path: root/include/dt-bindings/clock
2020-05-04Merge tag 'u-boot-rockchip-20200501' of ↵Tom Rini
https://gitlab.denx.de/u-boot/custodians/u-boot-rockchip - dts clean up to use -u-boot for px30, rk3399 boards - dts sycn from upstream kernel for rk3328, rk3399 - add rockchip rng driver - new board support: rk3328-roc-cc, rk3399-roc-pc,Nanopi M4 2GB
2020-05-01dt-bindings: clock: rk3328: sync from upstream Linux kernelChen-Yu Tsai
This syncs the rk3328 clock header file from Linux kernel next-20200324, to support newer hardware blocks when syncing the device tree files. The last non-merge commit to touch it was 0dc14b013f79 ("clk: rockchip: add clock id for watchdog pclk on rk3328") Reviewed-by: Kever Yang <kever.yang@rock-chips.com> Tested-by: Loic Devulder <ldevulder@suse.com> Tested-by: Peter Geis <pgwipeout@gmail.com> Signed-off-by: Chen-Yu Tsai <wens@csie.org>
2020-04-29Merge https://gitlab.denx.de/u-boot/custodians/u-boot-shTom Rini
- rmobile gen2/gen3 DTS sync and defconfig consolidation
2020-04-28ARM: dts: rmobile: Synchronize Gen2 DTs with Linux 5.6.2Marek Vasut
Synchronize R-Car Gen2 device trees with Linux 5.6.2, commit 9fbe5c87eaa9b72db08425c52c373eb5f6537a0a . Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2020-04-28Merge tag 'u-boot-amlogic-20200428' of ↵Tom Rini
https://gitlab.denx.de/u-boot/custodians/u-boot-amlogic - fix sd-emmc controller A init on G12A/G12B/SM1 SoCs - add GXBB USB PHY driver - enable access to SPI NOR Flash on VIM2 and VIM3/VIM3L boards - fix USB PHYs Power-Up on on VIM3/VIM3L boards
2020-04-28arm64: dts: meson: sync dt and bindings from v5.7-rc1Neil Armstrong
Sync the device tree and dt-bindings from Linux v5.7-rc1 8f3d9f354286 ("Linux 5.7-rc1"). Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
2020-04-27ARC: HSDK: CGU: add support for timer clockEugeniy Paltsev
Add support for additional timer clock which belongs to tunnel domain. Signed-off-by: Eugeniy Paltsev <Eugeniy.Paltsev@synopsys.com> Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
2020-04-24arm: actions: add S700 SoC device treeAmit Singh Tomar
This patch adds .dtsi file(sync with Linux 5.5-rc6 with hash "b3a987b0264d") and required binding for S700 SoC that is a 64-bit Quad-core ARM Cortex-A53 cores. It also provisions dts file to be built based on selected platform(CONFIG_MACH_S900/S700). Reviewed-by: Manivannan Sadhasivam <manivannan.sadhasivam@linaro.org> Reviewed-by: Andre Przywara <andre.przywara@arm.com> Signed-off-by: Amit Singh Tomar <amittomer25@gmail.com>
2020-04-24arm: dts: sync dts for Action Semi S900Amit Singh Tomar
Synchronize device tree bindings with v5.5-rc6 tag with commit id "b3a987b0264d". Also, it removes older clock binding defined for S900 along with undocumented compatible string "actions,s900-serial" from serial driver and adapts clock driver to cater to new bindings. Reviewed-by: Manivannan Sadhasivam <manivannan.sadhasivam@linaro.org> Reviewed-by: Andre Przywara <andre.przywara@arm.com> Signed-off-by: Amit Singh Tomar <amittomer25@gmail.com>
2020-04-18clk: imx: add i.IMXRT1020 clk driverGiulio Benetti
Add i.MXRT1020 clk driver support. Signed-off-by: Giulio Benetti <giulio.benetti@benettiengineering.com> Reviewed-by: Lukasz Majewski <lukma@denx.de>
2020-04-06arm64: dts: meson: sync dt and bindings from v5.6-rc2Jerome Brunet
Sync the device tree and dt-bindings from Linux v5.6-rc2 11a48a5a18c6 ("Linux 5.6-rc2") The only exception to this is the mmc pinctrl pin bias of gxl SoC family. This is a fix which found its way to u-boot but not Linux yet. Acked-by: Neil Armstrong <narmstrong@baylibre.com> Signed-off-by: Jerome Brunet <jbrunet@baylibre.com> Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
2020-03-09ARM: dts: imx6sx: Sync with kernel 5.4.16Fabio Estevam
Sync the imx6sx dts files with kernel 5.4.16. Signed-off-by: Fabio Estevam <festevam@gmail.com>
2020-02-07x86: Add a clock driver for Intel devicesSimon Glass
