path: root/include/fdt_support.h
2016-12-02libfdt: replace ARCH_FIXUP_FDT with ARCH_FIXUP_FDT_MEMORYMasahiro Yamada
Commit e2f88dfd2d96 ("libfdt: Introduce new ARCH_FIXUP_FDT option") allows us to skip memory setup of DTB, but a problem for ARM is that spin_table_update_dt() and psci_update_dt() are skipped as well if CONFIG_ARCH_FIXUP_FDT is disabled. This commit allows us to skip only fdt_fixup_memory_banks() instead of the whole of arch_fixup_fdt(). It will be useful when we want to use a memory node from a kernel DTB as is, but need some fixups for Spin-Table/PSCI. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Alexey Brodkin <abrodkin@synopsys.com> Acked-by: Simon Glass <sjg@chromium.org> Fixed build error for x86: Signed-off-by: Simon Glass <sjg@chromium.org>
2016-10-13cmd/fdt: add possibilty to have 'extrasize' on fdt resizeHannes Schmelzer
Sometimes devicetree nodes and or properties are added out of the u-boot console, maybe through some script or manual interaction. The devicetree as loaded or embedded is quite small, so the devicetree has to be resized to take up those new nodes/properties. In original the devicetree was only extended by effective 4 * add_mem_rsv. With this commit we can add an argument to the "fdt resize" command, which takes the extrasize to be added. Signed-off-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com> Signed-off-by: Hannes Schmelzer <oe5hpm@oevsv.at> Acked-by: Simon Glass <sjg@chromium.org>
2016-09-27usb: fsl: Rename fdt_fixup_dr_usbSriram Dash
The function fdt_fixup_dr_usb is specific to fsl/nxp. So, make the function name explicit and rename fdt_fixup_dr_usb into fsl_fdt_fixup_dr_usb. Signed-off-by: Sriram Dash <sriram.dash@nxp.com>
2016-08-12fdt_support: fdt_translate_address() blob const correctnessStephen Warren
The next patch will call fdt_translate_address() from somewhere with a "const void *blob" rather than a "void *blob", so fdt_translate_address() must accept a const pointer too. Constify the minimum number of function parameters to achieve this. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org> Squashed in build fix from Stephen: Signed-off-by: Simon Glass <sjg@chromium.org>
2016-07-19fdt_support: define stub for fdt_fixup_mtdpartsChristopher Spinrath
Define an inline stub for fdt_fixup_mtdparts in the case that CONFIG_FDT_FIXUP_PARTITIONS is not defined. This avoids the need to guard every call to this function by a proper #ifdef in board files. Signed-off-by: Christopher Spinrath <christopher.spinrath@rwth-aachen.de> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Igor Grinberg <grinberg@compulab.co.il>
2016-04-10drivers:usb:common:fsl-dt-fixup: Add device-tree fixup support for xhci ↵Sriram Dash
controller Enables usb device-tree fixup code to incorporate xhci controller Signed-off-by: Ramneek Mehresh <ramneek.mehresh@nxp.com> Signed-off-by: Sriram Dash <sriram.dash@nxp.com>
2015-07-20fdt: prevent clearing memory node if there are no banksAndre Przywara
Avoid clearing the reg property in the memory DT node if no memory banks have been specified for a board (CONFIG_NR_DRAM_BANKS == 0). This allows boards to let U-Boot skip the DT memory tinkering in case other firmware has already setup the node properly before. This should be safe as all callers of fdt_fixup_memory_banks that use a computed <banks> value put at least 1 in there. Add some documentation comments to the header file. Signed-off-by: Andre Przywara <osp@andrep.de> Acked-by: Simon Glass <sjg@chromium.org>
2015-06-05fdt: Documentation for a few support functions aside their prototypesPaul Kocialkowski
This instroduces comments that explain the purpose, parameters and return codes of a few fdt support functions, that are used to fill the fdt. Signed-off-by: Paul Kocialkowski <contact@paulk.fr> Acked-by: Simon Glass <sjg@chromium.org>
2015-06-05fdt: Pass the device serial number through devicetreePaul Kocialkowski
