flash detection bug
* Patch by Nicolas Lacressonniere, 24 Jun 2004:
Add Support for Flash AT49BV6416 for AT91RM9200DK board
Add support for Intel K3 strata flash.
* Some cleanup
* Patch by Thomas Brand, 10 Jun 2004:
Fix "loads" command on DK1S10 board
Add support for Analogue&Micro Adder87x and the older AdderII board.
* Patch by Ming-Len Wu, 09 Jun 2004:
Add suppport for MC9328 (Dargonball) CPU and Motorola MX1ADS board
- flash.h: more flash types added
- immap_8260.h: some bits added (useful for RMII)
- cmd_coninfo.c: typo corrected, printf -> puts
- reduced size by replacing spaces with tab
Add support for TI OMAP5912 OSK Board
* Patch by Sam Song May, 07 May 2004:
Fix typo of UPM table for rmu board
attempting to switch on USB on SX1 board.
* Patch by Josef Wagner, 18 Mar 2004:
- Add support for MicroSys XM250 board (PXA255)
- Add support for MicroSys PM828 board (MPC8280)
- Add support for 32 MB Flash on PM825/826
- new SDRAM refresh rate for PM825/PM826
- added support for MicroSys PM520 (MPC5200)
- replaced Query by Identify command in CPU86/flash.c
to support 28F160F3B
* Fix wrap around problem with udelay() on ARM920T
* Add support for Macronix flash on TRAB board
Fix early board initialization for Cogent CSB272 board
* Patch by Ed Okerson, 3 Mar 2004:
fix CFI flash writes for little endian systems
* Patch by Reinhard Meyer, 01 Mar 2004:
generalize USB and IDE support for MPC5200 with according
changes to IceCube.h and TOP5200.h
add Am29LV256 256 MBit FLASH support for TOP5200 boards
add info about USB and IDE to README
* Patch by Josef Baumgartner, 10 Feb 2004:
Fixes for Coldfire port
* Patch by Brad Kemp, 11 Feb 2004:
Fix CFI flash driver problems
Allow bzip2 compression for small memory footprint boards
* Patch by Brad Kemp, 21 Jan 2004:
Add support for CFI flash driver for both the Intel and the AMD
command sets.
* Patch by Travis Sawyer, 20 Jan 2004:
Fix pci bridge auto enumeration of sibling p2p bridges.
* Patch by Tolunay Orkun, 12 Jan 2004:
Add some delays as needed for Intel LXT971A PHY support
* Patches by Stephan Linz, 09 Jan 2004:
- avoid warning: unused variable `piop' in board/altera/common/sevenseg.c
- make DK1C20 board configuration related to ASMI conform to
documentation
ARM memory layout fixes: the abort-stack is now set up in the
correct RAM area, and the BSS is zeroed out as it should be.
Furthermore, the magic variables 'armboot_end' and 'armboot_end_data'
of the linker scripts are replaced by '__bss_start' and '_end',
resp., which is a further step to eliminate unnecessary differences
between the implementation of the CPU architectures.
* Minor code cleanup (coding style)
* Patch by Reinhard Meyer, 30 Dec 2003:
- cpu/mpc5xxx/fec.c: added CONFIG_PHY_ADDR, added CONFIG_PHY_TYPE,
- added CONFIG_PHY_ADDR to include/configs/IceCube.h,
- turned debug print of PHY registers into a function (called in two places)
- added support for EMK MPC5200 based modules
* Fix MPC8xx PLPRCR_MFD_SHIFT typo
* Add support for TQM866M modules
* Fixes for TQM855M with 4 MB flash (Am29DL163 = _no_ mirror bit flash)
* Fix a few compiler warnings
add support for Coldfire CPU
add support for Motorola M5272C3 and M5282EVB boards
Add support for SNMC's QS850/QS823/QS860T boards
fix TI Innovator/OMAP1510 pin configs
* Patches by Kshitij, 18 Aug 2003
- add support for arm926ejs cpu core
- add support for TI OMAP 1610 Innovator Board
* Add support for TQM823M, TQM850M, TQM855M and TQM860M modules
* Add support for Am29LV160ML, Am29LV320ML, and Am29LV640ML
mirror bit flash on TQM8xxM modules
- Allow to call sysmon function interactively
- PIC on LWMON board needs delay after power-on
- Add missing RSR definitions for MPC8xx
- Improve log buffer handling: guarantee clean reset after power-on
- Add support for EXBITGEN board
- Add support for SL8245 board
- Hymod board database mods: add "who" field and new xilinx chip types
- provide new "init_cmd_timeout()" function so code external to
"common/main.c" can use the "reset_cmd_timeout()" function before
entering the main loop
- add DTT support for adm1021 (new file dtt/adm1021.c; config
slightly different. see include/configs/hymod.h for an example
(requires CONFIG_DTT_ADM1021, CONFIG_DTT_SENSORS, and
CFG_DTT_ADM1021 defined)
- add new "eeprom_probe()" function which has similar args and
behaves in a similar way to "eeprom_read()" etc.
