UCLASS_USB_GADGET_GENERIC
Since the orginal way to call interrupts handle function of DM usb
gadget driver is through dm_usb_gadget_handle_interrupts(), when we want
to use two or more different gadget drivers at the same time, it will
cause error of duplicate names.
So here add a handle_interrupts function pointer instead of driectly
call dm_usb_gadget_handle_interrupts(), then the error can be avoided.
Signed-off-by: Sherry Sun <sherry.sun@nxp.com>
(cherry picked from commit 2458ddd952a6a2d2304dfe7ea34e4192cd1d5ed4)
(cherry picked from commit c9fc90db5b31a0f111f85b749a55b417b1341af3)
(cherry picked from commit d2fe116607c4f7c462de497e66b2a5c9c9f1ea8e)
(cherry picked from commit 744536ff77fdbdefa7ca2eaac6fb38d85038b2e5)
Add a new driver FLAG (DM_FLAG_IGNORE_DEFAULT_CLKS). If any driver
is set with this flag, then when probing the device, we will skip
setting the default clocks.
This is useful when clock driver can't work with some device driver.
Signed-off-by: Ye Li <ye.li@nxp.com>
(cherry picked from commit 5dd4ff270dc387111f5feb85e4020adf2d60a32f)
(cherry picked from commit 7b5950ea2999d3c4e28ab62b5ba363037ae649c3)
(cherry picked from commit aa9f568864f18cdb59b13917f0b576e28142b9c8)
(cherry picked from commit 80c48ed9b45714e44fb814775a5c320a9f144e0d)
Use parenthesis for the device_get_ops macro argument. This prevents
errors when using an expression for the parameter.
Signed-off-by: Sughosh Ganu <sughosh.ganu@linaro.org>
At present this list is used to collect items within the DSDT and SSDT
tables. It is useful for it to collect the whole tables as well, so there
is a list of what was created and which write created each one.
Refactor the code accordingly.
Move this table over to use a writer function, moving the code from the
x86 implementation.
Add a pointer to the DSDT in struct acpi_ctx so we can reference it later.
Disable this table for sandbox since we don't actually compile real ASL
code.
x86 implementation.
Use the new ACPI writer to write the base tables at the start of the area,
moving this code from the x86 implementation.
At present acpi_setup_base_tables() both sets up the ACPI context and
writes out the base tables.
We want to use an ACPI writer to write the base tables, so split this
function into two, with acpi_setup_ctx() doing the context set, and
acpi_setup_base_tables() just doing the base tables.
Disable the writer's write_acpi_tables() function for now, to avoid
build errors. It is enabled in a following patch.
At present we call lots of functions to generate the required ACPI tables.
It would be better to standardise these functions and allow them to be
automatically collected and used when needed.
Add a linker list to handle this.
It is useful to record the start of an ACPI table so that offsets from
that point can be easily calculated.
Add this to the context and set it before calling the writer method.
Sphinx expects Return: and not @return to indicate a return value.
find . -name '*.c' -exec \
sed -i 's/^\(\s\)\*\(\s*\)@return\(\s\)/\1*\2Return:\3/' {} \;
find . -name '*.h' -exec \
Signed-off-by: Heinrich Schuchardt <heinrich.schuchardt@canonical.com>
Correct Sphinx style comments in include/dm/fdtaddr.h
and add the devfdt API to the HTML documentation;
these functions are NOT compatible with live tree.
Signed-off-by: Patrick Delaunay <patrick.delaunay@foss.st.com>
Reviewed-by: Heinrich Schuchardt <heinrich.schuchardt@canonical.com>
Correct Sphinx style comments in include/dm/ofnode.h
and add the device tree node API to the HTML documentation;
the ofnode functions are compatible with Live tree or with flat
device tree.
Correct Sphinx style comments in include/dm/read.h
and add the device read from device tree API to the HTML
documentation.