Before device-tree, the device serial number used to be passed to the kernel using ATAGs (on ARM). This is now deprecated and all the handover to the kernel should now be done using device-tree. Thus, this passes the serial-number property to the kernel using the serial-number property of the root node, as expected by the kernel. The serial number is a string that somewhat represents the device's serial number. It might come from some form of storage (e.g. an eeprom) and be programmed at factory-time by the manufacturer or come from identification bits available in e.g. the SoC. Signed-off-by: Paul Kocialkowski <contact@paulk.fr> Reviewed-by: Simon Glass <sgj@chromium.org>
2015-04-22fdt: add new fdt_fixup_display function to configure displayTim Harvey
Add 'fdt_fixup_display' function to fixup device-tree native-mode property of display-timings node to select timings for a specific display. This is useful if a device-tree has configurations for multiple display timings for undetectable displays. see kernel Documentation/devicetree/bindings/video/display-timing.txt Signed-off-by: Tim Harvey <tharvey@gateworks.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-02-17cmd_fdt: Actually fix fdt command in sandboxJoe Hershberger
Commit 90bac29a76bc8d649b41a55f2786c0abef9bb2c1 claims to fix this bug that was introduced in commit a92fd6577ea17751ead9b50243e3c562125cf581 but doesn't actually make the change that the commit message describes. Actually fix the bug this time. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-11-26Merge branch 'master' of http://git.denx.de/u-boot-sunxiTom Rini
2014-11-25fdt_support: Add a fdt_setup_simplefb_node helper functionHans de Goede
Add a generic helper to fill and enable simplefb nodes. The first user of this will be the sunxi display code. lcd_dt_simplefb_configure_node is also a good candidate to be converted to use this, but that requires someone to run some tests first, as lcd_dt_simplefb_configure_node does not honor #address-cells and #size-cells, but simply assumes 1 and 1 for both. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Tested-by: Stephen Warren <swarren@wwwdotorg.org> Acked-by: Simon Glass <sjg@chromium.org>
2014-11-21fdt: Add ft_system_setup() function for system device tree additionsSimon Glass
Add an additional function for adding information to the device tree before booting. This permits additions which are not board-specific. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Anatolij Gustschin <agust@denx.de> Reviewed-by: Tom Rini <trini@ti.com>
2014-11-21fdt: Tidy up error handling in image_setup_libfdt()Simon Glass
The message about needing to reset should be printed no matter what error is printed. Also, an error should always be printed. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Anatolij Gustschin <agust@denx.de> Reviewed-by: Tom Rini <trini@ti.com>
2014-11-21fdt: Export the fdt_find_or_add_subnode() functionSimon Glass
This function is useful for ensuring that a node exists. Export it so it can be used more widely. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Anatolij Gustschin <agust@denx.de> Reviewed-by: Tom Rini <trini@ti.com>
2014-11-21fdt: Allow ft_board_setup() to report failureSimon Glass
This function can fail if the device tree runs out of space. Rather than silently booting with an incomplete device tree, allow the failure to be detected. Unfortunately this involves changing a lot of places in the code. I have not changed behvaiour to return an error where one is not currently returned, to avoid unexpected breakage. Eventually it would be nice to allow boards to register functions to be called to update the device tree. This would avoid all the many functions to do this. However it's not clear yet if this should be done using driver model or with a linker list. This work is left for later. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Anatolij Gustschin <agust@denx.de>
2014-10-25fdt_support: add prototypes for __weak functionsJeroen Hofstee
Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
2014-09-25fdt_support: Make of_bus_default_count_cells non staticArnab Basu
of_bus_default_count_cells can be used to get the #address-cells and #size-cells defined by the current node's parent node. This is required when using of_read_number to read from FDT nodes that can be 32 or 64 bytes depending on values defined by the parent. Signed-off-by: Arnab Basu <arnab.basu@freescale.com> CC: Scott Wood <scottwood@freescale.com>
