path: root/include/dt-bindings
2020-07-17Merge https://gitlab.denx.de/u-boot/custodians/u-boot-x86Tom Rini
- New timer API to allow delays with a 32-bit microsecond timer - Add dynamic ACPI structs (DSDT/SSDT) generations to the DM core - x86: Enable ACPI table generation by default - x86: Enable the copy framebuffer on Coral - x86: A few fixes to FSP2 with ApolloLake - x86: Drop setup_pcat_compatibility() - x86: Primary-to-Sideband Bus minor fixes
2020-07-17Merge tag 'u-boot-imx-20200716' of ↵Tom Rini
https://gitlab.denx.de/u-boot/custodians/u-boot-imx i.MX for 2020.10 ---------------- - i.MX DDR driver fix/update for i.MX8M - i.MX pinctrl driver fix. - Use arm_smccc_smc to remove imx sip function - i.MX8M clk update - support booting aarch32 kernel on aarch64 hardware - fused part support for i.MX8MP - imx6: pcm058 to DM Travis: https://travis-ci.org/github/sbabic/u-boot-imx/builds/708734785
2020-07-17x86: irq: Support flags for acpi_gpeSimon Glass
This binding currently has a flags cell but it is not used. Make use of it to create ACPI tables for interrupts. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Wolfgang Wallner <wolfgang.wallner@br-automation.com>
2020-07-17x86: Add bindings for NHLTSimon Glass
Add devicetree bindings for the Intel Non-High-Definition-Audio Link Table (NHLT). Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Wolfgang Wallner <wolfgang.wallner@br-automation.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2020-07-14dts-bindings: regulator: Add dlg,da9063-regulatorNiel Fourie
Add da9063-regulator bindings from Linux 5.6: commit 7111951b8d49 upstream Signed-off-by: Niel Fourie <lusus@denx.de> Cc: Stefano Babic <sbabic@denx.de>
2020-07-13arm: dts: k3-am65/j721e: Sync DMA DT bindings from Kernel DTVignesh Raghavendra
Sync DT bindings from kernel DT and move them to out of -u-boot.dtsi files. Signed-off-by: Vignesh Raghavendra <vigneshr@ti.com> Reviewed-by: Grygorii Strashko <grygorii.strashko@ti.com>
2020-07-10reset: Add Raspberry Pi 4 firmware reset controllerNicolas Saenz Julienne
Raspberry Pi 4's co-processor controls some of the board's HW initialization process, but it's up to Linux to trigger it when relevant. Introduce a reset controller capable of interfacing with RPi4's co-processor that models these firmware initialization routines as reset lines. Signed-off-by: Nicolas Saenz Julienne <nsaenzjulienne@suse.de> Signed-off-by: Matthias Brugger <mbrugger@suse.com>
2020-07-01riscv: Add device tree for K210 and Sipeed Maix BitMSean Anderson
Where possible, I have tried to find compatible drivers based on the layout of registers. However, many devices remain untested. All untested devices have been left disabled, but some tentative properties (such as compatible strings, and clocks, interrupts, and resets properties) have been added. Signed-off-by: Sean Anderson <seanga2@gmail.com>
2020-07-01clk: Add K210 clock supportSean Anderson
Due to the large number of clocks, I decided to use the CCF. The overall structure is modeled after the imx code. Clocks parameters are stored in several arrays, and are then instantiated at run-time. There are some translation macros (FOOIFY()) which allow for more dense packing. Signed-off-by: Sean Anderson <seanga2@gmail.com> CC: Lukasz Majewski <lukma@denx.de>
2020-06-16omap5: Copy device tree from linux 5.7.yTero Kristo
Copy all the device tree files required for omap5 uevm support from mainline Linux. Signed-off-by: Tero Kristo <t-kristo@ti.com>
2020-06-16omap4: Copy device tree from Linux 5.7.yTero Kristo
Copy all device tree files required for omap4 panda support from mainline Linux. Signed-off-by: Tero Kristo <t-kristo@ti.com>
2020-05-31dt-bindings: input: adopt Linux gpio-keys binding constantsPeter Robinson
Sync the gpio-keys input bindings from linux 5.7-rc1. Signed-off-by: Peter Robinson <pbrobinson@gmail.com>
2020-05-10dt-bindings: imx_rsrc: add SC_R_NONEPeng Fan
Add SC_R_NONE entry Signed-off-by: Peng Fan <peng.fan@nxp.com>
2020-05-07phy: atheros: add device tree bindings and configMichael Walle
