path: root/include/efi_selftest.h
2017-10-09efi_loader: supply EFI network testHeinrich Schuchardt
This patch provides an EFI application to check the correct function of the Simple Network Protocol implementation. It sends a DHCP request and analyzes the DHCP offer. Different error conditions including a 10s timeout are checked. A successful execution will look like this: => bootefi nettest Scanning disk ide.blk#0... Found 1 disks WARNING: Invalid device tree, expect boot to fail Network test DHCP Discover DHCP reply received from 192.168.76.2 (52:55:c0:a8:4c:02) as broadcast message. OK. The test was completed successfully. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Alexander Graf <agraf@suse.de>
2017-10-09efi_selftest: correct definition of efi_st_errorHeinrich Schuchardt
Enclose definition in parantheses to allow using efi_st_error like a void function. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Alexander Graf <agraf@suse.de>
2017-10-09efi_selftest: make tests easier to readHeinrich Schuchardt
Rename counter to more illustrative names. Update notification function description. Simplify notification function. Add comment for arbitrary non-zero value. Document @return. Use constants for return values of setup, execute, teardown. Reported-by: Simon Glass <sjg@chromium.org> Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Alexander Graf <agraf@suse.de>
2017-09-18efi_selftest: provide an EFI selftest applicationHeinrich Schuchardt
A testing framework for the EFI API is provided. It can be executed with the 'bootefi selftest' command. It is coded in a way that at a later stage we may turn it into a standalone EFI application. The current build system does not allow this yet. All tests use a driver model and are run in three phases: setup, execute, teardown. A test may be setup and executed at boottime, it may be setup at boottime and executed at runtime, or it may be setup and executed at runtime. After executing all tests the system is reset. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
