Copied from linux, branch nxp/imx_4.14.98_2.2.0 @ e6c2f6322962.
Add soc DTSi and clock/pinctrl binding files. The pinctrl binding
file is v0.03 generated by tool
Signed-off-by: Ye Li <ye.li@nxp.com>
Sync the SCFW API to with latest commit:
commit 252281d48647caad9a00ff1dd0f1a666c4067653
Author: Chuck Cannon <chuck.cannon@nxp.com>
Date: Fri Apr 5 18:03:13 2019 -0500
SCF-105: Update wiki.
Signed-off-by: Chuck Cannon <chuck.cannon@nxp.com>
Major changes in the update:
1. sc_seco_patch and sc_seco_start_rng are added.
2. sc_misc_get_boot_container is added
3. New resource SC_R_USB_1_PHY
4. Type for 16Mhz frequency
Acked-by: Peng Fan <peng.fan@nxp.com>
Also fixes MLK-21051: Replace manually added pads with defines from SCFW
export package.
Signed-off-by: Leonard Crestez <leonard.crestez@nxp.com>
Acked-by: Fugang Duan <fugang.duan@nxp.com>
Update to latest SCFW API with below commit. Add version API and
remove some resource ids.
commit 004247e14afc74a21d65569415c4b2e35bfaabc3
Author: Ranjani Vaidyanathan <ranjani.vaidyanathan@nxp.com>
Date: Thu Feb 14 14:55:12 2019 -0800
SCF-341 Fix bug in setting large slice clock divider
Incorrect mask was applied when clearing out the bits in the
DSC large slice divider.
Signed-off-by: Ranjani Vaidyanathan <ranjani.vaidyanathan@nxp.com>
We use MU8 and MU9 to communicate with M4_0 and M4_1 in u-boot. Add
relevant nodes for the MU driver.
Update API files generated from latest SCFW commit:
commit b5dbcf59157cf758da2b96c395e3f4cb2674437f
Author: Ranjani Vaidyanathan <Ranjani.Vaidyanathan@nxp.com>
Date: Sat Oct 27 02:04:47 2018 -0500
SCF-248 Fix Linux boot fail on iMX8QX
By default, imx8qm/qxp b0 silicon set the IO voltage to 2.5v, but mek/arm2
boards are designed as 1.8v voltage for enet IO, so force the IO voltage
to 1.8 by setting COMP_CTL_GPIO_1V8_3V3 pins like:
The pin setting:
1.8V/3.3V : bit4=0, bit[30]=1, bit[2:0]=000
2.5V : bit4=1, bit[30]=1, bit[2:0]=010
Reviewed-by: Ye Li <ye.li@nxp.com>
Signed-off-by: Fugang Duan <fugang.duan@nxp.com>
Sync dts from Linux kernel commit
3091745d6acfdad21("MLK-18210 ARM64: dts: imx8qm: correct the pds of pcie").
Signed-off-by: Peng Fan <peng.fan@nxp.com>
(cherry picked from commit 0e7a5484878338d0dff871b6d21092a0479f07b4)
Copy the imx8qm DTS files and its binding header files from imx_4.9.y kernel
(commit "MLK-16174: ASoC: fsl_hifi4: load firmware in device open phase.")
Add extra support used in u-boot:
1. Add alias for FSPI nodes
2. Add GPIO alias which is used as seq number in u-boot DM GPIO driver.
3. Ajust GPIO nodes ahead of i2c nodes. The PCA9557 is a i2c device, if we
arrange the i2c nodes ahead of GPIO nodes, the GPIO seq number for PCA9557
will overlay with GPIO nodes. This will cause issue to use GPIO in u-boot.
