path: root/include/environment.h
2016-10-06Various, accumulated typos collected from around the tree.Robert P. J. Day
Fix various misspellings of: * deprecated * partition * preceding,preceded * preparation * its versus it's * export * existing * scenario * redundant * remaining * value * architecture Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Reviewed-by: Jagan Teki <jteki@openedev.com> Reviewed-by: Stefan Roese <sr@denx.de>
2014-08-01env_mmc: support env partition setup in runtimeDmitry Lifshitz
Add callback with __weak annotation to allow setup of environment partition number in runtime from a board file. Propagate mmc_switch_part() return value into init_mmc_for_env() instead of -1 in case of failure. Signed-off-by: Dmitry Lifshitz <lifshitz@compulab.co.il> Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Acked-by: Pantelis Antoniou <panto@antoniou-consulting.com>
2014-08-01env_mmc: add mmc_get_env_addr() prototypeDmitry Lifshitz
Add missing mmc_get_env_addr() prototype in environment.h Signed-off-by: Dmitry Lifshitz <lifshitz@compulab.co.il> Acked-by: Pantelis Antoniou <panto@antoniou-consulting.com>
2014-03-21env: Implement support for encrypting environmentMarek Vasut
Add function which allows encrypting the whole environment block with AES-128-CBC. The key for the environment is retrieved by env_aes_cbc_get_key() function, which must be implemented on a per-board basis. Signed-off-by: Marek Vasut <marex@denx.de>
2014-03-21env: Add env_export() wrapperMarek Vasut
Implement env_export() wrapper, so that all implementers of saveenv() don't have to call hexport_r(), crc32() etc. sequence . This trims down a bit of code duplication. Signed-off-by: Marek Vasut <marex@denx.de>
2013-06-13mmc: fix env in mmc with redundant compile errorBo Shen
The commit d196bd8 (env_mmc: add support for redundant environment) introduce the following compile error when enable redundant environment support with MMC ---8<--- env_mmc.c:149: error: 'env_t' has no member named 'flags' env_mmc.c:248: error: 'env_t' has no member named 'flags' env_mmc.c:248: error: 'env_t' has no member named 'flags' env_mmc.c:250: error: 'env_t' has no member named 'flags' env_mmc.c:250: error: 'env_t' has no member named 'flags' env_mmc.c:252: error: 'env_t' has no member named 'flags' env_mmc.c:252: error: 'env_t' has no member named 'flags' env_mmc.c:254: error: 'env_t' has no member named 'flags' env_mmc.c:254: error: 'env_t' has no member named 'flags' env_mmc.c:267: error: 'env_t' has no member named 'flags' make[1]: *** [env_mmc.o] Error 1 --->8--- Add this patch to fix it Signed-off-by: Bo Shen <voice.shen@atmel.com> Reviewed-by: Michael Heimpold <mhei@heimpold.de> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-04-11env: Add redundant env support to UBI envJoe Hershberger
Allow the user to specify two UBI volumes to use for the environment Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2013-04-11env: Add support for UBI environmentJoe Hershberger
UBI is a better place for the environment on NAND devices because it handles wear-leveling and bad blocks. Gluebi is needed in Linux to access the env as an MTD partition. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2012-12-13env: Add support for access control to .flagsJoe Hershberger
Add support for read-only, write-once, and change-default. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2012-12-13env: Add environment variable flagsJoe Hershberger
Currently just validates variable types as decimal, hexidecimal, boolean, ip address, and mac address. If the entry is not found in the env ".flags", then look in the static one. This allows the env to override the static definitions, but prevents the need to have every definition in the environment distracting you. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2012-12-13env: Add support for callbacks to environment varsJoe Hershberger
Add support for per-variable callbacks to the "hashtable" functions. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> !!!fix comment in callback
2012-12-13env: Refactor apply into change_okJoe Hershberger
Move the read of the old value to inside the check function. In some cases it can be avoided all together and at the least the code is only called from one place. Also name the function and the callback to more clearly describe what it does. Pass the ENTRY instead of just the name for direct access to the whole data structure. Pass an enum to the callback that specifies the operation being approved. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2012-09-18env: make "env default" selective, check and applyGerlando Falauto
Change the syntax (user API) for "env default": -f: override write-once variables var... : accept individual variable(s) -a: all (resetting the whole env is NOT the default behavior) Enable variable checking and make changes effective by enabling do_apply argument to himport_r(). Signed-off-by: Gerlando Falauto <gerlando.falauto@keymile.com>
2012-09-18env: add check/apply logic to himport_r()Gerlando Falauto