2014-09-25fdt_support: Move of_read_number to fdt_support.hArnab Basu
This is being done so that it can be used outside 'fdt_support.c'. Making life more convenient when reading device node properties that can be 32 or 64 bits long. Signed-off-by: Arnab Basu <arnab.basu@freescale.com> Cc: Scott Wood <scottwood@freescale.com>
2014-08-09fdt: Rename fdt_resize() to fdt_shrink_to_minimum()Simon Glass
Since libfdt now has an fdt_resize() function, we need to rename the U-Boot one. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-07-03armv8/fsl-lsch3: Add support to load and start MC FirmwareJ. German Rivera
Adding support to load and start the Layerscape Management Complex (MC) firmware. First, the MC GCR register is set to 0 to reset all cores. MC firmware and DPL images are copied from their location in NOR flash to DDR. MC registers are updated with the location of these images. Deasserting the reset bit of MC GCR register releases core 0 to run. Core 1 will be released by MC firmware. Stop bits are not touched for this step. U-boot waits for MC until it boots up. In case of a failure, device tree is updated accordingly. The MC firmware image uses FIT format. Signed-off-by: J. German Rivera <German.Rivera@freescale.com> Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Lijun Pan <Lijun.Pan@freescale.com> Signed-off-by: Shruti Kanetkar <Shruti@Freescale.com>
2014-06-19fdt_support: delete force argument of fdt_chosen()Masahiro Yamada
After all, we have realized "force" argument is completely useless. fdt_chosen() was always called with force = 1. We should always want to do the same thing (set appropriate value to the property) even if the property already exists. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-06-19fdt_support: delete force argument of fdt_initrd()Masahiro Yamada
After all, we have realized "force" argument is completely useless. fdt_initrd() was always called with force = 1. We should always want to do the same thing (set appropriate value to the property) even if the property already exists. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-05-09Merge branch 'u-boot/master'Albert ARIBAUD
Conflicts: drivers/net/Makefile (trivial merge)
2014-04-22fdt_support: Add helper function to read "ranges" propertyAlexander Graf
This patch adds a helper function that can be used to interpret most "ranges" properties in the device tree. It reads the n'th range out of a "ranges" array and returns the node's virtual address of the range, the physical address that range starts at and the size of the range. Signed-off-by: Alexander Graf <agraf@suse.de> Acked-by: Scott Wood <scottwood@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-04-22fdt_support: split fdt_getprop_u32_defaultAlexander Graf
We already have a nice helper to give us a property cell value with default fall back from a path. Split that into two helpers - one for the old path based lookup and one to give us a value based on a node offset. Signed-off-by: Alexander Graf <agraf@suse.de> Acked-by: Scott Wood <scottwood@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-04-17fdt: call ft_board_setup_ex() at the end of image_setup_libfdt()Vitaly Andrianov
The keystone2 SOC requires to fix all 32 bit aliased addresses to their 36 physical format. This has to happen after all fdt nodes are added or modified. Signed-off-by: Vitaly Andrianov <vitalya@ti.com> Signed-off-by: Murali Karicheri <m-karicheri2@ti.com> Acked-by: Tom Rini <trini@ti.com>
2014-03-21tools, fit_check_sign: verify a signed fit imageHeiko Schocher
add host tool "fit_check_sign" which verifies, if a fit image is signed correct. Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Simon Glass <sjg@chromium.org>
2013-05-14image: Add device tree setup to image librarySimon Glass
This seems to be a common function for several architectures, so create a common function rather than duplicating the code in each arch. Also make an attempt to avoid introducing #ifdefs in the new code, partly by removing useless #ifdefs around function declarations in the image.h header. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-02-08Clean up libfdt.h includesGerald Van Baren
