path: root/include/env_callback.h
2014-07-18env_callback.h: spl: mark callback as maybe_unusedJeroen Hofstee
When static inline is used in a header file the function should preferably be inlined and if not possible made a static function. When declared inside a c file there is a static function, which might be inlined. Since SPL uses a define to declare the static inline it becomes part of the c file although it is declared in a header and clang will warn that you have introduced unused static functions. Add maybe_unused to prevent such warnings. Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
2013-03-27env_callback: Mark find_env_callback as staticTom Rini
This is not called outside of env_callback.c so mark static, remove from <env_callback.h> Cc: Joe Hershberger <joe.hershberger@ni.com> Signed-off-by: Tom Rini <trini@ti.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2013-03-12Refactor linker-generated arraysAlbert ARIBAUD
Refactor linker-generated array code so that symbols which were previously linker-generated are now compiler- generated. This causes relocation records of type R_ARM_ABS32 to become R_ARM_RELATIVE, which makes code which uses LGA able to run before relocation as well as after. Note: this affects more than ARM targets, as linker- lists span possibly all target architectures, notably PowerPC. Conflicts: arch/arm/cpu/arm926ejs/mxs/u-boot-spl.lds arch/arm/cpu/arm926ejs/spear/u-boot-spl.lds arch/arm/cpu/armv7/omap-common/u-boot-spl.lds board/ait/cam_enc_4xx/u-boot-spl.lds board/davinci/da8xxevm/u-boot-spl-da850evm.lds board/davinci/da8xxevm/u-boot-spl-hawk.lds board/vpac270/u-boot-spl.lds Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2013-03-11lcd: implement a callback for splashimageNikita Kiryanov
On some architectures certain values of splashimage will lead to a data abort exception. Document the problem, and implement a callback for splashimage to reject such values. Cc: Anatolij Gustschin <agust@denx.de> Cc: Wolfgang Denk <wd@denx.de> Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2012-12-22env: don't generate callback list entries for SPLScott Wood
SPL doesn't write to the environment. These list entries prevent the functions from being garbage-collected, even though nothing will look at the list. This caused several SPL builds (e.g. P2020RDB-PC_NAND) to break due to size limitations and/or unresolved symbols. A static inline function is used to provide a context in which we can consume the callback, and thus avoid unused function warnings. Signed-off-by: Scott Wood <scottwood@freescale.com> Acked-by: Joe Hershberger <joe.hershberger@gmail.com> Acked-by: Kim Phillips <kim.phillips@freescale.com>
2012-12-13env: Add environment variable flagsJoe Hershberger
Currently just validates variable types as decimal, hexidecimal, boolean, ip address, and mac address. If the entry is not found in the env ".flags", then look in the static one. This allows the env to override the static definitions, but prevents the need to have every definition in the environment distracting you. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2012-12-13env: Add a silent env handlerJoe Hershberger
The silent variable now updates the global data flag anytime it is changed as well as after the env relocation (in case its value is different from the default env in such cases as NAND env) Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2012-12-13env: Add a console env handlerJoe Hershberger
Remove the hard-coded console handler and use a callback instead Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2012-12-13env: Add a loadaddr env handlerJoe Hershberger
Remove the hard-coded loadaddr handler and use a callback instead Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2012-12-13env: Add a baudrate env handlerJoe Hershberger
Remove the hard-coded baudrate handler and use a callback instead Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2012-12-13env: Add a bootfile env handlerJoe Hershberger
Remove the hard-coded bootfile handler and use a callback instead Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2012-12-13env: Add support for callbacks to environment varsJoe Hershberger
Add support for per-variable callbacks to the "hashtable" functions. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> !!!fix comment in callback