Change hashtable so that a callback function will decide whether a variable can be overwritten, and possibly apply the changes. So add a new field to struct hsearch_data: o "apply" callback function to check whether a variable can be overwritten, and possibly immediately apply the changes; when NULL, no check is performed. And a new argument to himport_r(): o "do_apply": whether to call the apply callback function NOTE: This patch does not change the current behavior. Signed-off-by: Gerlando Falauto <gerlando.falauto@keymile.com> Reviewed-by: Marek Vasut <marex@denx.de>
2012-06-21Block: Remove MG DISK supportMarek Vasut
This driver is unused and obsolete. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: unsik Kim <donari75@gmail.com>
2012-01-05env: remove value from boolean definesIgor Grinberg
Several boolean defines have a value assigned. Remove the value as defining the symbol is enough. Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Acked-by: Marek Vasut <marek.vasut@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-11-22env: clean env_common.c checkpatch and code styleIgor Grinberg
Cleanup the env_common.c checkpatch warnings, errors and coding style. Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
2011-11-22env: clean cmd_nvedit.c checkpatch and code styleIgor Grinberg
Cleanup the cmd_nvedit.c checkpatch warnings, errors and coding style. There are 10 wanrings left about the simple_strtoul() function: WARNING: simple_strtoul is obsolete, use kstrtoul instead #359: FILE: cmd_nvedit.c:359: + load_addr = simple_strtoul(argv[2], NULL, 16); ... total: 0 errors, 10 warnings, 1043 lines checked Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
2011-11-22env: move extern environment[] to environment.hIgor Grinberg
Extract all extern declarations for environment out of c files into the environment.h header. Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
2011-11-22env: move extern default_environment[] to environment.hIgor Grinberg
Extract all extern declarations for default_environment[] out of c files into the environment.h header. Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Cc: Stefan Roese <sr@denx.de> Acked-by: Stefan Roese <sr@denx.de>
2011-11-22env: clean environment.h checkpatch and code styleIgor Grinberg
Though one warning left: WARNING: do not add new typedefs #149: FILE: u-boot/include/environment.h:149: +typedef struct environment_s { total: 0 errors, 1 warnings, 181 lines checked Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
2011-08-01environment.h: fix warning: "CONFIG_ENV_IS_EMBEDDED" redefinedWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Stefan Roese <sr@denx.de>
2011-07-26constify default envMike Frysinger
I can't see any obvious needs for the default environment to be writable, so make it const. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-02-15add checking the CONFIG_ENV_IS_IN_SPI_FLASH in Enbedded envYoshihiro Shimoda
Fix the problem which cannot build the U-boot, if we only set the CONFIG_ENV_IS_IN_SPI_FLASH. Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com> Acked-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2010-12-17hashtable: drop all non-reentrant versionsMike Frysinger
The non-reentrant versions of the hashtable functions operate on a single shared hashtable. So if two different people try using these funcs for two different purposes, they'll cause problems for the other. Avoid this by converting all existing hashtable consumers over to the reentrant versions and then punting the non-reentrant ones. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-09-19New implementation for internal handling of environment variables.Wolfgang Denk
Motivation: * Old environment code used a pessimizing implementation: - variable lookup used linear search => slow - changed/added variables were added at the end, i. e. most frequently used variables had the slowest access times => slow - each setenv() would calculate the CRC32 checksum over the whole environment block => slow * "redundant" envrionment was locked down to two copies * No easy way to implement features like "reset to factory defaults", or to select one out of several pre-defined (previously saved) sets of environment settings ("profiles") * No easy way to import or export environment settings ====================================================================== API Changes: - Variable names starting with '#' are no longer allowed I didn't find any such variable names being used; it is highly recommended to follow standard conventions and start variable names with an alphanumeric character - "printenv" will now print a backslash at the end of all but the last lines of a multi-line variable value. Multi-line variables have never been formally defined, allthough there is no reason not to use them. Now we define rules how to deal with them, allowing for import and export. - Function forceenv() and the related code in saveenv() was removed. At the moment this is causing build problems for the only user of this code (schmoogie - which has no entry in MAINTAINERS); may be fixed later by implementing the "env set -f" feature. Inconsistencies: - "printenv" will '\\'-escape the '\n' in multi-line variables, while "printenv var" will not do