The libfdt.h file is the definition file for libfdt. It is unnecessary to include other fdt header files (the necessary ones are pulled in by libfdt.h). Signed-off-by: Gerald Van Baren <gvb@unssw.com> Acked-by: Simon Glass <sjg@chromium.org> Acked-by: Stefan Roese <sr@denx.de>
2013-02-07common/fdt_support.c: sparse fixesKim Phillips
trivial: fdt_support.c:89:64: warning: Using plain integer as NULL pointer fdt_support.c:325:65: warning: Using plain integer as NULL pointer fdt_support.c:352:65: warning: Using plain integer as NULL pointer For the following bad constant expression, We hardcode the max. number of memory banks to four for the foreseeable future, and add an error with instructions on what to do once it's exceeded: fdt_support.c:397:22: error: bad constant expression For the rest below, sparse found a couple of wrong endian conversions in of_bus_default_translate() and fdt_get_base_address(), but otherwise the rest is mostly annotation fixes: fdt_support.c:64:24: warning: cast to restricted __be32 fdt_support.c:192:21: warning: incorrect type in assignment (different base types) fdt_support.c:192:21: expected unsigned int [unsigned] [usertype] tmp fdt_support.c:192:21: got restricted __be32 [usertype] <noident> fdt_support.c:201:21: warning: incorrect type in assignment (different base types) fdt_support.c:201:21: expected unsigned int [unsigned] [addressable] [usertype] tmp fdt_support.c:201:21: got restricted __be32 [usertype] <noident> fdt_support.c:304:13: warning: incorrect type in assignment (different base types) fdt_support.c:304:13: expected unsigned int [unsigned] [usertype] val fdt_support.c:304:13: got restricted __be32 [usertype] <noident> fdt_support.c:333:13: warning: incorrect type in assignment (different base types) fdt_support.c:333:13: expected unsigned int [unsigned] [usertype] val fdt_support.c:333:13: got restricted __be32 [usertype] <noident> fdt_support.c:359:13: warning: incorrect type in assignment (different base types) fdt_support.c:359:13: expected unsigned int [unsigned] [usertype] val fdt_support.c:359:13: got restricted __be32 [usertype] <noident> fdt_support.c:373:21: warning: cast to restricted __be32 fdt_support.c:963:48: warning: incorrect type in argument 1 (different base types) fdt_support.c:963:48: expected restricted __be32 const [usertype] *p fdt_support.c:963:48: got unsigned int [usertype] *<noident> fdt_support.c:971:48: warning: incorrect type in argument 1 (different base types) fdt_support.c:971:48: expected restricted __be32 const [usertype] *p fdt_support.c:971:48: got unsigned int [usertype] *<noident> fdt_support.c:984:29: warning: incorrect type in argument 1 (different base types) fdt_support.c:984:29: expected restricted __be32 const [usertype] *cell fdt_support.c:984:29: got unsigned int [usertype] *addr fdt_support.c:996:32: warning: incorrect type in argument 1 (different base types) fdt_support.c:996:32: expected restricted __be32 const [usertype] *cell fdt_support.c:996:32: got unsigned int [usertype] *addr fdt_support.c:1041:41: warning: incorrect type in argument 1 (different base types) fdt_support.c:1041:41: expected restricted __be32 const [usertype] *cell fdt_support.c:1041:41: got unsigned int [usertype] *addr fdt_support.c:1053:41: warning: incorrect type in argument 2 (different base types) fdt_support.c:1053:41: expected restricted __be32 const [usertype] *range fdt_support.c:1053:41: got unsigned int const [usertype] *[assigned] ranges fdt_support.c:1064:53: warning: incorrect type in argument 2 (different base types) fdt_support.c:1064:53: expected restricted __be32 const [usertype] *addr fdt_support.c:1064:53: got unsigned int [usertype] *addr fdt_support.c:1110:50: warning: incorrect type in argument 2 (different base types) fdt_support.c:1110:50: expected restricted __be32 const [usertype] *addr fdt_support.c:1110:50: got unsigned int *<noident> fdt_support.c:1121:49: warning: incorrect type in argument 1 (different base types) fdt_support.c:1121:49: expected restricted __be32 const [usertype] *cell fdt_support.c:1121:49: got unsigned int *<noident> fdt_support.c:1147:60: warning: incorrect type in argument 2 (different