path: root/include/fdt.h
2008-03-27Fix host tool build breakage, take twoBartlomiej Sieka
Revert commit 87c8431f and fix build breakage so that the build continues to work on FC systems. Signed-off-by: Bartlomiej Sieka <tur@semihalf.com>
2008-03-27new-image: Fix host tool build breakageHaavard Skinnemoen
Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
2007-11-26Cleanup coding style; update CHANGELOGWolfgang Denk
2007-11-21Update libfdt from device tree compiler (dtc)Kumar Gala
Update libfdt to commit 8eaf5e358366017aa2e846c5038d1aa19958314e from the device tree compiler (dtc) project. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-04-06libfdt: Make fdt_check_header() publicGerald Van Baren
Changed _fdt_check_header() to fdt_check_header() and made it part of the interface - it is a useful routine. Also did some asthetics cleanup to the include files (headers).
2007-04-04Minor cleanup.Wolfgang Denk
2007-03-31libfdt: Import libfdt source (1 of 2)Gerald Van Baren
This adds the applicable libfdt source files (unmodified) and a README to explain where the source came from.
