eficonfig_append_menu_entryi() accepts the number of entries
less than or equal to EFICONFIG_ENTRY_NUM_MAX.
EFICONFIG_ENTRY_NUM_MAX is currently set as INT_MAX, so
the invalid menu count check(efi_menu->count > EFICONFIG_ENTRY_NUM_MAX)
in eficonfig_process_common() is always false.
This commit sets EFICONFIG_ENTRY_NUM_MAX to (INT_MAX - 1).
Reported-by: Coverity (CID 435659)
Signed-off-by: Masahisa Kojima <masahisa.kojima@linaro.org>
Reviewed-by: Heinrich Schuchardt <heinrich.schuchardt@canonical.com>
Current eficonfig has the maximum number of menu entries and
it is 99. If there are more EFI load options and files in the
system, eficonfig can not handle it.
This commit increases this maximum number of menu entries
to INT_MAX.
Reviewed-by: Ilias Apalodimas <ilias.apalodimas@linaro.org>
The current eficonfig menu does not support vertical scroll,
so it can not display the menu entries greater than
the console row size.
This commit add the vertial scroll support.
The console size is retrieved by
SIMPLE_TEXT_OUTPUT_PROTOCOL.QueryMode() service, then
calculates the row size for menu entry by subtracting
menu header and description row size from the console row size.
"start" and "end" are added in the efimenu structure.
"start" keeps the menu entry index at the top, "end" keeps
the bottom menu entry index. item_data_print() menu function
only draws the menu entry between "start" and "end".
This commit also fixes the issue that "Save" and "Quit"
entries can be moved by BKEY_PLUS in change boot order menu.
Current change boot order implementation does not call
eficonfig_process_common() and call own menu functions
for display_statusline, item_data_print and item_choice.
Change boot order functionality should call
eficonfig_process_common() to improve maintenanceability.
This commit is a preparation to remove the change boot
order specific implementation. The menu functions
(display_statusline, item_data_print and item_choice) are
added as argument of eficonfig_process_common().
The menu description string displayed at the bottom of
the menu is also added as argument.
This commit adds the menu-driven UEFI Secure Boot Key
enrollment interface. User can enroll PK, KEK, db
and dbx by selecting file.
Only the signed EFI Signature List(s) with an authenticated
header, typically '.auth' file, is accepted.
To clear the PK, KEK, db and dbx, user needs to enroll the null key
signed by PK or KEK.
Following commits are adding support for UEFI variable management
via the eficonfig menu. Those functions needs to use
eficonfig_create_device_path() to construct the full device path
from device path of the volume and file path, so move it
out of their static declarations.
append_entry() and append_quit_entry() to construct the
menu, so move them out of their static declarations.
eficonfig_select_file_handler() is commonly used to select the
file. eficonfig_display_select_file_option() adds an additional
menu to clear the selected file.
eficonfig_display_select_file_option() is not always necessary
for the file selection process, so it must be outside of
eficonfig_select_file_handler().
This commit also renames the following functions to avoid confusion.
eficonfig_select_file_handler() -> eficonfig_process_select_file()
eficonfig_select_file() -> eficonfig_show_file_selection()
eficonfig_display_select_file_option() -> eficonfig_process_show_file_option()
Finally, test_eficonfig.py need to be updated to get aligned with
the above modification.
UEFI specification requires booting from removal media using
a architecture-specific default image name such as BOOTAA64.EFI.
This commit adds the removable media entries into bootmenu,
so that user can select the removable media and boot with
default image.
The bootmenu automatically enumerates the possible bootable
media devices supporting EFI_SIMPLE_FILE_SYSTEM_PROTOCOL,
add it as new UEFI boot option(BOOT####) and update BootOrder
variable. This automatically generated UEFI boot option
has the dedicated guid in the optional_data to distinguish it from
the UEFI boot option user adds manually. This optional_data is
removed when the efi bootmgr loads the selected UEFI boot option.
This commit also provides the BOOT#### variable maintenance feature.
Depending on the system hardware setup, some devices
may not exist at a later system boot, so bootmenu checks the
available device in each bootmenu invocation and automatically
removes the BOOT#### variable corrensponding to the non-existent
media device.
This commit adds the menu entry to edit the existing
BOOT#### variable contents.
User selects the item from the boot option list, then
user can edit the description, file path and optional_data.
Note that automatically generated boot option entry by bootmenu
to support the removable media device is filtered out and user
can not edit the automatically generated entry.
This commit add the "eficonfig" command.
The "eficonfig" command implements the menu-driven UEFI boot option
maintenance feature. This commit implements the addition of
new boot option. User can select the block device volume having
efi_simple_file_system_protocol and select the file corresponding
to the Boot#### variable. User can also enter the description and
optional_data of the BOOT#### variable in utf8.
This commit adds "include/efi_config.h", it contains the common
definition to be used from other menus such as UEFI Secure Boot
key management.