Add support for configuring the CLK_25M pin as well as the RGMII I/O voltage by the device tree. By default the AT803x PHYs outputs the 25MHz clock of the XTAL input. But this output can also be changed by software to other frequencies. This commit introduces a generic way to configure this output. Also the PHY supports different RGMII I/O voltages: 1.5V, 1.8V and 2.5V. An internal LDO is able to provide 1.5V (default) and 1.8V. The 2.5V option needs an external supply voltage. This commit adds support to switch the internal LDO to 1.8V. Signed-off-by: Michael Walle <michael@walle.cc> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2020-05-04Merge tag 'u-boot-imx-20200502' of ↵Tom Rini
https://gitlab.denx.de/u-boot/custodians/u-boot-imx i.MX for 2020.07 ---------------- - imxrt: fix LCD clock, fix doc - new board: Coral Dev - imx8: enable Cache in SPL. SNVS, update SCFW API - imx8MM: fix reset, 8MQ quand and QuadLite, CPU speed grading - MX6ULL : is_imx6ull to include i.MX6ULZ - Net: add config to enable TXC delay Travis: https://travis-ci.org/github/sbabic/u-boot-imx/builds/682033914
2020-05-04Merge tag 'u-boot-rockchip-20200501' of ↵Tom Rini
https://gitlab.denx.de/u-boot/custodians/u-boot-rockchip - dts clean up to use -u-boot for px30, rk3399 boards - dts sycn from upstream kernel for rk3328, rk3399 - add rockchip rng driver - new board support: rk3328-roc-cc, rk3399-roc-pc,Nanopi M4 2GB
2020-05-01dt-bindings: pinctrl: imxrt1020: remove useless commentGiulio Benetti
A comment note has been left after completing pinctrl listing, so let's remove it since it's useless. Signed-off-by: Giulio Benetti <giulio.benetti@benettiengineering.com>
2020-05-01dt-bindings: power: rk3328-power: sync from upstream Linux kernelChen-Yu Tsai
This syncs the rk3328 power domain header file from Linux kernel next-20200324, to support newer hardware blocks when syncing the device tree files. The last non-merge commit to touch it was b24413180f56 ("License cleanup: add SPDX GPL-2.0 license identifier to files with no license") Reviewed-by: Kever Yang <kever.yang@rock-chips.com> Tested-by: Loic Devulder <ldevulder@suse.com> Tested-by: Peter Geis <pgwipeout@gmail.com> Signed-off-by: Chen-Yu Tsai <wens@csie.org>
2020-05-01dt-bindings: clock: rk3328: sync from upstream Linux kernelChen-Yu Tsai
This syncs the rk3328 clock header file from Linux kernel next-20200324, to support newer hardware blocks when syncing the device tree files. The last non-merge commit to touch it was 0dc14b013f79 ("clk: rockchip: add clock id for watchdog pclk on rk3328") Reviewed-by: Kever Yang <kever.yang@rock-chips.com> Tested-by: Loic Devulder <ldevulder@suse.com> Tested-by: Peter Geis <pgwipeout@gmail.com> Signed-off-by: Chen-Yu Tsai <wens@csie.org>
2020-04-29Merge https://gitlab.denx.de/u-boot/custodians/u-boot-shTom Rini
- rmobile gen2/gen3 DTS sync and defconfig consolidation
2020-04-28ARM: dts: rmobile: Synchronize Gen2 DTs with Linux 5.6.2Marek Vasut
Synchronize R-Car Gen2 device trees with Linux 5.6.2, commit 9fbe5c87eaa9b72db08425c52c373eb5f6537a0a . Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2020-04-28Merge tag 'u-boot-amlogic-20200428' of ↵Tom Rini
https://gitlab.denx.de/u-boot/custodians/u-boot-amlogic - fix sd-emmc controller A init on G12A/G12B/SM1 SoCs - add GXBB USB PHY driver - enable access to SPI NOR Flash on VIM2 and VIM3/VIM3L boards - fix USB PHYs Power-Up on on VIM3/VIM3L boards
2020-04-28arm64: dts: meson: sync dt and bindings from v5.7-rc1Neil Armstrong
Sync the device tree and dt-bindings from Linux v5.7-rc1 8f3d9f354286 ("Linux 5.7-rc1"). Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
2020-04-27ARC: HSDK: CGU: add support for timer clockEugeniy Paltsev
Add support for additional timer clock which belongs to tunnel domain. Signed-off-by: Eugeniy Paltsev <Eugeniy.Paltsev@synopsys.com> Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
2020-04-24arm: actions: add S700 SoC device treeAmit Singh Tomar
This patch adds .dtsi file(sync with Linux 5.5-rc6 with hash "b3a987b0264d") and required binding for S700 SoC that is a 64-bit Quad-core ARM Cortex-A53 cores. It also provisions dts file to be built based on selected platform(CONFIG_MACH_S900/S700). Reviewed-by: Manivannan Sadhasivam <manivannan.sadhasivam@linaro.org> Reviewed-by: Andre Przywara <andre.przywara@arm.com> Signed-off-by: Amit Singh Tomar <amittomer25@gmail.com>
