Measures the DTB passed to the EFI application upon new boolean config
switch CONFIG_EFI_TCG2_PROTOCOL_MEASURE_DTB. For platforms where the
content of the DTB passed to the OS can change across reboots, there is
not point measuring it hence the config switch to allow platform to not
embed this feature.
Co-developed-by: Ilias Apalodimas <ilias.apalodimas@linaro.org>
Signed-off-by: Ilias Apalodimas <ilias.apalodimas@linaro.org>
Signed-off-by: Etienne Carriere <etienne.carriere@linaro.org>
Tested-by: Ilias Apalodimas <ilias.apalodimas@linaro.org>
Reviewed-by: Ilias Apalodimas <ilias.apalodimas@linaro.org>
We support the TCG2 protocol. Allow command efidebug to print it.
Signed-off-by: Heinrich Schuchardt <heinrich.schuchardt@canonical.com>
This commit adds the UEFI GPT disk partition topology
measurement required in TCG PC Client Platform Firmware
Profile Specification
Signed-off-by: Masahisa Kojima <masahisa.kojima@linaro.org>
TCG PC Client Platform Firmware Profile Specification
requires to measure the SMBIOS table that contains static
configuration information (e.g. Platform Manufacturer
Enterprise Number assigned by IANA, platform model number,
Vendor and Device IDs for each SMBIOS table).
The device- and environment-dependent information such as
serial number is cleared to zero or space character for
the measurement.
Existing smbios_string() function returns pointer to the string
with const qualifier, but exisintg use case is updating version
string and const qualifier must be removed.
This commit removes const qualifier from smbios_string()
return value and reuses to clear the strings for the measurement.
This commit also fixes the following compiler warning:
lib/smbios-parser.c:59:39: warning: cast to pointer from integer of
different size [-Wint-to-pointer-cast]
const struct smbios_header *header = (struct smbios_header *)entry->struct_table_address;
TCG EFI Protocol Specification defines the number_of_algorithms
field in spec ID event to be equal to the number of active
algorithms supported by the TPM device. In current implementation,
this field is populated with the count of all algorithms supported
by the TPM which leads to incorrect spec ID event creation.
Similarly, the algorithm array in spec ID event should be a variable
length array with length being equal to the number_of_algorithms field.
In current implementation this is defined as a fixed length array
which has been fixed.
Signed-off-by: Ruchika Gupta <ruchika.gupta@linaro.org>
CC: Masahisa Kojima <masahisa.kojima@linaro.org>
CC: Ilias Apalodimas <ilias.apalodimas@linaro.org>
CC: Heinrich Schuchardt <xypron.glpk@gmx.de>
boot_service_capability_min is constant, it should be capitalized.
Acked-by: Ilias Apalodimas <ilias.apalodimas@linaro.org>
Reviewed-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
TCG EFI Protocol Specification defines that PCRIndex parameter
passed from caller must be 0 to 23.
TPM2_MAX_PCRS is currently used to check the range of PCRIndex,
but TPM2_MAX_PCRS is tpm2 device dependent and may have larger value.
This commit newly adds EFI_TCG2_MAX_PCR_INDEX macro, it is used to
check the range of PCRIndex parameter.
Acked-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
TCG EFI Protocol Specification requires to the input
ProtocolCapability.Size < size of the EFI_TCG2_BOOT_SERVICE_CAPABILITY
up to and including the vendor ID field.
Current implementation does different calculation, let's fix it.
This commit adds the comment of the TCG Specification
efi_tcg2.h file refers, and comment for the structure.
TCG PC Client PFP spec requires to measure the secure
boot policy before validating the UEFI image.
This commit adds the secure boot variable measurement
of "SecureBoot", "PK", "KEK", "db", "dbx", "dbt", and "dbr".
Note that this implementation assumes that secure boot
variables are pre-configured and not be set/updated in runtime.
"TCG PC Client Platform Firmware Profile Specification"
requires to measure every attempt to load and execute
a OS Loader(a UEFI application) into PCR[4].
This commit adds the PE/COFF image measurement, extends PCR,
and appends measurement into Event Log.
Replace CONFIG_HASH_CALCULATE by CONFIG_HASH
Fix conversions between pointers and u64.
In the previous patches we only introduced a minimal subset of the
EFI_TCG2_PROTOCOL protocol implementing GetCapability().
So let's continue adding features to it, introducing the
GetEventLog() and HashLogExtendEvent() functions.
In order to do that we first need to construct the eventlog in memory,
specifically in EFI_BOOT_SERVICES_DATA memory and a configuration table
from EFI_ACPI_MEMORY_NVS.
U-Boot won't currently add any events to the log or measure any
components, but will expose the necessary EFI APIs for applications
to do so.
On pull reuqest
https://lists.denx.de/pipermail/u-boot/2020-November/432735.html
V4 of the patchset was sent instead of the v5.
This is the v4->v5 missing diff
Since U-boot EFI implementation is getting richer it makes sense to
add support for EFI_TCG2_PROTOCOL taking advantage of any hardware TPM
available on the device.
This is the initial implementation of the protocol which only adds
support for GetCapability(). It's limited in the newer and safer
TPMv2 devices.