- add 8260 FCC ethernet loopback code (new "eth_loopback_test()"
function which is enabled by defining CONFIG_ETHER_LOOPBACK_TEST)
- gdbtools copyright update
- ensure that set_msr() executes the "sync" and "isync" instructions
after the "mtmsr" instruction in cpu/mpc8260/interrupts.c
- 8260 I/O ports fix: Open Drain should be set last when configuring
- add SIU IRQ defines for 8260
- allow LDSCRIPT override and OBJCFLAGS initialization: change to
config.mk to allow board configurations to override the GNU
linker script, selected via the LDSCRIPT, make variable, and to
give an initial value to the OBJCFLAGS make variable
- 8260 i2c enhancement:
o correctly extends the timeout depending on the size of all
queued messages for both transmit and receive
o will not continue with receive if transmit times out
o ensures that the error callback is done for all queued tx
and rx messages
o correctly detects both tx and rx timeouts, only delivers one to
the callback, and does not overwrite an earlier error
o logic in i2c_probe now correct
- add "vprintf()" function so that "panic()" function can be
technically correct
- many Hymod board changes
Modifications for Atmel AT91RM9200DK ARM920T based development kit
- Add Atmel DataFlash support for reading and writing.
- Add possibility to boot a Linux from DataFlash with BOOTM command.
- Add Flash detection on Atmel AT91RM9200DK
(between Atmel AT49BV1614 and AT49BV1614A flashes)
- Replace old Ethernet PHY layer functions
- Change link address
* Patch by Frank Smith, 9 Jun 2003:
use CRIT_EXCEPTION for machine check on 4xx
* Patch by Detlev Zundel, 13 Jun 2003:
added implementation of the "carinfo" command in cmd_immap.c
* Patches by Kyle Harris, 13 Mar 2003:
- Add FAT partition support
- Add command support for FAT
- Add command support for MMC
- Add Intel PXA support for video
- Add Intel PXA support for MMC
- Enable MMC and FAT for lubbock board
- Other misc changes for lubbock board
Fixed rarp boot method for IA32 and other little-endian CPUs.
* Patch by Marc Singer, 28 May 2003:
Added port I/O commands.
* Patch by Matthew McClintock, 28 May 2003
- cpu/mpc824x/start.S: fix relocation code when booting from RAM
- minor patches for utx8245
* Patch by Daniel Engström, 28 May 2003:
x86 update
* Patch by Dave Ellis, 9 May 2003 + 27 May 2003:
add nand flash support to SXNI855T configuration
fix/extend nand flash support:
- fix 'nand erase' command so does not erase bad blocks
- fix 'nand write' command so does not write to bad blocks
- fix nand_probe() so handles no flash detected properly
- add doc/README.nand
- add .jffs2 and .oob options to nand read/write
- add 'nand bad' command to list bad blocks
- add 'clean' option to 'nand erase' to write JFFS2 clean markers
- make NAND read/write faster
* Patch by Rune Torgersen, 23 May 2003:
Update for MPC8266ADS board
Fix problem with only partially cleared .bss segment
* Patch by Rune Torgersen, 12 May 2003:
get PCI to work on a MPC8266ADS board; incorporate change to
cpu/mpc8260/pci.c to enable overrides of PCI memory parameters
Add support for Atmel AT91RM9200DK w/NAND
* Patches by Robert Schwebel, 19 Mar 2003:
- use arm-linux-gcc as default compiler for ARM
- fix i2c fixup code
- fix missing baudrate setting
- added $loadaddr / CFG_LOAD_ADDR support to loadb
- moved "ignoring trailing characters" _before_ u-boot wants to
print out diagnostics messages; removes bogus characters at the
end of transmission
* Patch by John Zhan, 18 Mar 2003:
Add support for SinoVee Microsystems SC8xx boards
* Patch by Rolf Offermanns, 21 Mar 2003:
ported the dnp1110 related changes from the current armboot cvs to
current u-boot cvs. smc91111 does not work. problem marked in
smc91111.c, grep for "FIXME".
* Patch by Brian Auld, 25 Mar 2003:
Add support for STM flash chips on ebony board
* Add PCI support for MPC8250 Boards (PM825 module)
* Patch by Stefan Roese, 25 Mar 2003:
(patch by Jón Benediktsson, 11 Dec 2002)
syslog mechanism; used especially for POST results.
* Patch by Klaus Heydeck, 31 Oct 2002:
Add initial support for kup4k board
