This function has not been conditionally compiled for some time, so
remove the incorrect guards around the declaration.
When OF_LIVE flag is enabled on a 64 bits platform, there is an
issue when dev_read_addr() is called and need to perform an address
translation using __of_translate_address().
In case of error, __of_translate_address() return's value is OF_BAD_ADDR
(wich is defined in include/dm/of.h to ((u64)-1) = 0xffffffffffffffff).
The return value of dev_read_addr() is often compared to FDT_ADDR_T_NONE
which is defined as (-1U) = 0xffffffff.
In this case the comparison is always false.
To fix this issue, define FDT_ADDR_T_NONE to (ulong)(-1) in case of
AARCH64. Update accordingly related tests.
Signed-off-by: Patrice Chotard <patrice.chotard@foss.st.com>
Sphinx expects Return: and not @return to indicate a return value.
find . -name '*.c' -exec \
sed -i 's/^\(\s\)\*\(\s*\)@return\(\s\)/\1*\2Return:\3/' {} \;
find . -name '*.h' -exec \
Signed-off-by: Heinrich Schuchardt <heinrich.schuchardt@canonical.com>
This old macro is not needed anymore since we can use IS_ENABLED() now.
Drop it.
Keep track of where the devicetree came from, so we can report this later.
At present this override function is called even when OF_BOARD is not
enabled. This makes it impossible to disable this feature and in fact
makes the OF_BOARD option useless.
Reinstate its intended purpose, so that it is possible to switch between
the appended devicetree and one provided by the board's custom function.
A follower patch adds warnings for this scenario, but for now we don't
have a Kconfig that definitively tells us that OF_BOARD should be used.
Move this to the header file to clean up the C code.
OF_HOSTFILE is used on sandbox configs only. Although it's pretty
unique and not causing any confusions, we are better of having simpler
config options for the DTB.
So let's replace that with the existing OF_BOARD. U-Boot would then
have only three config options for the DTB origin.
- OF_SEPARATE, build separately from U-Boot
- OF_BOARD, board specific way of providing the DTB
- OF_EMBED embedded in the u-boot binary(should not be used in production
Signed-off-by: Ilias Apalodimas <ilias.apalodimas@linaro.org>
The previous patches removed OF_PRIOR_STAGE from the last consumers of the
Kconfig option. Cleanup any references to it in documentation, code and
configuration options.
Reserved memory nodes can have additional flags. Support reading and
writing these flags to ensure that reserved memory nodes can be properly
parsed and emitted.
This converts support for the existing "no-map" flag to avoid extending
the argument list for fdtdec_add_reserved_memory() to excessive length.
Signed-off-by: Thierry Reding <treding@nvidia.com>
Signed-off-by: Tom Warren <twarren@nvidia.com>
The fdtdec_set_carveout() function's parameters are inconsistent with
the parameters passed to fdtdec_add_reserved_memory(). Fix up the order
to make it more consistent.
Reserved memory nodes can have a compatible string list to identify the
type of reserved memory that they represent. Support specifying an
optional compatible string list when creating these nodes.
When retrieving a given carveout for a device, allow callers to query
the name. This helps differentiating between carveouts when there are
more than one.
This is also useful when copying carveouts to help assign a meaningful
name that cannot always be guessed.
The current API is outdated as it requires a devicetree pointer.
Move these functions to use the ofnode API and update this globally. Add
some tests while we are here.
Correct the call in exynos_dsim_config_parse_dt() which is obviously
wrong.
Add a bus driver for this and use it to configure the bus parameters for
the Ethernet interface. Drop the old pre-driver-model code.
Switch over to use driver model for Ethernet.
Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
Add functions to add size of addresses in the device tree using ofnode
references.
If the size is not set, return FDT_SIZE_T_NONE.
Signed-off-by: Chen Guanqiao <chenguanqiao@kuaishou.com>
Add boolean input argument @no_map to helper function
fdtdec_add_reserved_memory() to add or not "no-map" property
for an added reserved memory node.
Property no-map is used by the Linux kernel to not not map memory
in its static memory mapping. It is needed for example for the|
consistency of system non-cached memory and to prevent speculative
accesses to some firewalled memory.
No functional change. A later change will update to OPTEE library to
add no-map property to OP-TEE reserved memory nodes.
Signed-off-by: Etienne Carriere <etienne.carriere@st.com>
Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
Add fdtdec_get_pci_bus_range to read bus-range property
values.
Signed-off-by: Suneel Garapati <sgarapati@marvell.com>
New function should be called from board dram_init() because it initialized
gd->ram_base/ram_size. It finds the lowest available memory.
On systems with multiple memory nodes finding out the first memory node by
fdtdec_setup_mem_size_base() is not enough because this memory can be above
actual U-Boot VA mapping. Currently only mapping till 39bit is supported
(Full 44bit mapping was removed by commit 7985cdf74b28 ("arm64: Remove
non-full-va map code")).
If DT starts with the first memory node above 39bit address then system can
be unpredictable.
The function is available only when multiple memory bank support is
enabled.
Calling fdtdec_setup_memory_banksize() from dram_init() is not possible
because fdtdec_setup_memory_banksize() is saving dram information to bd
structure which is placed on stack but not initialized at this time. Also
stack is placed at location setup in dram_init().
This reverts commit 3ebe09d09a407f93022d945a205c5318239eb3f6.
There is no user of this split function that's why remove it.
This reverts commit 118f4d4559a4386fa87a1e2509e84a1986b24a34.
This reverts commit 5d3a21df6694ebd66d5c34c9d62a26edc7456fc7, reversing
changes made to 56d37f1c564107e27d873181d838571b7d7860e7.
