path: root/include/fdtdec.h
2016-08-12fdt: allow fdtdec_get_addr_size_*() to translate addressesStephen Warren
Some code may want to read reg values from DT, but from nodes that aren't associated with DM devices, so using dev_get_addr_index() isn't appropriate. In this case, fdtdec_get_addr_size_*() are the functions to use. However, "translation" (via the chain of ranges properties in parent nodes) may still be desirable. Add a function parameter to request that, and implement it. Update all call sites to default to the original behaviour. Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Simon Glass <sjg@chromium.org> Squashed in build fix from Stephen: Signed-off-by: Simon Glass <sjg@chromium.org>
2016-07-24mtd: nand: Add the sunxi NAND controller driverBoris Brezillon
We already have an SPL driver for the sunxi NAND controller, now add the normal/standard one. The source has been copied from Linux 4.6 with a few changes to make it work in u-boot. Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com> Acked-by: Hans de Goede <hdegoede@redhat.com>
2016-07-11sandbox: Find keyboard driver using driver modelSimon Glass
The cros-ec keyboard is always a child of the cros-ec node. Rather than searching the device tree, looking at the children. Remove the compat string which is now unused. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-07-11fdt: Drop unused exynos compatible stringsSimon Glass
A few drivers have moved to driver model, so we can drop these strings. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Jaehoon Chung <jh80.chung@samsung.com>
2016-07-11x86: fdt: Drop the unused compatible strings in fdtdecSimon Glass
We have drivers for several more devices now, so drop the strings which are no-longer used. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-07-05fdt: Drop some unused compatible stringsSimon Glass
We have driver-model drivers for some of these now, so drop them. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-05-31mmc: tegra: add basic Tegra186 supportStephen Warren
Tegra186's MMC controller needs to be explicitly identified. Add another compatible value for it. Tegra186 will use an entirely different clock/reset control mechanism to existing chips, and will use standard clock/reset APIs rather than the existing Tegra-specific custom APIs. The driver support for that isn't ready yet, so simply disable all clock/reset usage if compiling for Tegra186. This must happen at compile time rather than run-time since the custom APIs won't even be compiled in on Tegra186. In the long term, the plan would be to convert the existing custom APIs to standard APIs and get rid of the ifdefs completely. The system's main eMMC will work without any clock/reset support, since the firmware will have already initialized the controller in order to load U-Boot. Hence the driver is useful even in this apparently crippled state. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-05-05Fix various typos, scattered over the code.Robert P. J. Day
Spelling corrections for (among other things): * environment * override * variable * ftd (should be "fdt", for flattened device tree) * embedded * FTDI * emulation * controller
2016-03-17x86: dts: Drop memory SPD compatible stringSimon Glass
This is not needed now that the memory controller driver has the SPD data in its own node. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-03-17x86: Drop all the old pin configuration codeSimon Glass
We don't need this anymore - we can use device tree and the new pinconfig driver instead. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-02-16tegra: nyan-big: Move the LCD driver to driver modelSimon Glass
Adjust the driver to use driver model. The SOR becomes a bridge device. We use the normal simple_panel driver to handle the display itself. We also need to enable some options such as regulators, PWMs and DM_VIDEO itself. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Anatolij Gustschin <agust@denx.de> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-02-06fdt: introduce fdtdec_get_child_countPeng Fan
Introduce fdtdec_get_child_count for get the number of subnodes of one parent node. Signed-off-by: Peng Fan <van.freenix@gmail.com> Cc: Simon Glass <sjg@chromium.org> Acked-by: Simon Glass <sjg@chromium.org>
2016-01-24x86: Drop the irq router compatible stringSimon Glass