that. ====================================================================== Advantages: - "printenv" output much better readable (sorted) - faster! - extendable (additional variable properties can be added) - new, powerful features like "factory reset" or easy switching between several different environment settings ("profiles") Disadvantages: - Image size grows by typically 5...7 KiB (might shrink a bit again on systems with redundant environment with a following patch series) ====================================================================== Implemented: - env command with subcommands: - env print [arg ...] same as "printenv": print environment - env set [-f] name [arg ...] same as "setenv": set (and delete) environment variables ["-f" - force setting even for read-only variables - not implemented yet.] - end delete [-f] name not implemented yet ["-f" - force delete even for read-only variables] - env save same as "saveenv": save environment - env export [-t | -b | -c] addr [size] export internal representation (hash table) in formats usable for persistent storage or processing: -t: export as text format; if size is given, data will be padded with '\0' bytes; if not, one terminating '\0' will be added (which is included in the "filesize" setting so you can for exmple copy this to flash and keep the termination). -b: export as binary format (name=value pairs separated by '\0', list end marked by double "\0\0") -c: export as checksum protected environment format as used for example by "saveenv" command addr: memory address where environment gets stored size: size of output buffer With "-c" and size is NOT given, then the export command will format the data as currently used for the persistent storage, i. e. it will use CONFIG_ENV_SECT_SIZE as output block size and prepend a valid CRC32 checksum and, in case of resundant environment, a "current" redundancy flag. If size is given, this value will be used instead of CONFIG_ENV_SECT_SIZE; again, CRC32 checksum and redundancy flag will be inserted. With "-b" and "-t", always only the real data (including a terminating '\0' byte) will be written; here the optional size argument will be used to make sure not to overflow the user provided buffer; the command will abort if the size is not sufficient. Any remainign space will be '\0' padded. On successful return, the variable "filesize" will be set. Note that filesize includes the trailing/terminating '\0' byte(s). Usage szenario: create a text snapshot/backup of the current settings: => env export -t 100000 => era ${backup_addr} +${filesize} => cp.b 100000 ${backup_addr} ${filesize} Re-import this snapshot, deleting all other settings: => env import -d -t ${backup_addr} - env import [-d] [-t | -b | -c] addr [size] import external format (text or binary) into hash table, optionally deleting existing values: -d: delete existing environment before importing; otherwise overwrite / append to existion definitions -t: assume text format; either "size" must be given or the text data must be '\0' terminated -b: assume binary format ('\0' separated, "\0\0" terminated) -c: assume checksum protected environment format addr: memory address to read from size: length of input data; if missing, proper '\0' termination is mandatory - env default -f reset default environment: drop all environment settings and load default environment - env ask name [message] [size] same as "askenv": ask for environment variable - env edit name same as "editenv": edit environment variable - env run same as "run": run commands in an environment variable ====================================================================== TODO: - drop default env as implemented now; provide a text file based initialization instead (eventually using several text files to incrementally build it from common blocks) and a tool to convert it into a binary blob / object file. - It would be nice if we could add wildcard support for environment variables; this is needed for variable name auto-completion, but it would also be nice to be able to say "printenv ip*" or "printenv *addr*" - Some boards don't link any more due to the grown code size: DU405, canyonlands, sequoia, socrates. => cc: Matthias Fuchs <matthias.fuchs@esd-electronics.com>, Stefan Roese <sr@denx.de>, Heiko Schocher <hs@denx.de> - Dropping forceenv() causes build problems on schmoogie => cc: Sergey Kubushyn <ksi@koi8.net> - Build tested on PPC and ARM only; runtime tested with NOR and NAND flash only => needs testing!! Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Matthias Fuchs <matthias.fuchs@esd-electronics.com>, Cc: Stefan Roese <sr@denx.de>, Cc: Heiko Schocher <hs@denx.de> Cc: Sergey Kubushyn <ksi@koi8.net>
2010-07-12NAND: environment offset in OOB (CONFIG_ENV_OFFSET_OOB)Ben Gardiner
