Add imx6qdl clock header defines support from Linux.
"clk: imx: Add clock support for imx6qp"
(sha1: ee36027427c769b0b9e5e205fe43aced93d6aa66)
Cc: Peng Fan <peng.fan@nxp.com>
Cc: Fabio Estevam <fabio.estevam@nxp.com>
Cc: Matteo Lisi <matteo.lisi@engicam.com>
Cc: Michael Trimarchi <michael@amarulasolutions.com>
Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
Add i.mx6ul clock header, copied from kernel commit (29b4817d401).
i.MX6ULL reuse the file in Linux Kernel, so let's keep the same.
Signed-off-by: Peng Fan <peng.fan@nxp.com>
The primary benefit of this change is that it adds all missing clocks and
resets properties to peripherals. This will allow peripheral drivers to
migrate to the standard clock and reset APIs in the future.
Main changes:
* Brought in the correct Tegra210 CAR binding; the old file in U-Boot
appears to be a renamed version of the Tegra124 bindings rather than
the real Tegra210 version.
* Conversion of SPI and UART nodes to standard DMA bindings. U-Boot
doesn't use DMA so isn't affected.
* Split of EHCI and USB PHY nodes. The EHCI nodes continue to contain all
information required by U-Boot, so U-Boot is not affected.
* Conversion of many magic numbers to named defines.
* Addition of many nodes not used by U-Boot, including separation of the
Tegra LIC (Legacy IRQ controller) and GIC.
* Node sort order fixes.
Remaining deltas relative to the Linux DT:
* U-Boot has enabled PCIe for Tegra210, but the kernel hasn't yet.
* The GPIO node compatible value in the kernel explicitly includes
Tegra124 values whereas U-Boot does not. I'll send a kernel patch to
correct this.
Signed-off-by: Tom Warren <twarren@nvidia.com>
Main changes:
* Conversion of SPI nodes to standard DMA bindings. U-Boot doesn't use
* Boards need to define the clk32k_in clock that feeds the Tegra PMC.
* Addition of tegra114-mc.h since tegra114.dtsi now includes it.
* Addition of many nodes not used by U-Boot.
* USB node compatible values in U-Boot explicitly list Tegra114 values
whereas the kernel does not. I'll send a kernel patch to correct this.
Main changes:
* Modification of PCIe memory region addresses. The HW memory layout is
programmable, so this should work fine, and Beaver PCIe was tested
without issue.
* Removal of pcie_xclk from the PCIe node and clock binding header. This
clock doesn't exist and isn't used; only a reset with this ID exists.
* Changed the phy_type value for the second USB port. This required board
DTs to be updated to keep the same configuration.
* Addition of tegra30-mc.h since tegra30.dtsi now includes it.
* None.
This brings in a few minor fixes since the last sync. The largest change
is the removal of the definition for TEGRA20_CLK_PCIE_XCLK. This clock
doesn't actually exist.
Remaining deltas:
* Addition of u-boot,dm-pre-reloc property to a couple of nodes.
* Addition of the NAND controller, which Linux doesn't yet support.
Add a simple driver for the clocks provided by the MIPS Boston
development board. The system provides information about 2 clocks whose
rates are fixed by the bitfile flashed in the boards FPGA, and this
driver simply reads the rates of these 2 clocks.
Signed-off-by: Paul Burton <paul.burton@imgtec.com>
Sync dts files with the current (Aug 18th 2016) state of Maxime's
linux/sunxi/for-next repo.
Note this commit also updates configs/MSI_Primo81_defconfig,
adding: "# CONFIG_REQUIRE_SERIAL_CONSOLE is not set", this is necessary
because the tablet does not have a reachable uart so the dts sync
drops its serial0 alias.
Acked-by: Ian Campbell <ijc@hellion.org.uk>
The Tegra BPMP (Boot and Power Management Processor) is a separate
auxiliary CPU embedded into Tegra to perform power management work, and
controls related features such as clocks, resets, power domains, PMIC I2C
bus, etc. These bindings dictate how to represent the BPMP in device tree.
These files are from kernel upstream:
"649a371 Add linux-next specific files for 20160616"
with some modification need by U-Boot:
- chosen with stdout-path to uart2.
- add clock-frequency for uart2
Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
Add this file from Linux v4.5.
Tested-on: smartweb, corvus, taurus, axm
Tested-by: Heiko Schocher <hs@denx.de>
Reviewed-by: Andreas Bießmann <andreas@biessmann.org>
These are used by peach_pit and peach_pi. Add them so they can be referenced
in the device tree files.
Add a clock driver for Exynos7420 SoC. There are about 25 clock controller
blocks in Exynos7420 out of which support for topc, top0 and peric1 blocks
are added in this initial version of the driver.
Signed-off-by: Thomas Abraham <thomas.ab@samsung.com>
Import the upstream kernel dts into U-Boot. Currently
only serial is supported, but a lot more DT changes are
queued for v4.7.
Signed-off-by: Peter Griffin <peter.griffin@linaro.org>
This commit syncs the dt-bindings/input/* headers with the kernel (v4.5)
and adds dt-bindings/clock/sun4i-a10-pll2.h, both are necessary for newer
sunxi dts files to build.
Sync up these files with Linux v4.4.
PIC32 clock module consists of multiple oscillators, PLLs, mutiplexers
and dividers capable of supplying clock to various controllers
on or off-chip.
Signed-off-by: Purna Chandra Mandal <purna.mandal@microchip.com>
Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
Since rk3036 device tree file still in reviewing, bring it from
https://patchwork.kernel.org/patch/7203371/ and add some aliases
we need in uboot
Signed-off-by: Lin Huang <hl@rock-chips.com>
Bring in required device tree files from Linux. Since mainline Linux is
somewhat behind, use the files from the Chromium tree. We can re-sync once
further code is acccepted upstream.
All based off of Tegra124. As a Tegra210 board is brought
up, these may change a bit to match the HW more closely,
but probably 90% of this is identical to T124.
Note that since T210 is a 64-bit build, it has no SPL
component, and hence no cpu.c for Tegra210.
Add the device tree node for the PCIe controller found on Tegra30 SoCs.
Signed-off-by: Thierry Reding <treding@nvidia.com>
Add the device tree node for the PCIe controller found on Tegra20 SoCs.
Some Tegra device tree files do not include information about the serial
ports. Add this and also add information about the input clock speed.
The console alias needs to be set up to indicate which port is used for
the console.
Also add a binding file since this is missing.
Series-changes; 5
- Add full serial port nodes from Linux tree (commit fc9d4dbe)
- Use /chosen/stdout-path instead of /aliases/console to specify the console