We use driver model for this now, so we don't need this string. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-01-20dm: video: sandbox: Convert sandbox to use driver model for videoSimon Glass
Now that driver model support is available, convert sandbox over to use it. We can remove a few of the special hooks that sandbox currently has. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Anatolij Gustschin <agust@denx.de>
2016-01-14Merge branch 'master' of git://git.denx.de/u-boot-x86Tom Rini
2016-01-13fdtdec: Add compatible string for Intel IvyBridge FSPBin Meng
Use "intel,ivybridge-fsp" for Intel IvyBridge FSP compatible string. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2016-01-12dm: serial: Convert ns16550 driver to use driver model PCI APISimon Glass
Use the driver model version of the function to find the BAR. This updates the fdtdec function, of which ns16550 is the only user. The fdtdec_get_pci_bdf() function is dropped for several reasons: - with driver model we should use 'struct udevice *' rather than passing the device tree offset explicitly - there are no other users in the tree - the function parses for information which is already available in the PCI device structure (specifically struct pci_child_platdata which is available at dev_get_parent_platdata(dev) Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Bin Meng <bmeng.cn@gmail.com>
2015-12-20arm: socfpga: Allow DWC2 UDC probing from OFMarek Vasut
The USB gadget framework does not support DM yet, so add this bit to let DWC2 UDC probe from OF on platforms which support it. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@opensource.altera.com> Cc: Lukasz Majewski <l.majewski@majess.pl> Cc: Lukasz Majewski <l.majewski@samsung.com>
2015-12-01dm: tegra: pci: Convert tegra boards to driver model for PCISimon Glass
Adjust the Tegra PCI driver to support driver model and move all boards over at the same time. This can make use of some generic driver model code, such as the range-decoding logic. Signed-off-by: Simon Glass <sjg@chromium.org> Tested-by: Stephen Warren <swarren@nvidia.com>
2015-11-19dm: tegra: Convert keyboard driver to driver modelSimon Glass
Adjust the tegra keyboard driver to support driver model, using the new uclass. Make this the default for all Tegra boards so that those that use a keyboard will build correctly with this driver. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-11-12pci: tegra: add/enable support for Tegra210Stephen Warren
This needs a separate compatible value from Tegra124 since the new HW version has bugs that would prevent a driver for previous HW versions from operating at all. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-11-05Merge git://git.denx.de/u-boot-socfpgaTom Rini
2015-11-05lib, fdt: Adding fdtdec_get_uint functionChin Liang See
Adding fdtdec_get_uint function which is the unsigned version for fdtdec_get_int Signed-off-by: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@opensource.altera.com> Cc: Dinh Nguyen <dinh.linux@gmail.com> Cc: Marek Vasut <marex@denx.de> Cc: Stefan Roese <sr@denx.de> Cc: Vikas Manocha <vikas.manocha@st.com> Cc: Jagannadh Teki <jteki@openedev.com> Cc: Pavel Machek <pavel@denx.de> Cc: Heiko Schocher <hs@denx.de>
2015-11-04fdt: Add a function to look up a /chosen propertySimon Glass
It is sometimes useful to find a property in the chosen node. Add a function for this. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2015-09-15fdt: add new fdt address parsing functionsStephen Warren
fdtdec_get_addr_size() hard-codes the number of cells used to represent an address or size in DT. This is incorrect in many cases depending on the DT binding for a particular node or property (e.g. it is incorrect for the "reg" property). In most cases, DT parsing code must use the properties #address-cells and #size-cells to parse addres properties. This change splits up the implementation of fdtdec_get_addr_size() so that the core logic can be used for both hard-coded and non-hard-coded cases. Various wrapper functions are implemented that support cases where hard-coded cell counts should or should not be used, and where the client does and doesn't know the parent node ID that contains the properties #address-cells and #size-cells. dev_get_addr() is updated to use the new functions. Core functionality in fdtdec_get_addr_size_fixed() is widely tested via