Correct Sphinx style comments in include/dm/devres.h
and add the driver model device resource API, devres_*(),
to the HTML documentation.
Reviewed-by-by: Heinrich Schuchardt <heinrich.schuchardt@canonical.com>
Correct Sphinx style comments in include/dm/device.h
and add the driver model device API to the HTML documentation.
Correct Sphinx style comments in include/dm/platdata.h
and add the associated API to the HTML documentation.
Correct Sphinx style comments in include/dm/lists.h
and add the list API to the HTML documentation.
and add the associated driver model API to the HTML documentation.
Correct Sphinx style comments in include/dm/uclass.h
and add the driver model UCLASS API to the HTML documentation.
Add a function that returns some basic stats about driver model. For now
we only have two.
Prepare v2022.01-rc4
Due to a non-existing parameter name in macro's, use of those macro's will
cause a compiler error of "undefined reference".
Unfortunately, dm test doesn't fail because a wrong name ("&dev", hence it
is accidentally a valid name in the context of a caller site) is passed on.
Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org>
Fixes: f262d4ca4b2b ("dm: core: Add a way to read platdata for all
child devices")
Fixes: 903e83ee8464 ("dm: core: Add a way to iterate through children,
probing each")
UCLASS_EFI_LOADER is used for devices created by applications and
drivers loaded by U-Boots UEFI implementation.
This patch provides a new uclass (UCLASS_EFI_MEDIA) to be used for devices
that provided by a UEFI firmware calling U-Boot as an EFI application.
If the two uclasses can be unified, is left to future redesign.
These names are better used for access to devices provided by an EFI
layer. Use EFI_LOADER instead here, since these are only available in
U-Boot's EFI_LOADER layer.
Use the return value ENOSYS for unsupported API
- pinctrl_generic_set_state
- pinctrl_select_state
Add a function that returns the number of devices in a uclass. This can be
helpful in sizing an array that needs to hold a list of them.
In some cases it is useful to search just by a partial name, such as
when looking for a sibling device that has a common name substring. Add
helper functions to handle these requirements.
At present we support reading a string list a string at a time. Apart
from being inefficient, this makes it impossible to separate reading of
the devicetree into the of_to_plat() method where it belongs, since any
code which needs access to the string must read it from the devicetree.
Add a function which returns the string property as an array of pointers
to the strings, which is easily used by clients.
The details for of_property_read_string_helper() and
ofnode_read_string_index() are a little inaccurate. Fix up the comments to
avoid confusion.
This method is currently called after the platform data has been freed.
But the pre_unbind() method may wish to access this, e.g. to free some
data structures stored there.
Split the unbinding of devices into two pieces, as is done with removal.
This corrects the problem.
Also tidy a code-style issue in device_remove() while we are here.
Certain serial SERDES protocols like 1000base-x, 2500base-x, SGMII,
USXGMII can operate either in a mode where the PHY (be it on-board or
inside an SFP module) passes the link parameters (speed, duplex, pause)
to the MAC through in-band through control words standardized by IEEE
802.3 clause 37, or in a mode where the MAC must configure (force) its
link parameters based on information obtained out-of-band (MDIO reads,
guesswork etc).
In Linux, the OF node property named "managed" is parsed by the phylink
framework, and the convention is that if a driver uses phylink, then the
presence of this property means that in-band autoneg should be enabled,
otherwise it shouldn't.
To be compatible with the OF node bindings of drivers that use phylink
in Linux, introduce parsing support for this property in U-Boot too.
Signed-off-by: Vladimir Oltean <vladimir.oltean@nxp.com>
Reviewed-by: Ramon Fried <rfried.dev@gmail.com>
Add a helper to iterate over all nodes with a given compatible string.
Signed-off-by: Michael Walle <michael@walle.cc>
Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
This uclass is intended to manage IOMMUs on systems where the
IOMMUs are not in bypass mode by default. In that case U-Boot
cannot ignore the IOMMUs if it wants to use devices that need
to do DMA and sit behind such an IOMMU.