4. Add i2c alias for i2c0 to i2c3.
5. Add mipi0/mipi1 i2c0 controllers' nodes.
6. Add "u-boot,dm-pre-reloc" to thermal node in QXP DTSi
7. Add USB alias for OTG and USB3 ports.
8. Sync power domains of display resources with kernel
(commit "MLK-17978[IMX8QXP B0] Add a buffer null flag to ensure the buffer is not")
9. Removed mmc alias
(cherry picked from commit b8b7885469720ad6e31e0a1ff5751e9cb36b408e)
1. Add mbox-cells used for mailbox
2. Add alias for FSPI nodes
3. Add GPIO alias which is used as seq number in u-boot DM GPIO driver.
4. Ajust GPIO nodes ahead of i2c nodes. The PCA9557 is a i2c device, if we
5. Add i2c alias for i2c0 to i2c4, i2c6 and i2c8.
6. Modify ethernet alias index start from 0
7. Add the usb alias for OTG and USB3.
8. Add "u-boot,dm-pre-reloc" to thermal node to DTSi
9. Sync power domains of display resources with kernel
10. Add "power-domains" property to all GPIO nodes and flexspi node, since
they miss to add it.
11. Add "simple-bus" compatible strings to imx8qm-pm node.
12. Removed mmc alias
(cherry picked from commit 0e69d9e74d651227224bbc7e29ef87f515b9d07a)
Update i.MX6SX dtsi file and relevant DTS header files.
Add the imx6sx-sdb-emmc DTS file for reworked eMMC board.
Changes in DTS and DTSi:
1. Modify the n25q256a flash node's compatible to "spi-flash".
2. Add spi0 and spi1 alias for qspi1 and qspi2.
3. Add USB alias
4. Remove MMC alias
Porting the the imx7d dtsi, dts files and binding files from kernel
(f3834c73366f985fef6c1fdaaa129dfceb6151cb)
New dts files are added to support GPMI-WEIM, QSPI, RevA boards.
1. Add USB alias
2. Modify the SPI alias for qspi
3. Disable USDHC2 since it is for SDIO
4. Add i2c force idle support pins
5. Add LPSR pinfunc file
6. Removed mmc alias. So that device id in DM-MMC is aligned with Non-DM MMC.
v2017.03
Port the DTS and relevent binding files from v2017.03 for i.MX6DQ/DQP/DL/S
Sabreauto and SabreSD boards.
Removed the MMC alias from v2017.03, since the MMC will use it as device index when
DM MMC is enabled. This causes mismatch with Non-DM MMC case.
Import the R8A77965 M3N DT from Linux 4.16-rc1 .
Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com>
Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
Add dtsi file for i.MX8MQ.
Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
"assign-clock-rate"
The RK3288 CRU-node assigns rates to a number of clocks that are not
implemented in the RK3288 clock-driver (but which have been
sufficiently initialised from rkclk_init()): for these clocks, we
implement the gmac clock set parent, but simply ignore the
others' set_rate() operation and return 0 to signal success.
Signed-off-by: David Wu <david.wu@rock-chips.com>
Acked-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
The rk3328 soc has two gmac controllers, one is gmac2io,
the other is gmac2phy. We use the gmac2io rgmii interface
for 1000M phy here.
Import the Renesas R8A7794 DTS and headers from upstream Linux kernel v4.15-rc8,
commit bebc6082da0a9f5d47a1ea2edc099bf671058bd4 .
Import the Renesas R8A7793 DTS and headers from upstream Linux kernel v4.15-rc8,
Import the Renesas R8A7792 DTS and headers from upstream Linux kernel v4.15-rc8,
Import the Renesas R8A7791 DTS and headers from upstream Linux kernel v4.15-rc8,
Import the Renesas R8A7790 DTS and headers from upstream Linux kernel v4.15-rc8,
Signed-off-by: Álvaro Fernández Rojas <noltari@gmail.com>
Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
I'm working on a v2 patch to add support for a board named pdu001. Its
Linux DTS file uses the include file added by this patch. To keep Linux
and U-Boot DTS files in sync U-Boot requires a copy of this file,
although there is no driver for NXP's PCA9532 i2c LED driver chip (yet).
