path: root/include/dt-bindings/clock/bcm6338-clock.h
2017-05-31MIPS: add support for Broadcom MIPS BCM6338 SoC familyÁlvaro Fernández Rojas
Signed-off-by: Álvaro Fernández Rojas <noltari@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