This initial IOMMU uclass implementation does not implement and
device ops and is intended for IOMMUs that have a bypass mode
that does not require address translation. Support for IOMMUs
that do require address translation is planned and device ops
will be defined when support for such IOMMUs will be added.
Signed-off-by: Mark Kettenis <kettenis@openbsd.org>
Fix up the header's include guard to contain the definition of
dm_priv_to_rw(), which was erroneously added outside of it, by moving
its #endif to the end of the file (i.e. where it belongs). This removes
the risk of compilation errors resulting from the redefinition of that
function where the header might have been (indirectly) included more
than once.
Fixes: cfb9c9b77c2 ("dm: core: Use separate priv/plat data region")
Signed-off-by: Pierre-Clément Tosi <ptosi@google.com>
Like dev_read_addr_ptr(), provide a wrapper for the indexed version.
Reviewed-by: Leo Yu-Chi Liang <ycliang@andestech.com>
At present there is only devfdt_get_addr_ptr() which only returns
the first <addr, size> pair in the 'reg' property. Add a new API
devfdt_get_addr_index_ptr() to return the indexed pointer.
https://source.denx.de/u-boot/custodians/u-boot-stm
- Disable ATAGS for STM32 MCU and MPU boards
- Disable bi_boot_params for STM32 MCU and MPU boards
- Update stm32-usbphyc node management
- Convert CONFIG_STM32_FLASH to Kconfig for STM32 MCU boards
- Convert some USB config flags to Kconfig for various boards
- Convert CONFIG_BOOTCOMMAND flag to Kconfig for STM32 F429 board
- Remove specific CONFIG_STV0991 flags
- Remove unused CONFIG_USER_LOWLEVEL_INIT flag
- Add ofdata_to_platdata() callback for stm32_spi driver
- Update for stm32f7_i2c driver
- Remove gpio_hog_probe_all() from STM32 MP1 board
- Fix bind command
Fix a regression brings by commit 84f8e36f03fa ("cmd: bind: allow to
bind driver with driver data")
As example, the following bind command doesn't work:
bind /soc/usb-otg@49000000 usb_ether
As usb_ether driver has no compatible string, it can't be find by
lists_bind_fdt(). In bind_by_node_path(), which called lists_bind_fdt(),
the driver entry is known, pass it to lists_bind_fdt() to force the driver
entry selection.
For this, add a new parameter struct *driver to lists_bind_fdt().
Fix also all lists_bind_fdt() callers.
Fixes: 84f8e36f03fa ("cmd: bind: allow to bind driver with driver data")
Signed-off-by: Patrice Chotard <patrice.chotard@foss.st.com>
Reported-by: Herbert Poetzl <herbert@13thfloor.at>
Cc: Herbert Poetzl <herbert@13thfloor.at>
Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com>
https://source.denx.de/u-boot/custodians/u-boot-microblaze into next
Xilinx changes for v2022.01-rc1
zynq:
- Enable capsule update for qspi and mmc
- Update zed DT qspi compatible string
zynqmp:
- Add missing modeboot for EMMC
- Add missing nand DT properties
- List all eeproms for SC on vck190
- Add vck190 SC psu_init
clk:
- Handle only GATE type clock for Versal
watchdog:
- Update versal driver to handle system reset
Force the mtd name of spi-nor to "nor" + the driver sequence number:
"nor0", "nor1"... beginning after the existing nor devices.
This patch is coherent with existing "nand" and "spi-nand"
mtd device names.
When CFI MTD NOR device are supported, the spi-nor index is chosen after
the last CFI device defined by CONFIG_SYS_MAX_FLASH_BANKS.
When CONFIG_SYS_MAX_FLASH_BANKS_DETECT is activated, this config
is replaced by to cfi_flash_num_flash_banks in the include file
mtd/cfi_flash.h.