So far we have avoided adding a clock driver for Intel devices. But the Designware I2C driver needs a different clock (133MHz) on Intel devices than on others (166MHz). Add a simple driver that provides this information. This driver can be expanded later as needed. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2020-01-26Merge branch 'master' of https://gitlab.denx.de/u-boot/custodians/u-boot-sunxiTom Rini
- Libre Computer ALL-H3-IT/ALL-H5-CC board (Chen-Yu Tsai) - Allwinner R40 Ethernet, usb phy enablement (Andre Przywara) - Sunxi auto load from 128KB MMC offset (Andre Przywara) - Orange Pi Win Ethernet phy enablement (Jernej Skrabec)
2020-01-24sunxi: H3/H5 Sync DT files from upstream Linux kernel as of next-20200108Chen-Yu Tsai
Sync the device tree files and device tree header files from upstream Linux kernel, as of 2020-01-08. The commit synced to in the sunxi repo 98d25b0b266d Merge branch 'sunxi/dt-for-5.6' into sunxi/for-next which is also part of next-20200108. Changes brought in include: - cleanup of pinmux node names - addition of Security ID, MBUS, CSI, crypto engine, video codec, pmu, and thermal sensor device nodes for both SoCs - addition of deinterlacing engine device node on H3 - cleanup of RTC device node and addition of its clocks - various board cleanups and improvements - removal of pinmux node for GPIO lines - cpufreq / DVFS - HDMI output - UART-based Bluetooth - audio codec - USB ports - new boards Most of the changes don't concern U-boot. Signed-off-by: Chen-Yu Tsai <wens@csie.org> Reviewed-by: Jagan Teki <jagan@amarulasolutions.com>
2020-01-22arm: dts: Import device tree for ST-Ericsson Ux500Stephan Gerhold
from https://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-stericsson.git/ tag "ux500-armsoc-v5.6-2" commit 224bf0fe7292 ("ARM: dts: ux500: samsung-golden: Add Bluetooth") (queued for merge in Linux 5.6) Signed-off-by: Stephan Gerhold <stephan@gerhold.net> Reviewed-by: Linus Walleij <linus.walleij@linaro.org>
2020-01-16clk: mediatek: add driver for MT7622Sam Shih
This patch add clock driver for MediaTek MT7622 SoC. Signed-off-by: Ryder Lee <ryder.lee@mediatek.com> Signed-off-by: Sam Shih <sam.shih@mediatek.com>
2020-01-16clk: mediatek: add driver support for MT8512mingming lee
Add clock driver for MediaTek MT8512 SoC, include topckgen, apmixedsys and infracfg support. Signed-off-by: mingming lee <mingming.lee@mediatek.com>
2020-01-14clk: imx: add i.IMXRT1050 clk driverGiulio Benetti
Add i.MXRT1050 clk driver support. Signed-off-by: Giulio Benetti <giulio.benetti@benettiengineering.com>
2020-01-08Merge tag 'u-boot-imx-20200108' of ↵Tom Rini
https://gitlab.denx.de/u-boot/custodians/u-boot-imx --------------------------------------------------------------------- Add i.MX8MP SoC and EVK board Update README for i.MX8MN EVK and fix mmc env Add pca9450 driver -------------------------------------------------------------------- Travis: https://travis-ci.org/sbabic/u-boot-imx/builds/634211885
2020-01-08dt-bindings: clock: add i.MX8MP clock headerPeng Fan
Add i.MX8MP clock header Signed-off-by: Peng Fan <peng.fan@nxp.com>
2020-01-07clk: agilex: Add clock driver for AgilexLey Foon Tan
Add clock manager driver for Agilex. Provides clock initialization and get_rate functions. agilex-clock.h is from Linux commit ID cd2e1ad12247. Signed-off-by: Chee Hong Ang <chee.hong.ang@intel.com> Signed-off-by: Ley Foon Tan <ley.foon.tan@intel.com> Reviewed-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
2019-12-03clk: mediatek: add driver for MT8518mingming lee
Add clock driver for MediaTek MT8518 SoC. Signed-off-by: mingming lee <mingming.lee@mediatek.com>
2019-11-26ARM: dts: stm32: DT alignment with kernel v5.3Patrick Delaunay
Device tree and binding alignment with kernel v5.3 and converted to SPDX. Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com> Reviewed-by: Patrice Chotard <patrice.chotard@st.com>
2019-11-17rockchip: clk: Add clk driver for rk3308Finley Xiao
