path: root/include/dwc3-uboot.h
2020-05-29usb: dwc3: Add disable u2mac linestate check quirkJagan Teki
This patch adds a quirk to disable USB 2.0 MAC linestate check during HS transmit. Refer the dwc3 databook, we can use it for some special platforms if the linestate not reflect the expected line state(J) during transmission. When use this quirk, the controller implements a fixed 40-bit TxEndDelay after the packet is given on UTMI and ignores the linestate during the transmit of a token (during token-to-token and token-to-data IPGAP). On some rockchip platforms (e.g. rk3399), it requires to disable the u2mac linestate check to decrease the SSPLIT token to SETUP token inter-packet delay from 566ns to 466ns, and fix the issue that FS/LS devices not recognized if inserted through USB 3.0 HUB. Reference from below Linux commit, commit <65db7a0c9816> ("usb: dwc3: add disable u2mac linestate check quirk") Cc: Marek Vasut <marex@denx.de> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
2020-05-29usb: dwc3: add dis_u2_freeclk_exists_quirkFrank Wang
Add a quirk to clear the GUSB2PHYCFG.U2_FREECLK_EXISTS bit, which specifies whether the USB2.0 PHY provides a free-running PHY clock, which is active when the clock control input is active. Refer to commit 27f83eeb6b42("usb: dwc3: add dis_u2_freeclk_exists_quirk") in Linux Rockchip Kernel. Signed-off-by: Frank Wang <frank.wang@rock-chips.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com> Reviewed-by: Jagan Teki <jagan@amarulasolutions.com> Tested-by: Jagan Teki <jagan@amarulasolutions.com>
2020-05-29usb: dwc3: add dis_enblslpm_quirkFrank Wang
Add a quirk to clear the GUSB2PHYCFG.ENBLSLPM bit, which controls whether the PHY receives the suspend signal from the controller. Refer to commit ec791d149bca("usb: dwc3: Add dis_enblslpm_quirk") in Linux Kernel. Signed-off-by: Frank Wang <frank.wang@rock-chips.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com> Reviewed-by: Jagan Teki <jagan@amarulasolutions.com> Tested-by: Jagan Teki <jagan@amarulasolutions.com>
2020-05-12usb: dwc3: add dis_del_phy_power_chg_quirkJagan Teki
Add a quirk to clear the GUSB3PIPECTL.DELAYP1TRANS bit, which specifies whether disable delay PHY power change from P0 to P1/P2/P3 when link state changing from U0 to U1/U2/U3 respectively. Reference from below Linux commit, commit <00fe081dc3a3> ("usb: dwc3: add dis_del_phy_power_chg_quirk") Cc: Marek Vasut <marex@denx.de> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2020-05-02usb: dwc3: use the phy bulk API to get physChunfeng Yun
Get a group of phys by the phy bulk API Signed-off-by: Chunfeng Yun <chunfeng.yun@mediatek.com> Signed-off-by: Frank Wunderlich <frank-w@public-files.de> Reviewed-by: Weijie Gao <weijie.gao@mediatek.com>
2019-11-23usb: dwc3: Add phy interface for dwc3_ubootJagan Teki
U-Boot has two different variants of dwc3 initializations, - with dm variant gadget, so the respective dm driver would call the dwc3_init in core. - with non-dm variant gadget, so the usage board file would call dwc3_uboot_init in core. The driver probe would handle all respective gadget properties including phy interface via phy_type property and then trigger dwc3_init for dm-variant gadgets. So, to support the phy interface for non-dm variant gadgets, the better option is dwc3_uboot_init since there is no dedicated controller for non-dm variant gadgets. This patch support for adding phy interface like 8/16-bit UTMI+ code for dwc3_uboot. This change used Linux phy.h enum list, to make proper code compatibility. Cc: Marek Vasut <marex@denx.de> Tested-by: Levin Du <djw@t-chip.com.cn> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Reviewed-by: Marek Vasut <marex@denx.de> Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
2018-12-07dwc3: move phy operation to core.cJean-Jacques Hiblot
Those operations can be used for peripheral operation as well as host operation. Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com> # Conflicts: # drivers/usb/dwc3/core.c # drivers/usb/host/xhci-dwc3.c
2016-06-04usb: dwc3: Correct datatype of base to unsigned longSiva Durga Prasad Paladugu
Correct type of varibale base to unsigned long as keeping it as int causes usb failures if MSB of the base address is set. Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2015-04-14dwc3: core: added an API to invoke irq handlersKishon Vijay Abraham I
Since interrupt support is not present in u-boot, added an API to handle the interrupts in dwc3 core. This API can be polled to handle the interrupts. Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com> Reviewed-by: Lukasz Majewski <l.majewski@samsung.com>
2015-04-14dwc3: core: add support for multiple dwc3 controllersKishon Vijay Abraham I
Added support for multiple dwc3 controllers. This gives uboot the capability to control multiple dwc3 controllers. Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com> Reviewed-by: Lukasz Majewski <l.majewski@samsung.com>
2015-04-14include: dwc3-uboot: add a structure for populating platform dataKishon Vijay Abraham I
Added a structure to populate dwc3 core platform data. The board file should populate these platform data before invoking dwc3 driver. This will be removed once we have dwc3 driver adapted to use the driver model. Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com> Reviewed-by: Lukasz Majewski <l.majewski@samsung.com>
