common/env_common.c (default_env): new function that resets the environment to
the default value
common/env_common.c (env_relocate): use default_env instead of own copy
common/env_nand.c (env_relocate_spec): use default_env instead of own copy
include/environment.h: added default_env prototype
Signed-off-by: Werner Almesberger <werner@openmoko.org>
Signed-off-by: Harald Welte <laforge@openmoko.org>
This avoids an early global data reference.
Signed-off-by: Joakim Tjernlund <Joakim.Tjernlund@transmode.se>
env_get_char is not a function, but a pointer to one.
The envcrc.c does sizeof(unsigned long) when calculating the crc, but
this is done with the build toolchain instead of the target tool
chain, so if the build is a 64bit system but the target is 32bits,
the size will obviously be wrong. This converts all unsigned long
stuff related to crc32 to uint32_t types. Compile tested only: output
of ./tools/envcrc when run on a 32bit build system matches that of a
64bit build system.
Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
The current NAND Bootloader setup forces the environment
variables to be in line with the bootloader. This change
enables the configuration to be made in the board include
file instead so that it can be individually enabled.
Signed-off-by: Nick Spence <nick.spence@freescale.com>
Patch by Stefan Roese, 12 Sep 2006
Cleanup compiler warning