This is a re-submission of the patch by Harald Welte <laforge@openmoko.org> with minor modifications for rebase and changes as suggested by Scott Wood <scottwood@freescale.com> [1] [2]. This patch enables the environment partition to have a run-time dynamic location (offset) in the NAND flash. The reason for this is simply that all NAND flashes have factory-default bad blocks, and a fixed compile time offset would mean that sometimes the environment partition would live inside factory bad blocks. Since the number of factory default blocks can be quite high (easily 1.3MBytes in current standard components), it is not economic to keep that many spare blocks inside the environment partition. With this patch and CONFIG_ENV_OFFSET_OOB enabled, the location of the environment partition is stored in the out-of-band (OOB) data of the first block in flash. Since the first block is where most systems boot from, the vendors guarantee that the first block is not a factory default block. This patch introduces the 'nand env.oob' command, which can be called from the u-boot command line. 'nand env.oob get' reads the address of the environment partition from the OOB data, 'nand env.oob set {offset,partition-name}' allows the setting of the marker by specifying a numeric offset or a partition name. [1] http://article.gmane.org/gmane.comp.boot-loaders.u-boot/43916 [2] http://article.gmane.org/gmane.comp.boot-loaders.u-boot/79195 Signed-off-by: Ben Gardiner <bengardiner@nanometrics.ca> Acked-by: Harald Welte <laforge@gnumonks.org>
2010-07-04Redundant environment: move flag definitions to header fileWolfgang Denk
Instead of defining the flags sevaral times in different source files (which is error prone), move them to a central place in a header file. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-08-25unify {CONFIG_,}ENV_IS_EMBEDDEDMike Frysinger
Some boards have fallen out of sync by defining CONFIG_ENV_IS_EMBEDDED manually. While it is useful to have this available to the build system, let's do it automatically rather than forcing people to opt into it. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Albin Tonnerre <albin.tonnerre@free-electrons.com> Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-07-19compiler.h: unify system ifdef cruft hereMike Frysinger
Shove a lot of the HOSTCC and related #ifdef checking crap into the new compiler.h header so that we can keep all other headers nice and clean. Also introduce custom uswap functions so we don't have to rely on the non standard implementations that a host may (or may not in the case of OS X) provide. This allows mkimage to finally build cleanly on an OS X system. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-04-03mflash: Initial mflash supportunsik Kim
Mflash is fusion memory device mainly targeted consumer eletronic and mobile phone. Internally, it have nand flash and other hardware logics and supports some different operation (ATA, IO, XIP) modes. IO mode is custom mode for the host that doesn't have IDE interface. (Many mobile targeted SoC doesn't have IDE bus) This driver support mflash IO mode. Followings are brief descriptions about IO mode. 1. IO mode based on ATA protocol and uses some custom command. (read confirm, write confirm) 2. IO mode uses SRAM bus interface. Signed-off-by: unsik Kim <donari75@gmail.com>
2008-09-10rename CFG_ENV_IS_IN_NAND in CONFIG_ENV_IS_IN_NANDJean-Christophe PLAGNIOL-VILLARD
2008-07-10Remove code duplication for setting the default environmentHarald Welte
common/env_common.c (default_env): new function that resets the environment to the default value common/env_common.c (env_relocate): use default_env instead of own copy common/env_nand.c (env_relocate_spec): use default_env instead of own copy include/environment.h: added default_env prototype Signed-off-by: Werner Almesberger <werner@openmoko.org> Signed-off-by: Harald Welte <laforge@openmoko.org>
2008-07-09Change env_get_char from a global function ptr to a functionJoakim Tjernlund
This avoids an early global data reference. Signed-off-by: Joakim Tjernlund <Joakim.Tjernlund@transmode.se>
2008-05-14environment: fix bug introduced by commit a8409f4f1ac8Wolfgang Denk
env_get_char is not a function, but a pointer to one. Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-05-14environment: cleanup prototype declarations of env functions.Wolfgang Denk
2008-04-24crc32: use uint32_t rather than unsigned longMike Frysinger
The envcrc.c does sizeof(unsigned long) when calculating the crc, but this is done with the build toolchain instead of the target tool chain, so if the build is a 64bit system but the target is 32bits, the size will obviously be wrong. This converts all unsigned long stuff related to crc32 to uint32_t types. Compile tested only: output of ./tools/envcrc when run on a 32bit build system matches that of a 64bit build system. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2006-11-27[PATCH] Select NAND embedded environment from board configurationStefan Roese
The current NAND Bootloader setup forces the environment variables to be in line with the bootloader. This change enables the configuration to be made in the board include file instead so that it can be individually enabled. Signed-off-by: Nick Spence <nick.spence@freescale.com> Signed-off-by: Stefan Roese <sr@denx.de>
2006-09-12Add NAND environment support for PPC440EPx Sequoia NAND boot configStefan Roese
Patch by Stefan Roese, 12 Sep 2006
2006-03-20Support for redundant environment in NAND Flash.Markus Klotzbuecher
2003-03-06Fix problem with default #definesLABEL_2003_03_06_1440wdenk
Cleanup compiler warning
