path: root/include/errno.h
2016-09-23treewide: replace #include <asm-generic/errno.h> with <linux/errno.h>Masahiro Yamada
Now, include/linux/errno.h is a wrapper of <asm-generic/errno.h>. Replace all include directives for <asm-generic/errno.h> with <linux/errno.h>. <asm-generic/...> is supposed to be included from <asm/...> when arch-headers fall back into generic implementation. Generally, they should not be directly included from .c files. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> [trini: Add drivers/usb/host/xhci-rockchip.c] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-07-05errno: Allow errno_str() to be used without CONFIG_ERRNO_STRSimon Glass
The pmic framework uses errno_str() and this requires board that use it to enable CONFIG_ERRNO_STR to avoid a build error. Update the header to provide a NULL error message when CONFIG_ERRNO_STR is not defined, and fix the build error. This will show as "(null)" when U-Boot prints it. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-07-05errno: Add copyright header and header guardSimon Glass
Bring in a copyright for this file from cmd/pmic.c since this file was submitted by the same author at around the same time. Also fix the missing header guard. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2014-12-11lib: errno: introduce errno_str(): returns errno related messagePrzemyslaw Marczak
The functions error's numbers are standarized - but the error messages are not. The errors are often handled with unclear error messages, so why not use an errno standarized messages. Advantages: - This could decrease the binary size. - Appended with a detailed information, the error message will be clear. This commit introduces new function: - const char *errno_to_str(int errno) The functions returns a pointer to the errno corresponding text message: - if errno is null or positive number - a pointer to "Success" message - if errno is negative - a pointer to errno related message Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Reviewed-by: Tom Rini <trini@ti.com>
2010-09-19Add basic errno support.Wolfgang Denk
Needed for hash table support; probably useful in a lot of other places as well. Signed-off-by: Wolfgang Denk <wd@denx.de>