2020-04-24arm: dts: sync dts for Action Semi S900Amit Singh Tomar
Synchronize device tree bindings with v5.5-rc6 tag with commit id "b3a987b0264d". Also, it removes older clock binding defined for S900 along with undocumented compatible string "actions,s900-serial" from serial driver and adapts clock driver to cater to new bindings. Reviewed-by: Manivannan Sadhasivam <manivannan.sadhasivam@linaro.org> Reviewed-by: Andre Przywara <andre.przywara@arm.com> Signed-off-by: Amit Singh Tomar <amittomer25@gmail.com>
2020-04-20Merge branch 'master' of https://gitlab.denx.de/u-boot/custodians/u-boot-imxTom Rini
2020-04-18dt-bindings: pinctrl: add i.MXRT1020 pins definitionGiulio Benetti
Add i.MXRT1020 pins definition. Signed-off-by: Giulio Benetti <giulio.benetti@benettiengineering.com>
2020-04-18clk: imx: add i.IMXRT1020 clk driverGiulio Benetti
Add i.MXRT1020 clk driver support. Signed-off-by: Giulio Benetti <giulio.benetti@benettiengineering.com> Reviewed-by: Lukasz Majewski <lukma@denx.de>
2020-04-16gpio: sandbox: cleanup binding supportPatrick Delaunay
Cleanup binding support, use the generic binding by default (test u-class gpio_xlate_offs_flags function) and add specific binding for added value. Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2020-04-16dt-bindings: gpio: document the new pull-up/pull-down flagsPatrick Delaunay
This commit extends the flags that can be used in GPIO specifiers to indicate if a pull-up resistor or pull-down resistor should be enabled. It is the backport of linux commit ede033e1e863c ('dt-bindings: gpio: document the new pull-up/pull-down flags') from Thomas Petazzoni <thomas.petazzoni@bootlin.com> and integrated in v5.1-rc1 https://github.com/torvalds/linux/commit/ede033e1e863c Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2020-04-06arm64: dts: meson: sync dt and bindings from v5.6-rc2Jerome Brunet
Sync the device tree and dt-bindings from Linux v5.6-rc2 11a48a5a18c6 ("Linux 5.6-rc2") The only exception to this is the mmc pinctrl pin bias of gxl SoC family. This is a fix which found its way to u-boot but not Linux yet. Acked-by: Neil Armstrong <narmstrong@baylibre.com> Signed-off-by: Jerome Brunet <jbrunet@baylibre.com> Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
2020-04-06dt-bindings: leds: import common led bindings from linux v5.5Jerome Brunet
Import the common leds bindings definition from linux d5226fa6dbae ("Linux 5.5") Reviewed-by: Neil Armstrong <narmstrong@baylibre.com> Signed-off-by: Jerome Brunet <jbrunet@baylibre.com> Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
2020-03-09ARM: dts: imx6sx: Sync with kernel 5.4.16Fabio Estevam
Sync the imx6sx dts files with kernel 5.4.16. Signed-off-by: Fabio Estevam <festevam@gmail.com>
2020-02-07x86: Add a clock driver for Intel devicesSimon Glass
So far we have avoided adding a clock driver for Intel devices. But the Designware I2C driver needs a different clock (133MHz) on Intel devices than on others (166MHz). Add a simple driver that provides this information. This driver can be expanded later as needed. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2020-01-26Merge branch 'master' of https://gitlab.denx.de/u-boot/custodians/u-boot-sunxiTom Rini
- Libre Computer ALL-H3-IT/ALL-H5-CC board (Chen-Yu Tsai) - Allwinner R40 Ethernet, usb phy enablement (Andre Przywara) - Sunxi auto load from 128KB MMC offset (Andre Przywara) - Orange Pi Win Ethernet phy enablement (Jernej Skrabec)
2020-01-24sunxi: H3/H5 Sync DT files from upstream Linux kernel as of next-20200108Chen-Yu Tsai