Signed-off-by: Felix Brack <fb@ltec.ch>
Update default AXI, TUN, ARC clock set options:
instead of changing only IDIV divider settings adjust also domain PLL
settings.
Add support of TUN_ROM and TUN_PWM clocks (subclocks of TUNN_PLL)
Signed-off-by: Eugeniy Paltsev <Eugeniy.Paltsev@synopsys.com>
Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
Add DT nodes to enable ARM_PL180_MMCI IP support for STM32F746
and STM32F769 discovery boards
There is a hardware issue on these boards, it misses a pullup on the GPIO line
used as card detect to allow correct SD card detection.
As workaround, cd-gpios property is not present in DT.
So SD card is always considered present in the slot.
Signed-off-by: Christophe Priouzeau <christophe.priouzeau@st.com>
Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
_ Add gpio compatible and aliases for stm32f429
_ Add FMC sdram node with associated new bindings value to
manage second bank (ie bank 1).
_ Add "u-boot,dm-pre-reloc" for rcc, fmc, fixed-clock, pinctrl,
pwrcfg and gpio nodes.
All these files comes from kernel v4.15-rc1.
Update some header with correct STMicroelectronics Copyright.
Remove the paragraph about writing to the Free Software
Foundation's mailing address as requested by checkpatch.
Synopsys HSDK clock controller generates and supplies clocks to various
controllers and peripherals within the SoC.
Each clock has assigned identifier and client device tree nodes can use
this identifier to specify the clock which they consume. All available
clocks are defined as preprocessor macros in the
dt-bindings/clock/snps,hsdk-cgu.h header and can be used in device
tree sources.
Add bits to support yet another SoC, the R8A77995 D3 .
Add bits to support yet another SoC, the R8A77970 V3M .
Add dts binding header for rk3128, files origin from kernel.
Series-Changes: 2
- fix i2c address
- add saradc and usb phy node
- emmc using fifo mode for there is no dma support in rk3128 emmc
- add some clock id in cru.h
Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
MMC block needs 48Mhz source clock, for that we choose
to select the SAI PLL.
Update also stm32_clock_get_rate() to retrieve the MMC
clock source needed in MMC driver.
STM32F4 uses a different RCC variant than STM32F7. For STM32F4
sdmmc clocks bit are located into dckcfgr register whereas there
are located into dckcfgr2 registers on STM32F7.
In both registers, bits CK48MSEL and SDMMC1SEL are located at
the same position.
Reviewed-by: Vikas Manocha <vikas.manocha@st.com>
Xilinx changes for v2018.1
Zynq:
- Add support for Syzygy and cc108 boards
- Add support for mini u-boot configurations (cse)
- dts updates
- config/defconfig updates in connection to Kconfig changes
- Fix psu_init handling
ZynqMP:
- SPL fixes
- Remove slcr.c
- Fixing r5 startup sequence
- Add support for external pmufw
- Add support for new ZynqMP chips
- dts updates
- Add support for zcu102 rev1.0 board
Drivers:
- nand: Support external timing setting and board init
- ahci: Fix wording
- axi_emac: Wait for bit, non processor mode, readl/write conversion
- zynq_gem: Fix SGMII/PCS support
Added pin control support in device tree for zynqmp.
Signed-off-by: Chirag Parekh <chirag.parekh@xilinx.com>
Synchronize the Amlogic ARM64 dts from mainline Linux 4.13.5
In the preparation of the support of the Amlogic P212 board,
import the corresponding meson-gxl-s905x-p212.dts file.
Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
Reviewed-by: Beniamino Galvani <b.galvani@gmail.com>
Upstream Linux has received a few device tree updates to the RPi
which we should propagate into the builtin U-Boot one as well to
gain hardware support.
This patch bumps the dts files to their 4.14 Linux counterparts
with the exception of sdhost on 32bit RPi versions. There we stay
with iproc as the sdhost driver is missing in U-Boot.
