path: root/include/dtt.h
2011-10-22hwmon: Provide dtt_init()Dirk Eibach
Our boards rely on dtt for initialization of fan hardware. dtt_init() was implemented to be called form board specific code. Signed-off-by: Dirk Eibach <eibach@gdsys.de> Acked-by: Heiko Schocher <hs@denx.de> Tested-by: Heiko Schocher <hs@denx.de>
2011-08-04hwmon: do not init sensors on startupHeiko Schocher
The U-Boot Design Principles[1] clearly say: Initialize devices only when they are needed within U-Boot, i.e. don't initialize the Ethernet interface(s) unless U-Boot performs a download over Ethernet; don't initialize any IDE or USB devices unless U-Boot actually tries to load files from these, etc. (and don't forget to shut down these devices after using them - otherwise nasty things may happen when you try to boot your OS). So, do not initialize and read the sensors on startup. Signed-off-by: Heiko Schocher <hs@denx.de> cc: Wolfgang Denk <wd@denx.de> cc: Holger Brunck <holger.brunck@keymile.com>
2008-10-18hwmon: Add LM63 supportDirk Eibach
This patch adds support for the National LM63 temperature sensor with integrated fan control. It's used on the GDSys Neo board (405EP) which will be submitted later. Signed-off-by: Dirk Eibach <eibach@gdsys.de> Acked-by: Stefan Roese <sr@denx.de>
2008-08-18Minor code cleanup: keep lists sorted.Wolfgang Denk
2008-08-18Add support for ADT7460 I2C monitor chipRicardo Ribalda Delgado
Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@uam.es>
2008-07-13hwmon: Cleaning hwmon devicesMichal Simek
Clean Makefile Move device specific values to driver for better reading Signed-off-by: Michal Simek <monstr@monstr.eu> Acked-by: Stefan Roese <sr@denx.de>
2007-12-27Add driver for National Semiconductor LM73 temperature sensorLarry Johnson
This driver is based on the driver for the LM75. Signed-off-by: Larry Johnson <lrj@acm.org>
2007-07-26ppc4xx: Add support for AMCC 405EP Taihu boardJohn Otken
Signed-off-by: John Otken <john@softadvances.com>
2006-12-21[PATCH] Add support for the UC101 board from MAN.Heiko Schocher
2003-06-19Patches by Murray Jensen, 17 Jun 2003:wdenk
- Hymod board database mods: add "who" field and new xilinx chip types - provide new "init_cmd_timeout()" function so code external to "common/main.c" can use the "reset_cmd_timeout()" function before entering the main loop - add DTT support for adm1021 (new file dtt/adm1021.c; config slightly different. see include/configs/hymod.h for an example (requires CONFIG_DTT_ADM1021, CONFIG_DTT_SENSORS, and CFG_DTT_ADM1021 defined) - add new "eeprom_probe()" function which has similar args and behaves in a similar way to "eeprom_read()" etc. - add 8260 FCC ethernet loopback code (new "eth_loopback_test()" function which is enabled by defining CONFIG_ETHER_LOOPBACK_TEST) - gdbtools copyright update - ensure that set_msr() executes the "sync" and "isync" instructions after the "mtmsr" instruction in cpu/mpc8260/interrupts.c - 8260 I/O ports fix: Open Drain should be set last when configuring - add SIU IRQ defines for 8260 - allow LDSCRIPT override and OBJCFLAGS initialization: change to config.mk to allow board configurations to override the GNU linker script, selected via the LDSCRIPT, make variable, and to give an initial value to the OBJCFLAGS make variable - 8260 i2c enhancement: o correctly extends the timeout depending on the size of all queued messages for both transmit and receive o will not continue with receive if transmit times out o ensures that the error callback is done for all queued tx and rx messages o correctly detects both tx and rx timeouts, only delivers one to the callback, and does not overwrite an earlier error o logic in i2c_probe now correct - add "vprintf()" function so that "panic()" function can be technically correct - many Hymod board changes