Add clk controller driver for RK3308 SOC. This patch depends on Elaine's pll patch[0]. [0]http://patchwork.ozlabs.org/patch/1183718/ Signed-off-by: Andy Yan <andy.yan@rock-chips.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
2019-11-17rockchip: clk: add px30 clock driverKever Yang
The px30 contains 2 separate clock controllers, pmucru and cru. Add drivers for them. Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Signed-off-by: Heiko Stuebner <heiko.stuebner@theobroma-systems.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
2019-11-05imx: add dtsi for i.MX8MNPeng Fan
Add dtsi for i.MX8MN Signed-off-by: Peng Fan <peng.fan@nxp.com>
2019-11-03imx: update i.MX8MQ device treesPatrick Wildt
This updates the i.MX8MQ device trees and, necessarily, also the i.MX8MQ clock bindings. These are taken verbatim from from the Linux kernel version v5.4-rc2, which three small changes which were already part of the previous device tree: * Keep the PSCI reserved memory range * Keep the alias for ethernet, so that the MAC address can be set * Keep the modified #include for the IOMUXC pins Signed-off-by: Patrick Wildt <patrick@blueri.se> Acked-by: Peng Fan <peng.fan@nxp.com>
2019-10-25Merge tag 'mips-pull-2019-10-25' of git://git.denx.de/u-boot-mipsTom Rini
- bmips: add BCRM NAND support for BCM6368, BCM6328, BCM6362 and BCM63268 SoCs - bmips: various small fixes - mtmips: add new drivers for clock, reset-controller and pinctrl - mtmips: add support for high speed UART - mtmips: update/enhance drivers for SPI and ethernet - mtmips: add support for MMC
2019-10-25clk: add clock driver for MediaTek MT76x8 platformWeijie Gao
This patch adds a clock driver for MediaTek MT7628/7688 SoC. It provides clock gate control as well as getting clock frequency for CPU/SYS/XTAL and some peripherals. Signed-off-by: Weijie Gao <weijie.gao@mediatek.com>
2019-10-25bmips: correct name charactersÁlvaro Fernández Rojas
Signed-off-by: Álvaro Fernández Rojas <noltari@gmail.com>
2019-10-24dt-bindings: clock: zynqmp: Add clk headerRajan Vaja
Add dt clock header which can be included by dtses. And also use zynqmp-clk compatible string. Signed-off-by: Rajan Vaja <rajan.vaja@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2019-10-18arm: dts: Import and update DT for Khadas VIM3Andreas Färber
In Linux meson-g12-common.dtsi was introduced as well as new g12b nodes and headers, as dependencies of new meson-g12b-a311d-khadas-vim3.dts. Copied from da0c9ea146cb ("Linux 5.4-rc2") Signed-off-by: Andreas Färber <afaerber@suse.de> Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
2019-10-08imx: imx8mm: add clock bindings headerPeng Fan
Import clock bindings header file from Linux 5.3.0-rc2 Signed-off-by: Peng Fan <peng.fan@nxp.com>
2019-10-08arm: dts: sync dts for i.MX6ULPeng Fan
Sync kernel dts for i.MX6UL from commit <0a8ad0ffa4d8> ("Merge tag 'for-linus-5.3-ofs1' of git://git.kernel.org/pub/scm/linux/kernel/git/hubcap/linux") Signed-off-by: Peng Fan <peng.fan@nxp.com> Reviewed-by: Ye Li <ye.li@nxp.com> Reviewed-by: Fabio Estevam <festevam@gmail.com>
2019-08-11arm: dts: Import HI3660 devicetree from LinuxManivannan Sadhasivam
This commit imports HI3660 SoC devicetree from Linux Signed-off-by: Manivannan Sadhasivam <manivannan.sadhasivam@linaro.org>
2019-08-09ARM: dts: renesas: Add R8A77980 V3H DTs and headersMarek Vasut
Import R8A77980 V3H DTs and headers from Linux 5.2.7 , commit 5697a9d3d55f. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2019-07-31ARM: dts: Sync Amlogic G12A with Linux 5.3-rc1Neil Armstrong
Sync the Amlogic Meson G12A DT and Bindings file with the Linux 5.3-rc1 from the commit 5f9e832c1370 ("Linus 5.3-rc1"). Also remove the meson-g12a-u-boot.dtsi and meson-g12a-u200-u-boot.dtsi, now conflicting with the main DT content. Signed-off-by: Neil Armstrong <narmstrong@baylibre.com> Tested-by: Mark Kettenis <kettenis@openbsd.org>
2019-07-19clk: sifive: Sync-up DT bindings header with upstream LinuxAnup Patel