base types) fdt_support.c:1147:60: expected restricted __be32 const [usertype] *addr fdt_support.c:1147:60: got unsigned int *<noident> fdt_support.c:1081:5: warning: symbol '__of_translate_address' was not declared. Should it be static? fdt_support.c:1154:5: error: symbol 'fdt_translate_address' redeclared with different type (originally declared at include/fdt_support.h:95) - incompatible argument 3 (different base types) fdt_support.c: In function 'fdt_node_offset_by_compat_reg': fdt_support.c:1173:17: warning: initialization discards 'const' qualifier from pointer target type [enabled by default] See also linux kernel commit 0131d897 "of/address: use proper endianess in get_flags". Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Cc: Jerry Van Baren <gvb.uboot@gmail.com>
2013-02-07treewide: include libfdt_env.h before fdt.hKim Phillips
and, if including libfdt.h which includes libfdt_env.h in the correct order, don't include fdt.h before libfdt.h. this is needed to get the fdt type definitions set from the project environment before fdt.h uses them. Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Cc: Jerry Van Baren <gvb.uboot@gmail.com>
2012-02-15powerpc/8xxx:Add MPH controller support in USB device-tree fixupramneek mehresh
Add support for fixing usb mode and phy type for MPH(Multi Port Host) USB controllers in device-tree nodes. Required for socs like P3060, P5020, etc having MPH USB controller Signed-off-by: Ramneek Mehresh <ramneek.mehresh@freescale.com>
2011-11-13Fix constness of the fdt void pointer in fdt_getprop_u32_defaultGabe Black
The function fdt_getprop_u32_default doesn't modify the fdt, so it can use a const void * for its fdt argument. Signed-off-by: Gabe Black <gabeblack@chromium.org>
2011-10-18fdt: Add new fdt_set_node_status & fdt_set_status_by_alias helpersShengzhou Liu
Add common function fdt_set_node_status() to assist in various locations that we set a nodes status. This function utilizes the status values that are part of the EPAPR spec (on power.org). fdt_set_status_by_alias() is based on fdt_set_node_status() but uses an alias string to identify the node to update. We also add some shortcut functions to help the common cases of setting "okay" and "disabled": fdt_status_okay() fdt_status_disabled() fdt_status_okay_by_alias() fdt_status_disabled_by_alias() Finally, we fixup the corenet_ds ethernet code which previously had a function by the same name that can be replaced with the new helpers. Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Gerald Van Baren <vanbaren@cideas.com>
2011-10-15fdt: check for fdt errors in fdt_create_phandleTimur Tabi
fdt_create_phandle() was ignoring errors from fdt_set_phandle(). If an error occurs, print an error message and return 0, which is an invalid phandle. We also need to change the return type for fdt_create_phandle() to indicate that it cannot return an error code. Signed-off-by: Timur Tabi <timur@freescale.com>
2011-10-15fdt: Add a do_fixup_by_path_string() functionChunhe Lan
The do_fixup_by_path_string() will set the specified node's property to the value contained in "status". It would just be an inline wrapper for do_fixup_by_path() that calls strlen on the argument. Signed-off-by: Chunhe Lan <Chunhe.Lan@freescale.com>
2011-09-29fdt: Add new fdt_create_phandle helperKumar Gala
Add a helper function that will return a phandle value for the given node. If the node doesn't have a phandle already one will be created. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Gerald Van Baren <vanbaren@cideas.com>
2011-09-29fdt: Rename fdt_create_phandle to fdt_set_phandleKumar Gala
The old fdt_create_phandle didn't actually create a phandle it just set one. We'll introduce a new helper that actually does creation. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Gerald Van Baren <vanbaren@cideas.com>
2011-07-14fdt: introduce fdt_create_phandle()Gerald Van Baren
The ePAPR specification says that phandle properties should be called "phandle", and not "linux,phandle". To facilitate the migration from "linux,phandle" to "phandle", introduce function fdt_create_phandle(), which creates a phandle in a given node. For now, we create both the "phandle" and "linux,phandle" properties. A later version of this function will remove support for "linux,phandle". Signed-off-by: Timur Tabi <timur@freescale.com>