This generic name "nor%d" can be use to identify the mtd spi-nor device
without knowing the real device name or the DT path of the device,
used with API get_mtd_device_nm() and is used in mtdparts command.
This patch also avoids issue when the same NOR device is present 2 times,
for example on STM32MP15F-EV1:
STM32MP> mtd list
SF: Detected mx66l51235l with page size 256 Bytes, erase size 64 KiB, \
total 64 MiB
List of MTD devices:
* nand0
- type: NAND flash
- block size: 0x40000 bytes
- min I/O: 0x1000 bytes
- OOB size: 224 bytes
- OOB available: 118 bytes
- ECC strength: 8 bits
- ECC step size: 512 bytes
- bitflip threshold: 6 bits
- 0x000000000000-0x000040000000 : "nand0"
* mx66l51235l
- device: mx66l51235l@0
- parent: spi@58003000
- driver: jedec_spi_nor
- path: /soc/spi@58003000/mx66l51235l@0
- type: NOR flash
- block size: 0x10000 bytes
- min I/O: 0x1 bytes
- 0x000000000000-0x000004000000 : "mx66l51235l"
* mx66l51235l
- device: mx66l51235l@1
- path: /soc/spi@58003000/mx66l51235l@1
- type: NOR flash
The same mtd name "mx66l51235l" identify the 2 instances
mx66l51235l@0 and mx66l51235l@1.
This patch fixes a ST32CubeProgrammer / stm32prog command issue
with nor0 target on STM32MP157C-EV1 board introduced by
commit b7f060565e31 ("mtd: spi-nor: allow registering multiple MTDs when
DM is enabled").
Fixes: b7f060565e31 ("mtd: spi-nor: allow registering multiple MTDs when DM is enabled")
[trini: Add <dm/device.h> to <mtd.h> for DM_MAX_SEQ_STR]
Now that we have a 'positive' Kconfig option, use this instead of the
negative one, which is harder to understand.
Use this new Kconfig to simplify the compilation conditions where
appropriate.
The current API is outdated as it requires a devicetree pointer.
Move these functions to use the ofnode API and update this globally. Add
some tests while we are here.
Correct the call in exynos_dsim_config_parse_dt() which is obviously
wrong.
Tighten up these comments to make the behaviour clearer.
Add UCLASS_HASH for hash driver development. Thus the
hash drivers (SW or HW-accelerated) can be developed
in the DM-based fashion.
Signed-off-by: Chia-Wei Wang <chiawei_wang@aspeedtech.com>
Define a UCLASS API for verifying ECDSA signatures. Unlike
UCLASS_MOD_EXP, which focuses strictly on modular exponentiation,
the ECDSA class focuses on verification. This is done so that it
better aligns with mach-specific implementations, such as stm32mp.
Signed-off-by: Alexandru Gagniuc <mr.nuke.me@gmail.com>
Reviewed-by: Patrick Delaunay <patrick.delaunay@foss.st.com>
At present it is possible to call uclass_get() before driver model is
inited. In fact this happens on x86 boards which use Intel FSPv1, since
mrccache_get_region() tries to get the SPI flash device very early
during init.
This has always been undefined behaviour. Previously it generally worked,
i.e. returned an error code without crashing, because gd->uclass_root_s
is zeroed and the uclass can be added despite driver model not being
ready, due to the way lists are implemented. With the change to use a
gd->uclass_root pointer, this no-longer works. For example, it causes a
hang on minnowmax.
Fix this by adding a check that driver model is ready when uclass_get() is
called. This function is called in the process of locating any device, so
it is a good place to add the check.
This fixes booting on minnowmax.
Fixes: 8a715530bb1 ("dm: core: Allow the uclass list to move")
Migrate the dm_warn function to log macro with
LOGC_DM category and LOGL_WARNING level.
This macro allows filtering with log command and allows
output on all log backend.
