path: root/include/exports.h
2008-07-01Make setenv() return statusSteven A. Falco
Currently, the setenv function does not return an error code. This patch allows to test for errors. Signed-off-by: Steve Falco <sfalco@harris.com>
2007-08-10[ARM] TI DaVinci support, hopefully finalSergey Kubushyn
Add support for the following DaVinci boards: - DV_EVM - SCHMOOGIE - SONATA Changes: - Split into separate board directories - Removed changes to MTD_DEBUG (or whatever it's called) - New CONFIG_CMD party line followed - Some cosmetic fixes, cleanup etc. - Patches against the latest U-Boot tree as of now. - Fixed CONFIG_CMD_NET in net files. - Fixed CONFIG_CMD_EEPROM for schmoogie. - Made sure it compiles and works (forceenv() link problem) on SCHMOOGIE and DV_EVM. Can't check if it works on SONATA, don't have a board any more, but it at least compiles. Here is an excerpt from session log on SCHMOOGIE... U-Boot 1.2.0-g6c33c785-dirty (Aug 7 2007 - 13:07:17) DRAM: 128 MB NAND: 128 MiB In: serial Out: serial Err: serial ARM Clock : 297MHz DDR Clock : 162MHz ETH PHY : DP83848 @ 0x01 U-Boot > iprobe Valid chip addresses: 1B 38 3A 3D 3F 50 5D 6F U-Boot > ping 192.168.253.10 host 192.168.253.10 is alive U-Boot > Signed-off-by: Sergey Kubushyn <ksi@koi8.net> Acked-by: Dirk Behme <dirk.behme@gmail.com> Acked-by: Zach Sadecki <Zach.Sadecki@ripcode.com> Acked-by: Stefan Roese <sr@denx.de>
2007-08-06Add functions to list of exported functionsMartin Krause
Additionally export the following fuctions (to make trab_config build again): - simple_strtol() - strcmp() Also bump the ABI version to reflect this change Signed-off-by: Martin Krause <martin.krause@tqs.de>
2007-07-10cpu/ rtc/ include/: Remove lingering references to CFG_CMD_* symbols.Jon Loeliger
2007-07-09include/: Remove obsolete references to CONFIG_COMMANDSJon Loeliger
Mostly removed from comments here. Signed-off-by: Jon Loeliger <jdl@freescale.com>
2007-07-04include/ non-config: Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2006-09-01Added simple_strtoul(), getenv() and setenv() to the exported functions.Detlev Zundel
Also bumped up ABI version to reflect this change.
2003-09-12Move TRAB burn-in tests to TRAB board directoryLABEL_2003_09_12_1745wdenk
2003-09-11* Patch by Martin Krause, 11 Sep 2003:LABEL_2003_09_12_0110wdenk
add burn-in tests for TRAB board * Enable instruction cache on MPC5200 board
2003-07-26* Allow crc32 to be used at address 0x000wdenk
* Provide consistent interface to standalone applications to access the 'global_data' structure Provide a doc/README.standalone more useful to users/developers. * Make IceCube MGT5100 FEC driver work
2003-07-24* Implement new mechanism to export U-Boot's functions to standalonewdenk
applications: instead of using (PPC-specific) system calls we now use a jump table; please see doc/README.standalone for details * Patch by Dave Westwood, 24 Jul 2003: added support for Unity OS (a proprietary OS)
