path: root/include/elf.h
2018-08-10elf: Add support for PPC64 ELF V1 ABI in bootelfRob Bracero
This update adds PPC64 ELF V1 ABI support to bootelf for both the program header and section header options. Elf64 support was already present for the program header option, but it was not handling the PPC64 ELF V1 ABI case. For the PPC64 ELF V1 ABI, the e_entry field of the elf header must be treated as function descriptor pointer instead of a function address. The first doubleword of the function descriptor is the function's entry address. Signed-off-by: Rob Bracero <robbracero@gmail.com> [trini: Fix whitespace issues] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-07-25elf: Move x86 reloc defines to common elf.hAlexander Graf
We need to know about x86 relocation definitions even in cases where we don't officially build against the x86 target, such as with sandbox. So let's move the x86 definitions into the common elf header, where all other architectures already have them. Signed-off-by: Alexander Graf <agraf@suse.de>
2018-04-16elf: Add ELF64 related structure definesBin Meng
This adds ELF header, program header and section header structure defines for the 64-bit ELF image. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-04-16elf: Clean up the ELF header fileBin Meng
Fix various style violations in elf.h - use correct comment format if the comment fits in just one line - remove the ending period for the one-line comment - use tab for the indention instead of space - put the opening brace at the same line of a typedef/union - remove <name> in a 'typedef struct' for consistency Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Christian Gmeiner <christian.gmeiner@gmail.com>
2018-01-12riscv: Modify generic codes to support RISC-VRick Chen
Support common commands bdinfo and image format, also modify common generic flow for RISC-V. Signed-off-by: Rick Chen <rick@andestech.com> Signed-off-by: Rick Chen <rickchen36@gmail.com> Signed-off-by: Greentime Hu <green.hu@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-11-14elf: arm: Add a few ARM relocation typesSimon Glass
Rather than hard-coding the relocation type, add it to the ELF header file and use it from there. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Alexander Graf <agraf@suse.de>
2016-10-11elf: Add the Elf64_Rela typeSimon Glass
Add this so that we can support 64-bit relocation on x86. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-08-05elf: Add a few definitions for 64-bit relocationSimon Glass
Provide the types necessary to relocate 64-bit images. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2014-10-25elf: add prototype for valid_elf_imageJeroen Hofstee
Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
2013-08-19SPDX-License-Identifier: convert BSD-3-Clause filesWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> [trini Don't remove some copyrights by accident] Signed-off-by: Tom Rini <trini@ti.com>
2009-07-19compiler.h: unify system ifdef cruft hereMike Frysinger
Shove a lot of the HOSTCC and related #ifdef checking crap into the new compiler.h header so that we can keep all other headers nice and clean. Also introduce custom uswap functions so we don't have to rely on the non standard implementations that a host may (or may not in the case of OS X) provide. This allows mkimage to finally build cleanly on an OS X system. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-04-04elf.h: Use stdint.h to provide standard typedefs for WIN32Peter Tyser
The original code provided an incomplete set of typedefs for WIN32 compiles and replicated the standard typedefs that are already provided by stdint.h Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2003-10-30* Fix parameter passing to standalone images with bootm commandU-Boot-1_0_0wdenk
* Patch by Kyle Harris, 30 Oct 2003: Fix build errors for ixdp425 board * Patch by David M. Horn, 29 Oct 2003: Fixes to build under CYGWIN * Get IceCube MGT5100 working (again)
2003-10-08* Patch by Anders Larsen, 18 Sep 2003:wdenk
allow mkimage to build and run on Cygwin-hosted systems * Patch by Frank Müller, 18 Sep 2003: use bi_intfreq instead of bi_busfreq to compute fec_mii_speed in cpu/mpc8xx/fec.c * Patch by Pantelis Antoniou, 16 Sep 2003: add tool to compute fileds in the PLPRCR register for MPC86x
2002-09-30Initial revisionwdenk