Sync the device tree files and device tree header files from upstream Linux kernel, as of 2020-01-08. The commit synced to in the sunxi repo 98d25b0b266d Merge branch 'sunxi/dt-for-5.6' into sunxi/for-next which is also part of next-20200108. Changes brought in include: - cleanup of pinmux node names - addition of Security ID, MBUS, CSI, crypto engine, video codec, pmu, and thermal sensor device nodes for both SoCs - addition of deinterlacing engine device node on H3 - cleanup of RTC device node and addition of its clocks - various board cleanups and improvements - removal of pinmux node for GPIO lines - cpufreq / DVFS - HDMI output - UART-based Bluetooth - audio codec - USB ports - new boards Most of the changes don't concern U-boot. Signed-off-by: Chen-Yu Tsai <wens@csie.org> Reviewed-by: Jagan Teki <jagan@amarulasolutions.com>
2020-01-22arm: dts: Import device tree for ST-Ericsson Ux500Stephan Gerhold
from https://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-stericsson.git/ tag "ux500-armsoc-v5.6-2" commit 224bf0fe7292 ("ARM: dts: ux500: samsung-golden: Add Bluetooth") (queued for merge in Linux 5.6) Signed-off-by: Stephan Gerhold <stephan@gerhold.net> Reviewed-by: Linus Walleij <linus.walleij@linaro.org>
2020-01-16clk: mediatek: add driver for MT7622Sam Shih
This patch add clock driver for MediaTek MT7622 SoC. Signed-off-by: Ryder Lee <ryder.lee@mediatek.com> Signed-off-by: Sam Shih <sam.shih@mediatek.com>
2020-01-16clk: mediatek: add driver support for MT8512mingming lee
Add clock driver for MediaTek MT8512 SoC, include topckgen, apmixedsys and infracfg support. Signed-off-by: mingming lee <mingming.lee@mediatek.com>
2020-01-14ram: add SDRAM driver for i.MXRT SoCsGiulio Benetti
Add SDRAM driver for i.MXRT SoCs. Signed-off-by: Giulio Benetti <giulio.benetti@benettiengineering.com>
2020-01-14ARM: dts: imxrt1050: add dtsi fileGiulio Benetti
Add dtsi file for i.MXRT1050. Signed-off-by: Giulio Benetti <giulio.benetti@benettiengineering.com>
2020-01-14clk: imx: add i.IMXRT1050 clk driverGiulio Benetti
Add i.MXRT1050 clk driver support. Signed-off-by: Giulio Benetti <giulio.benetti@benettiengineering.com>
2020-01-08Merge tag 'u-boot-imx-20200108' of ↵Tom Rini
https://gitlab.denx.de/u-boot/custodians/u-boot-imx --------------------------------------------------------------------- Add i.MX8MP SoC and EVK board Update README for i.MX8MN EVK and fix mmc env Add pca9450 driver -------------------------------------------------------------------- Travis: https://travis-ci.org/sbabic/u-boot-imx/builds/634211885
2020-01-08Merge branch 'master' of git://git.denx.de/u-boot-socfpgaTom Rini
2020-01-08dt-bindings: clock: add i.MX8MP clock headerPeng Fan
Add i.MX8MP clock header Signed-off-by: Peng Fan <peng.fan@nxp.com>
2020-01-07clk: agilex: Add clock driver for AgilexLey Foon Tan
Add clock manager driver for Agilex. Provides clock initialization and get_rate functions. agilex-clock.h is from Linux commit ID cd2e1ad12247. Signed-off-by: Chee Hong Ang <chee.hong.ang@intel.com> Signed-off-by: Ley Foon Tan <ley.foon.tan@intel.com> Reviewed-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
2020-01-07dt-bindings: add imx-audmux macro definitionsBaruch Siach
Import fsl-imx-audmux.h from Linux as of v5.4-rc6. The header is unchanged since v4.18. That would make it easier to import DT files that depend on imx-audmux definitions from the kernel tree. Signed-off-by: Baruch Siach <baruch@tkos.co.il> Reviewed-by: Fabio Estevam <festevam@gmail.com>
2019-12-09dt-bindings: phy: dp83867: Add documentation for disabling clock outputGrygorii Strashko
Based on commit 980066e6d964 ("dt-bindings: phy: dp83867: Add documentation for disabling clock output") of mainline linux kernel. The clock output is generally only used for testing and development and not used to daisy-chain PHYs. It's just a source of RF noise afterward. Add a mux value for "off". I've added it as another enumeration to the output property. In the actual PHY, the mux and the output enable are independently controllable. However, it doesn't seem useful to be able to describe the mux setting when the output is disabled. Document that PHY's default setting will be left as is if the property is omitted. Signed-off-by: Grygorii Strashko <grygorii.strashko@ti.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2019-12-03clk: mediatek: add driver for MT8518mingming lee
Add clock driver for MediaTek MT8518 SoC. Signed-off-by: mingming lee <mingming.lee@mediatek.com>
