path: root/include/dt-bindings/comphy
2017-05-09phy: marvell: cp110: add 5G XFI modeIgal Liberman
This patch adds the option to configure a comphy to 5G XFI mode. In order to configure the comphy to 5G XFI, update the comphy node in the device-tree: phy2 { phy-type = <PHY_TYPE_SFI>; phy-speed = <PHY_SPEED_5_15625G>; }; Signed-off-by: Igal Liberman <igall@marvell.com> Signed-off-by: Stefan Roese <sr@denx.de> Reviewed-by: Stefan Roese <sr@denx.de>
2017-05-09phy: marvell: add IGNORE COMPHY typeStefan Roese
This type tells u-boot to preserve the COMPHY settings as is it is usefull in situations where the COMPHY was initialized by earlier firmware. Note that IGNORE is different from UNCONNECTED since setting UNCONNECTED type will disconnect the COMPHY in the COMPHY MUX which is a desired behaviour Signed-off-by: Yehuda Yitschak <yehuday@marvell.com> Signed-off-by: Stefan Roese <sr@denx.de> Signed-off-by: Igal Liberman <igall@marvell.com> Reviewed-by: Stefan Roese <sr@denx.de>
2017-05-09phy: marvell: cp110: update utmi phy connection typeStefan Roese
UTMI_PHY_TO_USB_HOST was used in USB3 UTMI dts node only, but there will be USB2 UTMI dts node for some SoCs that have got USB2 controller, so rename TO_USB_HOST to TO_USB3_HOST to distinguish TO_USB2_HOST in later on patches. Signed-off-by: zachary <zhangzg@marvell.com> Signed-off-by: Stefan Roese <sr@denx.de> Signed-off-by: Igal Liberman <igall@marvell.com> Reviewed-by: Stefan Roese <sr@denx.de>
2017-05-09phy: marvell: Replace PHY_TYPE_KR with PHY_TYPE_SFIStefan Roese
Use correct naming as done in the latest Marvell U-Boot version as well. Signed-off-by: Stefan Roese <sr@denx.de> Signed-off-by: Igal Liberman <igall@marvell.com> Reviewed-by: Stefan Roese <sr@denx.de>
2016-09-27drivers/phy: Add Marvell SerDes / PHY drivers used on Armada 3kStefan Roese
This version is based on the Marvell U-Boot version with this patch applied as latest patch: Git ID 7f408573: "fix: comphy: cp110: add comphy initialization for usb device mode" from 2016-07-05. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Nadav Haklai <nadavh@marvell.com> Cc: Kostya Porotchkin <kostap@marvell.com> Cc: Wilson Ding <dingwei@marvell.com> Cc: Victor Gu <xigu@marvell.com> Cc: Hua Jing <jinghua@marvell.com> Cc: Terry Zhou <bjzhou@marvell.com> Cc: Hanna Hawa <hannah@marvell.com> Cc: Haim Boot <hayim@marvell.com>
