path: root/include/ethsw.h
2016-01-28drivers: net: vsc9953: Add LAG supportCodrin Ciubotariu
You can now configure LAG on VSC9953's ports using the command: ethsw [port <port_no>] aggr {[help] | show | <lag_group_no>} A port must belong to a single LAG. By default, a port belongs to a LAG equal to the port's number. For each frame, a hash will be calculated based on Source/Destination MAC addresses, Source/Destination IP(v4/v6) addresses, Source/Destination ports. This hash will be used to select a single egress port from LAG. This also assures that frames from the same flow will always have the same egress port. Signed-off-by: Codrin Ciubotariu <codrin.ciubotariu@freescale.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2015-09-21drivers/net/vsc9953: Add commands for VLAN ingress filteringCodrin Ciubotariu
The command: ethsw [port <port_no>] ingress filtering { [help] | show | enable | disable } - enable/disable VLAN ingress filtering on port can be used to enable/disable/show VLAN ingress filtering on a port. This command has also been added to the ethsw generic parser from common/cmd_ethsw.c Signed-off-by: Johnson Leung <johnson.leung@freescale.com> Signed-off-by: Codrin Ciubotariu <codrin.ciubotariu@freescale.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-09-21drivers/net/vsc9953: Add command for shared/private VLAN learningCodrin Ciubotariu
The command: ethsw vlan fdb { [help] | show | shared | private } - make VLAN learning shared or private" configures the FDB to share the FDB entries learned on multiple VLANs or to keep them separated. By default, the FBD uses private VLAN learning. This command has also been added to the ethsw generic parser from common/cmd_ethsw.c Signed-off-by: Johnson Leung <johnson.leung@freescale.com> Signed-off-by: Codrin Ciubotariu <codrin.ciubotariu@freescale.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-09-21drivers/net/vsc9953: Add VLAN commands for VSC9953Codrin Ciubotariu
The new added commands can be used to configure VLANs for a port on both ingress and egress. The new commands are: ethsw [port <port_no>] pvid { [help] | show | <pvid> } - set/show PVID (ingress and egress VLAN tagging) for a port; ethsw [port <port_no>] vlan { [help] | show | add <vid> | del <vid> } - add a VLAN to a port (VLAN members); ethsw [port <port_no>] untagged { [help] | show | all | none | pvid } - set egress tagging mod for a port" ethsw [port <port_no>] egress tag { [help] | show | pvid | classified } - Configure VID source for egress tag. Tag's VID could be the frame's classified VID or the PVID of the port These commands have also been added to the ethsw generic parser from common/cmd_ethsw.c Signed-off-by: Johnson Leung <johnson.leung@freescale.com> Signed-off-by: Codrin Ciubotariu <codrin.ciubotariu@freescale.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-09-21drivers/net/vsc9953: Add commands to manipulate the FDB for VSC9953Codrin Ciubotariu
The new command: ethsw [port <port_no>] [vlan <vid>] fdb { [help] | show | flush | { add | del } <mac> } Can be used to add and delete FDB entries. Also, the command can be used to show entries from the FDB tables. When used with [port <port_no>] and [vlan <vid>], only the matching the FDB entries can be seen or flushed. The command has also been added to the generic ethsw parser from cmd_ethsw.c. Signed-off-by: Johnson Leung <johnson.leung@freescale.com> Signed-off-by: Codrin Ciubotariu <codrin.ciubotariu@freescale.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-09-21drivers/net/vsc9953: Add commands to enable/disable HW learningCodrin Ciubotariu
The command: ethsw [port <port_no>] learning { [help] | show | auto | disable } can be used to enable/disable HW learning on a port. This patch also adds this command to the generic ethsw parser from cmd_ethsw. Signed-off-by: Johnson Leung <johnson.leung@freescale.com> Signed-off-by: Codrin Ciubotariu <codrin.ciubotariu@freescale.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-09-21drivers/net/vsc9953: Add command to show/clear port countersCodrin Ciubotariu
The new added command: ethsw [port <port_no>] statistics { [help] | [clear] } will print counters like the number of Rx/Tx frames, number of Rx/Tx bytes, number of Rx/Tx unicast frames, etc. This patch also adds this commnd in the genereric ethsw parser from cmd_ethsw.c Signed-off-by: Codrin Ciubotariu <codrin.ciubotariu@freescale.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-09-21common/cmd_ethsw: Add generic commands for Ethernet SwitchesCodrin Ciubotariu
This patch creates a flexible parser for Ethernet Switch configurations that should support complex commands. The parser searches for predefined keywords in the command and calls the proper function when a match is found. Also, the parser allows for optional keywords, such as "port", to apply the command on a port or on all ports. For now, the defined commands are: ethsw [port <port_no>] { enable | disable | show } Signed-off-by: Codrin Ciubotariu <codrin.ciubotariu@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