fdtdec_get_addr_size(). I tested fdtdec_get_addr_size_auto_noparent() and dev_get_addr() by manually modifying the Tegra I2C driver to invoke them. Much of the core implementation of fdtdec_get_addr_size_fixed(), fdtdec_get_addr_size_auto_parent(), and fdtdec_get_addr_size_auto_noparent() comes from Thierry Reding's previous commit "fdt: Fix fdtdec_get_addr_size() for 64-bit". Based-on-work-by: Thierry Reding <treding@nvidia.com> Cc: Thierry Reding <treding@nvidia.com> Cc: Simon Glass <sjg@chromium.org> Cc: Michal Suchanek <hramrach@gmail.com> Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org> Dropped #define DEBUG at the top of fdtdec.c: Signed-off-by: Simon Glass <sjg@chromium.org>
2015-09-04mmc: dw_mmc: Probe the MMC from OFMarek Vasut
Rework the driver to probe the MMC controller from Device Tree and make it mandatory. There is no longer support for probing from the ancient qts-generated header files. This patch now also removes previous temporary workaround. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Dinh Nguyen <dinguyen@opensource.altera.com> Cc: Pantelis Antoniou <panto@antoniou-consulting.com> Cc: Tom Rini <trini@konsulko.com>
2015-08-31dm: tpm: Convert I2C driver to driver modelSimon Glass
Convert the tpm_tis_i2c driver to use driver model and update boards which use it. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Christophe Ricard<christophe-h.ricard@st.com> Reviewed-by: Heiko Schocher <hs@denx.de>
2015-08-18of: clean up OF_CONTROL ifdef conditionalsMasahiro Yamada
We have flipped CONFIG_SPL_DISABLE_OF_CONTROL. We have cleansing devices, $(SPL_) and CONFIG_IS_ENABLED(), so we are ready to clear away the ugly logic in include/fdtdec.h: #ifdef CONFIG_OF_CONTROL # if defined(CONFIG_SPL_BUILD) && !defined(SPL_OF_CONTROL) # define OF_CONTROL 0 # else # define OF_CONTROL 1 # endif #else # define OF_CONTROL 0 #endif Now CONFIG_IS_ENABLED(OF_CONTROL) is the substitute. It refers to CONFIG_OF_CONTROL for U-boot proper and CONFIG_SPL_OF_CONTROL for SPL. Also, we no longer have to cancel CONFIG_OF_CONTROL in include/config_uncmd_spl.h and scripts/Makefile.spl. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Linus Walleij <linus.walleij@linaro.org>
2015-08-18of: flip CONFIG_SPL_DISABLE_OF_CONTROL into CONFIG_SPL_OF_CONTROLMasahiro Yamada
As we discussed a couple of times, negative CONFIG options make our life difficult; CONFIG_SYS_NO_FLASH, CONFIG_SYS_DCACHE_OFF, ... and here is another one. Now, there are three boards enabling OF_CONTROL on SPL: - socfpga_arria5_defconfig - socfpga_cyclone5_defconfig - socfpga_socrates_defconfig This commit adds CONFIG_SPL_OF_CONTROL for them and deletes CONFIG_SPL_DISABLE_OF_CONTROL from the other boards to invert the logic. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-08-18fdtdec: fix OF_CONTROL switchMasahiro Yamada
There is no case where defined(SPL_DISABLE_OF_CONTROL) is true. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-08-14x86: baytrail: Configure FSP UPD from device treeAndrew Bradford
Allow for configuration of FSP UPD from the device tree which will override any settings which the FSP was built with itself. Modify the MinnowMax and BayleyBay boards to transfer sensible UPD settings from the Intel FSPv4 Gold release to the respective dts files, with the condition that the memory-down parameters for MinnowMax are also used. Signed-off-by: Andrew Bradford <andrew.bradford@kodakalaris.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Bin Meng <bmeng.cn@gmail.com> Removed fsp,mrc-debug-msg and fsp,enable-xhci for minnowmax, bayleybay Fixed lines >80col Signed-off-by: Simon Glass <sjg@chromium.org>
2015-08-08arm: socfpga: misc: Reset ethernet from OFMarek Vasut
Reset the GMAC ethernets based on the "resets" OF node instead of ad-hoc hardcoded values in the U-Boot code. Since we don't have a proper reset framework in place yet, we have to do this slightly ad-hoc parsing of the OF tree instead. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Dinh Nguyen <dinguyen@opensource.altera.com> Cc: Joe Hershberger <joe.hershberger@ni.com>
2015-08-06lib/fdtdec: Fix fdt_addr_t and fdt_size_t typedefYork Sun
fdt_addr_t is a physical address. It can be either 64-bit or 32-bit, depending on the architecture. It should be phys_addr_t instead of u64 or u32. Similarly, fdt_size_t is changed to phys_size_t. Signed-off-by: York Sun <yorksun@freescale.com> CC: Simon Glass <sjg@chromium.org>
