path: root/include/ext4fs.h
2012-10-03ext4: Rename block group descriptor table from gd to bgdSimon Glass
On x86 machines gd is unfortunately a #define, so we should avoid using gd for anything. This patch changes uses of gd to bgd so that ext4fs can be used on x86. A better fix would be to remove the #define in x86, but I'm not sure how to do that. Signed-off-by: Simon Glass <sjg@chromium.org>
2012-09-25cmd_extX: use common get_device_and_partition functionRob Herring
Convert ext2/4 load, ls, and write functions to use common device and partition parsing function. With the common function "dev:part" can come from the environment and a '-' can be used in that case. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2012-09-25ext4: remove init_fs/deinit_fsRob Herring
There's no real need to expose this and it can be removed by using a static allocation. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2012-08-09ext4fs write supportUma Shankar
Signed-off-by: Uma Shankar <uma.shankar@samsung.com> Signed-off-by: Manjunatha C Achar <a.manjunatha@samsung.com> Signed-off-by: Iqbal Shareef <iqbal.ams@samsung.com> Signed-off-by: Hakgoo Lee <goodguy.lee@samsung.com>
2012-08-09ext4fs ls load supportUma Shankar
