path: root/include/e500.h
2008-01-09Reworked FSL Book-E TLB macros to be more readableKumar Gala
The old macros made it difficult to know what WIMGE and perm bits were set for a TLB entry. Actually use the bit masks for these items since they are only a single bit. Also moved the macros into mmu.h out of e500.h since they aren't specific to e500. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-01-09Use FSL Book-E MMU macros from Linux KernelKumar Gala
Grab the FSL Book-E MAS register macros from Linux. Also added defines for page sizes up to 4TB and removed SHAREN since it doesnt really exist. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-12-11Handle Asynchronous DDR clock on 85xxKumar Gala
The MPC8572 introduces the concept of an asynchronous DDR clock with regards to the platform clock. Introduce get_ddr_freq() to report the DDR freq regardless of sync/async mode. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2004-08-01Patch by Jon Loeliger, 16 Jul 2004:wdenk
- support larger DDR memories up to 2G on the PC8540/8560ADS and STXGP3 boards - Made MPC8540/8560ADS be 33Mhz PCI by default. - Removed moldy CONFIG_RAM_AS_FLASH, CFG_FLASH_PORT_WIDTH_16 and CONFIG_L2_INIT_RAM options. - Refactor Local Bus initialization out of SDRAM setup. - Re-implement new version of LBC11/DDR11 errata workarounds. - Moved board specific PCI init parts out of CPU directory. - Added TLB entry for PCI-1 IO Memory - Updated README.mpc85xxads