The kernel DT of the SinA33 has evolved quite a bit. Make sure we sync it
and its upstream DTSI to be able to use the OTG. The DTs were taken from
the 4.13 kernel release.
Reviewed-by: Łukasz Majewski <lukma@denx.de>
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
The clk_saradc is dividing from the 24M, clk_saradc=24MHz/(saradc_div_con+1).
SARADC integer divider control register is 10-bits width.
This patch adapts stm32h743 disco and eval dts files to match
with U-boot requirements or add features wich are not yet
upstreamed on kernel side :
_ Add RCC clock driver node and update all clocks phandle
accordingly.
By default, on kernel side, all clocks was temporarly
configured as a phandle to timer_clk waiting for a RCC
clock driver to be available.
On U-boot side, we now have a dedicated RCC clock driver, we
can configured all clocks as phandle to this driver.
All this binding update will be available soon in a kernel tag,
as all the bindings have been acked by Rob Herring [1].
[1] http://lkml.iu.edu/hypermail/linux/kernel/1704.0/00935.html
_ Align STM32H7 serial compatible string with the one which will be
available in next kernel tag. The bindings has been acked by
Rob Herring [2].
This compatible string will be usefull to add stm32h7 specific
feature for this serial driver.
[2] https://lkml.org/lkml/2017/7/17/739
_ Add gpio compatible and aliases for stm32h743
_ Add missing HSI and CSI oscillators nodes needed
by STM32H7 RCC clock driver.
Clock sources could be:
_ HSE (High Speed External)
_ HSI (High Speed Internal)
_ CSI (Low Power Internal)
These clocks can be used as clocksource in some configuration.
By default, HSE is selected as clock source.
_ Set HSE to 25Mhz for stm32h743i-disco and eval board
By default, the external oscillator frequency is defined at
25 Mhz in SoC stm32h743.dtsi file.
It has been set at 125 Mhz in kernel DT temporarly waiting for
RCC clock driver becomes available.
As in U-boot we got a RCC clock driver, the real value of HSE
clock can be used.
All these files are imported from linux kernel v4.13
Add device tree support for STM32H743 SoC and discovery
board. This board offers :
_ STM32H743XIH6 microcontroller with 2 Mbytes of
Flash memory and 1 Mbyte of RAM in TFBGA240+25 package
_ 5.7” 640x480 TFT color LCD with touch screen
_ Ethernet compliant with IEEE-802.3-2002
_ USB OTG HS
_ I2 C compatible serial interface
_ ST-MEMS digital microphones
_ 8-Gbyte (or more) SDIO3.0 interface microSD™ card
_ 8Mx32bit SDRAM
_ 1-Gbit Twin Quad-SPI NOR Flash
_ Reset, wakeup, or key buttons
_ Joystick with 4-direction control and selector
_ Board connectors :
1 USB with Micro-AB
Ethernet RJ45
Stereo headset jack including analog microphone input
microSD™ card
RCA connector
JTAG/SWD and ETM trace
_ Expansion connectors:
Arduino Uno compatible Connectors
2 x PIO connectors (PMOD and PMOD+)
_ On-board ST-LINK/V2-1 debugger/programmer with USB re-enumeration
capability: mass storage, virtual COM port and debug port
This driver is adapted from linux drivers/reset/reset-stm32.c
It's compatible with STM32 F4/F7/H7 SoCs.
This driver doesn't implement .of_match as it's binded
by MFD RCC driver.
To add support for each SoC family, a SoC's specific
include/dt-binfings/mfd/stm32xx-rcc.h file must be added.
This patch only includes stm32h7-rcc.h dedicated for STM32H7 SoCs.
Other SoCs support will be added in the future.
This driver implements basic clock setup, only clock gating
is implemented.
by MFD RCC driver.
Files include/dt-bindings/clock/stm32h7-clks.h and
doc/device-tree-bindings/clock/st,stm32h7-rcc.txt
will be available soon in a kernel tag, as all the
