Add dt-bindings include file for Atmel Flexcom hardware block.
This file is copied from Linux kernel.
It is used in devicetrees from Linux.
Signed-off-by: Eugen Hristev <eugen.hristev@microchip.com>
Due to the large number of clocks, I decided to use the CCF. The overall
structure is modeled after the imx code. Clocks parameters are stored in
several arrays, and are then instantiated at run-time. There are some
translation macros (FOOIFY()) which allow for more dense packing.
Signed-off-by: Sean Anderson <seanga2@gmail.com>
CC: Lukasz Majewski <lukma@denx.de>
from https://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-stericsson.git/
tag "ux500-armsoc-v5.6-2"
commit 224bf0fe7292 ("ARM: dts: ux500: samsung-golden: Add Bluetooth")
(queued for merge in Linux 5.6)
Signed-off-by: Stephan Gerhold <stephan@gerhold.net>
Device tree and binding alignment with kernel v5.4-rc4
Reviewed-by: Patrice Chotard <patrice.chotard@st.com>
Device tree and binding alignment with kernel v5.3
and converted to SPDX.
Alignment with kernel driver name & binding
introduced by https://patchwork.kernel.org/cover/10761943/
to use the final marketing name = STPMIC1.
Reviewed-by: Lukasz Majewski <lukma@denx.de>
Prepare file modification for kernel alignment and
rename driver to stpmic1.
Add regulator nodes needed by stpmu1 regulator driver
Add vmmc-supply and vqmmc-supply regulator property for
sdmmc1 and sdmmc2.
Signed-off-by: Christophe Kerello <christophe.kerello@st.com>
Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
DSI clock is available on STM32F769-disco and
STM32F469-disco board.
Signed-off-by: Yannick Fertre <yannick.fertre@st.com>
All these files comes from kernel v4.15-rc1.
Update some header with correct STMicroelectronics Copyright.
Remove the paragraph about writing to the Free Software
Foundation's mailing address as requested by checkpatch.
MMC block needs 48Mhz source clock, for that we choose
to select the SAI PLL.
Update also stm32_clock_get_rate() to retrieve the MMC
clock source needed in MMC driver.
STM32F4 uses a different RCC variant than STM32F7. For STM32F4
sdmmc clocks bit are located into dckcfgr register whereas there
are located into dckcfgr2 registers on STM32F7.
In both registers, bits CK48MSEL and SDMMC1SEL are located at
the same position.
Signed-off-by: Christophe Priouzeau <christophe.priouzeau@st.com>
Reviewed-by: Vikas Manocha <vikas.manocha@st.com>
This driver is adapted from linux drivers/reset/reset-stm32.c
It's compatible with STM32 F4/F7/H7 SoCs.
This driver doesn't implement .of_match as it's binded
by MFD RCC driver.
To add support for each SoC family, a SoC's specific
include/dt-binfings/mfd/stm32xx-rcc.h file must be added.
This patch only includes stm32h7-rcc.h dedicated for STM32H7 SoCs.
Other SoCs support will be added in the future.
Use the same clocks macro than the one used by kernel DT.
Acked-by: Vikas MANOCHA <vikas.manocha@st.com>
This device tree has been extracted from v4.9 kernel