2015-08-05dts: Drop unused compatible ID for the NXP video bridgeSimon Glass
This has moved to driver model so we can drop the fdtdec support. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-08-05video: Remove the old parade driverSimon Glass
We have a new one which uses driver model and device tree configuration. Remove the old one. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-08-05power: Remove old TPS65090 driversSimon Glass
Remove the old drivers (both the normal one and the cros_ec one) now that we have new drivers that use driver model. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-07-28ARM: Tegra210: Add support to common Tegra source/config filesTom Warren
Derived from Tegra124, modified as appropriate during T210 board bringup. Cleaned up debug statements to conserve string space, too. This also adds misc 64-bit changes from Thierry Reding/Stephen Warren. Signed-off-by: Tom Warren <twarren@nvidia.com> Signed-off-by: Thierry Reding <treding@nvidia.com> Signed-off-by: Stephen Warren <swarren@nvidia.com>
2015-06-10dm: usb: tegra: Drop legacy USB codeSimon Glass
Drop the code that doesn't use driver model for USB. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-06-10sandbox: Move CONFIG_SANDBOX_SERIAL to KconfigSimon Glass
Move this over to Kconfig and tidy up. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-06-04x86: gpio: add pinctrl support from the device treeGabriel Huau
Every pin can be configured now from the device tree. A dt-bindings has been added to describe the different property available. Change-Id: I1668886062655f83700d0e7bbbe3ad09b19ee975 Signed-off-by: Gabriel Huau <contact@huau-gabriel.fr> Acked-by: Simon Glass <sjg@chromium.org>
2015-06-04x86: Refactor PIRQ routing supportBin Meng
PIRQ routing is pretty much common in Intel chipset. It has several PIRQ links (normally 8) and corresponding registers (either in PCI configuration space or memory-mapped IBASE) to configure the legacy 8259 IRQ vector mapping. Refactor current Queensbay PIRQ routing support using device tree and move it to a common place, so that we can easily add PIRQ routing support on a new platform. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-05-13tegra: video: Support serial output resource (SOR) on tegra124Simon Glass
The SOR is required for talking to eDP LCD panels. Add a driver for this which will be used by the DisplayPort driver. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Anatolij Gustschin <agust@denx.de> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-05-13fdt: Add binding decode function for display-timingsSimon Glass
This is useful for display parameters. Add a simple decode function to read from this device tree node. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-05-06dm: usb: exynos: Drop legacy USB codeSimon Glass
2015-04-23dm: core: Select device tree control correctly for SPLSimon Glass
Some boards will not use device tree for SPL even with driver model. Add the logic to support this. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-04-23fdt: Rename setup_fdt() and make it prepare alsoSimon Glass
There is little reason to split these two functions. Bring them together which simplifies the init sequence. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-04-23fdt: sandbox: Move setup code from board_f to fdtdecSimon Glass
We want to be able to set up the device tree in SPL, so move this code to a common place. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-04-18cros_ec: exynos: Match up device tree with kernel versionSimon Glass
The U-Boot device trees are slightly different in a few places. Adjust them to remove most of the differences. Note that U-Boot does not support the concept of interrupts as distinct from GPIOs, so this difference remains. For sandbox, use the same keyboard file as for ARM boards and drop the host emulation bus which seems redundant. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-04-18fdt: Drop LPC compatible string in fdtdecSimon Glass
This is not needed now that we have moved chromebook_link and cros_ec to driver model. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-04-18fdt: cros_ec: Drop compatible string in fdtdecSimon Glass
This is not needed now that we have moved to driver model. Signed-off-by: Simon Glass <sjg@chromium.org>
