path: root/include/e500.h
2009-01-23Add secondary CPUs processor frequency for e500 coreHaiying Wang
This patch updates e500 freqProcessor to array based on CONFIG_NUM_CPUS, and prints each CPU's frequency separately. It also fixes up each CPU's frequency in "clock-frequency" of fdt blob. Signed-off-by: James Yang <James.Yang@freescale.com> Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com>
2008-12-19mpc8[56]xx: Put localbus clock in sysinfo and gdTrent Piepho
Currently MPC85xx and MPC86xx boards just calculate the localbus frequency and print it out, but don't save it. This changes where its calculated and stored to be more consistent with the CPU, CCB, TB, and DDR frequencies and the MPC83xx localbus clock. The localbus frequency is added to sysinfo and calculated when sysinfo is set up, in cpu/mpc8[56]xx/speed.c, the same as the other frequencies are. get_clocks() copies the frequency into the global data, as the other frequencies are, into a new field that is only enabled for MPC85xx and MPC86xx. checkcpu() in cpu/mpc8[56]xx/cpu.c will print out the local bus frequency from sysinfo, like the other frequencies, instead of calculating it on the spot. Signed-off-by: Trent Piepho <tpiepho@freescale.com> Acked-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Jon Loeliger <jdl@freescale.com>
2008-01-09Reworked FSL Book-E TLB macros to be more readableKumar Gala
The old macros made it difficult to know what WIMGE and perm bits were set for a TLB entry. Actually use the bit masks for these items since they are only a single bit. Also moved the macros into mmu.h out of e500.h since they aren't specific to e500. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-01-09Use FSL Book-E MMU macros from Linux KernelKumar Gala
Grab the FSL Book-E MAS register macros from Linux. Also added defines for page sizes up to 4TB and removed SHAREN since it doesnt really exist. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-12-11Handle Asynchronous DDR clock on 85xxKumar Gala
The MPC8572 introduces the concept of an asynchronous DDR clock with regards to the platform clock. Introduce get_ddr_freq() to report the DDR freq regardless of sync/async mode. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2004-08-01Patch by Jon Loeliger, 16 Jul 2004:wdenk
- support larger DDR memories up to 2G on the PC8540/8560ADS and STXGP3 boards - Made MPC8540/8560ADS be 33Mhz PCI by default. - Removed moldy CONFIG_RAM_AS_FLASH, CFG_FLASH_PORT_WIDTH_16 and CONFIG_L2_INIT_RAM options. - Refactor Local Bus initialization out of SDRAM setup. - Re-implement new version of LBC11/DDR11 errata workarounds. - Moved board specific PCI init parts out of CPU directory. - Added TLB entry for PCI-1 IO Memory - Updated README.mpc85xxads