The location and license header of DT bindings header for SiFive clock driver has changed in upstream Linux hence this patch. Signed-off-by: Anup Patel <anup.patel@wdc.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2019-06-12fdt: update bcm283x device tree sources to Linux 5.1-rc6 stateHeinrich Schuchardt
Updating the bcm283x device tree sources adds the device trees for - Raspberry Pi 3 Model A+ - Raspberry Pi 3 Model B+ - Raspberry Pi Compute Module IO board rev1 - Raspberry Pi Compute Module 3 IO board V3.0 - Raspberry Pi Zero Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Matthias Brugger <mbrugger@suse.com>
2019-05-31ARM: dts: sync Amlogic G12A DT with Linux 5.2-rc1Neil Armstrong
Sync from Linux commit a188339ca5a3 ("Linux 5.2-rc1") Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
2019-05-07ARM: dts: renesas: Add RZ/A1 platform codeChris Brandt
Add platform code and DTs for Renesas RZ/A1 R7S72100 SoC. Distinguishing feature of this SoC is that it has up to 10 MiB of on-SoC static RAM (SRAM). The DTs are imported from Linux 5.0.11, commit d5a2675b207d . Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Chris Brandt <chris.brandt@renesas.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2019-05-01Merge tag 'u-boot-imx-20190426' of git://git.denx.de/u-boot-imxTom Rini
Porting to DM and i.MX8 ------------------------ - warp7 to DM - kp_imx53 to DM - Warnings in DT - MX8QM support - colibri-imx6ull to DM - imx7d-pico to DM - ocotp for MX8
2019-04-25dt-bindings: clock: dt-bindings: pinctrl: add i.MX8QM clocks definitionPeng Fan
Add i.MX8QM clocks definition Signed-off-by: Peng Fan <peng.fan@nxp.com>
2019-04-24Merge tag 'u-boot-stm32-mcu-20190423' of https://github.com/pchotard/u-bootTom Rini
STM32 MCUs update: - DT rework and alignment with DT kernel v4.20 - mmc: arm_pl180_mmci: Synchronize compatible with kernel v4.20 - mmc: stm32_sdmmc2: Synchronize properties with kernel v4.20 - configs: update for F746/769 boards
2019-04-24Merge tag 'u-boot-amlogic-20190423' of git://git.denx.de/u-boot-amlogicTom Rini
- Add support for Amlogic p200 & p201 Reference Designs - Add Amlogic SoC information display - Add support for the Libretech-AC AML-S805X-AC board - Add Amlogic AXG reset compatible - Add I2C support for Amlogic AXG - Fix AXG PIN and BANK pinctrl definitions - Fix regmap_read_poll_timeout warning about sandbox_timer_add_offset - Add initial support for Amlogic G12A SoC and U200 board - Enable PHY_REALTEK for selected boards - Fix Khadas VIM2 README
2019-04-23clk: mediatek: add driver for MT8516Fabien Parent
Add clock driver for MediaTek MT8516 SoC. Signed-off-by: Fabien Parent <fparent@baylibre.com> Acked-by: Ryder Lee <ryder.lee@mediatek.com> [trini: Redo whitespace] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-04-23ARM: dts: stm32: Sync DT files with v4.20 kernel for stm32f4Patrice Chotard
Synchronize stm32f7 device tree with kernel v4.20. Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
2019-04-23ARM: dts: Import Amlogic G12A u200 DT from Linux 5.1-rc1Neil Armstrong
Import Linux 5.1-rc1 DT from 9e98c678c2d6 ("Linux 5.1-rc1") for the meson-g12a-u200 board, the meson-g12a.dtsi and the corresponding bindings. Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
2019-04-14arm64: allwinner: sun50i: Sync H6 dts(i) files from LinuxJagan Teki
Usually the Linux dts changes were synced in specific tags in Allwinner, to keep track for whats been synced so-far and plan for future syncs. But this patch sync sun50i-h6* dts(i) files from Linux w/o any specific tag since these dts(i) changes are required for new H6 boards support. Linux commit details about the sun50i-h6* sync: "arm64: dts: allwinner: h6: move MMC pinctrl to dtsi" (sha1: 6ba2e45d57afdfd982d12f168edd6a79a65075d8) Linux commit details about the sun8i-tcon-top.h sync: "dt-bindings: display: sunxi-drm: Add TCON TOP description" (sha1: 59a9c39544cd1e5952c2a33028d71aa8180648f8) Part of the sync initiated by 'Clément Péron'. Signed-off-by: Clément Péron <peron.clem@gmail.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