Unfortunately this is causing CI failures:
https://travis-ci.org/github/trini/u-boot/jobs/711313649
Add weak function which is called right after fdtdec_setup() configured
the U-Boot DT. This permits board-specific adjustments to the U-Boot DT
before U-Boot starts parsing the DT. This could be used e.g. to patch in
various custom nodes or merge in DT fragments from prior-stage firmware.
Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com>
Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
Tidy up a few places where const * should be used.
These declarations are only used in fdtdec.c so move them to its header
file.
The phandlep pointer returning the phandle to the caller is optional
and if it is not set when calling fdtdec_add_reserved_memory() it is
highly likely that the caller is not interested in a phandle to the
created reserved-memory area and really just wants that area added.
So just don't create a phandle in that case.
Signed-off-by: Heiko Stuebner <heiko.stuebner@theobroma-systems.com>
The change adding fdtdec_add_reserved_memory() already protected the added
phandle against the phandlep being NULL - making the phandlep var optional.
But in the early code checking for an already existing carveout this check
was not done and thus the phandle assignment could run into trouble,
so add a check there as well, which makes the function still return
successfully if a matching region is found, even though no-one wants to
work with the phandle.
Fixes: c9222a08b3f7 ("fdtdec: Implement fdtdec_add_reserved_memory()")
This function ise effectively replaced by ofnode_read_pci_addr() which
works with flat tree. Delete it to avoid code duplication.
The current preprocessor logic prevents CONFIG_OF_PRIOR_STAGE from being
used in U-Boot SPL. Change the logic to also make it available in U-Boot
SPL.
Signed-off-by: Lukas Auer <lukas.auer@aisec.fraunhofer.de>
Tested-by: Bin Meng <bmeng.cn@gmail.com>
Reviewed-by: Anup Patel <anup.patel@wdc.com>
This function can be used to set the local MAC address for the default
Ethernet interface in its device tree node. The default interface is
identified by the "ethernet" alias.
One case where this is useful is for devices that store their MAC
address in a custom location. Once extracted, board code can store the
MAC address in U-Boot's control DTB so that it will automatically be
used by the Ethernet uclass.
U-Boot already defines the {upper,lower}_32_bits() macros that have the
same purpose. Use the existing macros instead of defining new APIs.
The fdt_setprop_u32() function does everything that we need, so we
really only use the function as a convenience wrapper, in which case it
can simply be a static inline function.
The fdtdec_get_carveout() and fdtdec_set_carveout() function can be used
to read a carveout from a given node or add a carveout to a given node
using the standard device tree bindings (involving reserved-memory nodes
and the memory-region property).
This function can be used to add subnodes in the /reserved-memory node.
This function can be used to set a phandle for a given node.
These helpers can be used to unpack variables of type fdt_addr_t and
fdt_size_t into a pair of 32-bit variables. This is useful in cases
where such variables need to be written to properties (such as "reg")
of a device tree node where they need to be split into cells.
These macros are useful for converting the endianness of variables of
type fdt_addr_t and fdt_size_t.
Split fdtdec_setup_memory_banksize() into fdtdec_setup_memory_banksize_fdt(),
which allows the caller to pass custom blob into the function and the
original fdtdec_setup_memory_banksize(), which uses the gd->fdt_blob. This
is useful when configuring the DRAM properties from a FDT blob fragment
passed in by the firmware.
Split fdtdec_setup_mem_size_base() into fdtdec_setup_mem_size_base_fdt(),
original fdtdec_setup_mem_size_base(), which uses the gd->fdt_blob. This
- DM I2C improvements
This is no-longer used. Drop it.
Reviewed-by: Lukasz Majewski <lukma@denx.de>
This enum still exists but we can shrink it a little based on recent
driver-model conversions with samsung. Update it to remove unused items.
Find out the highest alias ID used for certain subsystem.
This call will be used for alocating IDs for i2c buses which are not
described in DT.
In some cases it may be useful to be able to change the fdt we have been
using and use another one instead. For example, the TI platforms uses an
EEPROM to store board information and, based on the type of board,
different dtbs are used by the SPL. When DM_I2C is used, a first dtb must
be used before the I2C is initialized and only then the final dtb can be
selected.
To speed up the process and reduce memory usage, introduce a new function
fdtdec_setup_best_match() that re-use the DTBs loaded in memory by
fdtdec_setup() to select the best match.
Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com>
Commit 90c08fa038451d (fdt: Add device tree memory bindings) removed the
prototype declaration of board_fdt_blob_setup(), most likely by mistake.
This didn't break the build because the only file calling this function
(lib/fdtdec.c) provides a local weak definition. Restore the
declaration.
Cc: Michael Pratt <mpratt@chromium.org>
Signed-off-by: Baruch Siach <baruch@tkos.co.il>
This function is not used in U-Boot now. Remove it along with its 'memory'
version.
This patch renames the routine fdtdec_setup_memory_size()
to fdtdec_setup_mem_size_base() as it now fills the
mem base as well along with size.
Signed-off-by: Siva Durga Prasad Paladugu <siva.durga.paladugu@xilinx.com>
Add support for loading U-Boot on the Broadcom 7445 SoC. This port
assumes Broadcom's BOLT bootloader is acting as the second stage
bootloader, and U-Boot is acting as the third stage bootloader, loaded
as an ELF program by BOLT.
Signed-off-by: Thomas Fitzsimmons <fitzsim@fitzsim.org>
Cc: Stefan Roese <sr@denx.de>
Cc: Florian Fainelli <f.fainelli@gmail.com>