2011-07-14fdt: add prototype for fdt_increase_size()Timur Tabi
Add a prototype for fdt_increase_size() so that anyone can call it. Signed-off-by: Timur Tabi <timur@freescale.com>
2011-07-14fdt: introduce fdt_verify_alias_address() and fdt_get_base_address()Timur Tabi
Introduce two functions, fdt_verify_alias_address() and fdt_get_base_address(), which can be used to verify the physical address of a device in a device tree. fdt_get_base_address() returns the base address of an SOC or PCI node. fdt_verify_alias_address() prints a message if the address of a node specified by an alias does not match the given physical address. Signed-off-by: Timur Tabi <timur@freescale.com>
2010-10-18FDT: Add fixup support for multiple banks of memoryJohn Rigby
Add fdt_fixup_memory_banks and reimplement fdt_fixup_memory using it. Tested on OMAP3 beagle board with two banks of memory. Signed-off-by: John Rigby <john.rigby@linaro.org> CC: Jerry Van Baren <vanbaren@cideas.com> Acked-by: Gerald Van Baren <vanbaren@cideas.com>
2010-10-12fdt_support: support adding EDID property to FDT display nodesAnatolij Gustschin
Boards can pass display timing info for drivers using EDID block. Provide common function to add board specific EDID data to the device tree. Subsequent patch makes use of this functionality. Detailed timing descriptor data from EDID is used for programming the display controller. This is currently implemented on the Linux side by the fsl-diu-fb frame buffer driver and it is documented there in Documentation/powerpc/dts-bindings/fsl/diu.txt. Signed-off-by: Anatolij Gustschin <agust@denx.de> Acked-by: Detlev Zundel <dzu@denx.de> Cc: Gerald Van Baren <vanbaren@cideas.com>
2010-09-23ppc4xx/fdt/flash: Change fdt_fixup_nor_flash_node() to not rely on cs sizeStefan Roese
This patch changes the behaviour of the fdt_fixup_nor_flash_node() function. Now it doesn't patch the size of the "reg" property with the chip-select size, but with the size returned from the new function flash_get_bank_size(). This function will return per weak default the flash size of the bank (bank = chip-select numer) detected by the flash driver. If this does not fit your needs, this function may be overridden by a board specific one. For this the parameters needed to be changed. So I intentionally squashed the PPC4xx stuff using this routine into this patch. Otherwise it would not be git-bisectable anymore. The board specific function for the AMCC/APM Ebony eval board is now included in this patch version. Signed-off-by: Stefan Roese <sr@denx.de> Tested-by: Detlev Zundel <dzu@denx.de> Cc: Gerald Van Baren <vanbaren@cideas.com> Cc: Wolfgang Denk <wd@denx.de>
2010-07-26fdt: Add function to alloc phandle valuesKumar Gala
If we are creating reference (handles) to nodes in a device tree we need to first create a new phandle in node and this needs a new phandle value. So we search through the whole dtb to find the max phandle value and return the next greater value for a new phandle allocation. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Gerald Van Baren <vanbaren@cideas.com>
2010-07-20fdt: Add fdt_node_offset_by_compat_reg helperKumar Gala
Given a compatible string and physical address try and find a node that matches. This is useful when we want to find a specific device node to update (for example if we have multiple PCI nodes we can use the physical address to distinguish them when trying to update the device tree). Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Gerald Van Baren <vanbaren@cideas.com>
2010-07-20fdt: Add fdt_translate_address to convert reg node to cpu phys addrKumar Gala
This code is extracted out of the Linux Kernel code from arch/powerpc/kernel/prom_parse.c. We maintain some of the same structure to support multiple bus types even though we only have one in the current code. In the future we might want to translate across a PCI bus and thus it will be easier to add that functionality back in. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Gerald Van Baren <vanbaren@cideas.com>
