path: root/include/ds4510.h
2017-05-22Kconfig: Drop CONFIG_CMD_DS4510Simon Glass
This option enables a command in the driver. But the functions defined by the driver are not called anywhere else in U-Boot. So it does not seem useful to have this driver without its commands. Drop this option, move the header file out of the common include/ directory and make all the function static. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Heiko Schocher <hs@denx.de>
2016-01-19Add more SPDX-License-Identifier tagsTom Rini
In a number of places we had wordings of the GPL (or LGPL in a few cases) license text that were split in such a way that it wasn't caught previously. Convert all of these to the correct SPDX-License-Identifier tag. Signed-off-by: Tom Rini <trini@konsulko.com>
2009-01-24Add support for Maxim's DS4510 I2C devicePeter Tyser
Initial support for the DS4510, a CPU supervisor with integrated EEPROM, SRAM, and 4 programmable non-volatile GPIO pins. The CONFIG_DS4510 define enables support for the device while the CONFIG_CMD_DS4510 define enables the ds4510 command. The additional CONFIG_DS4510_INFO, CONFIG_DS4510_MEM, and CONFIG_DS4510_RST defines add additional sub-commands to the ds4510 command when defined. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
