path: root/include/dm
2016-02-24stm32x7: add support for stm32x7 serial driverVikas Manocha
This patch adds support for stm32f7 family usart peripheral. Signed-off-by: Vikas Manocha <vikas.manocha@st.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-02-23dm: implement a DMA uclassMugunthan V N
Implement a DMA uclass so that the devices like ethernet, spi, mmc etc can offload the data transfers from/to the device and memory. Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Jagan Teki <jteki@openedev.com>
2016-01-30video: sandbox: Allow selection of font size and console nameSimon Glass
For testing it is useful to be able to select the font size and the console driver for sandbox. Add this information to platform data and copy it to the video device when needed. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-01-28dm: Remove device_probe_child()Simon Glass
This function is not used as the use case for it did not eventuate. Remove it to avoid confusion. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-01-24ahci: Add a disk-controller uclassSimon Glass
Add a uclass ID for a disk controller. This can be used by AHCI/SATA or other controller types. There are no operations and no interface so far, but it is possible to probe a SATA device. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-01-24dm: x86: Add a northbridge uclassSimon Glass
Add a uclass for the northbridge / SDRAM controller found on some older Intel chipsets. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-01-24dm: x86: Create a driver for x86 interruptsSimon Glass
It seems likely that at some point we will want a generic interrupt uclass. But this is a big undertaking as it involves unifying code across multiple architectures. As a first step, create a simple IRQ uclass and a driver for x86. This can be generalised later as required. Adjust pirq_init() to probe this driver, which has the effect of creating routing tables and setting up the interrupt routing. This is a start towards making interrupts fit better with driver model. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-01-21dm: video: Repurpose the 'displayport' uclass to 'display'Simon Glass
The current DisplayPort uclass is too specific. The operations it provides are shared with other types of output devices, such as HDMI and LVDS LCD displays. Generalise the uclass so that it can be used with these devices as well. Adjust the uclass to handle the EDID reading and conversion to display_timing internally. Also update nyan-big which is affected by this. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-01-21dm: panel: Add a panel uclassSimon Glass
LCD panels can usefully be modelled as their own uclass. They can be probed (which powers them up ready for use). If they have a backlight, this can be enabled. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-01-21dm: backlight: Add a backlight uclassSimon Glass
LCD panels normally have a backlight which can be controlled to illuminate the LCD contents. Add a uclass to support this. Initially it only has a method to enable the backlight. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-01-21dm: pwm: Add a PWM uclassSimon Glass
Add a uclass that supports Pulse Width Modulation (PWM) devices. It provides methods to enable/disable and configure the device. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-01-21dm: core: Export uclass_find_device_by_of_offset()Simon Glass
It is sometimes useful to be able to find a device before probing it, perhaps to set up some platform data for it. Allow finding by of_offset also. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-01-21dm: pinctrl: Add a way for a GPIO driver to obtain a pin functionSimon Glass
GPIO drivers want to be able to show if a pin is enabled for input, output, or is being used by another function. Some drivers can easily find this and the code is included in the driver. For some SoCs this is more complex. Conceptually this should be handled by pinctrl rather than GPIO. Most pinctrl drivers will have this feature anyway. Add a method by which a GPIO driver can obtain the pin mux value given a GPIO reference. This avoids repeating the code in two places. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-01-21dm: Add a power sequencing uclassSimon Glass
Some devices need special sequences to be used when starting up. Add a uclass for this. Drivers can be added to provide specific features as needed. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-01-21dm: pinctrl: Add a function to parse PIN_CONFIG flagsSimon Glass
Add a function which produces a flags word from a few common PIN_CONFIG settings. This is useful for simple pinctrl drivers that don't need to worry about drive strength, etc. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-01-20dm: video: test: Add tests for the video uclassSimon Glass
Add tests that check that the video console is working correcty. Also check that text output produces the expected result. Test coverage includes character output, wrapping and scrolling. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Anatolij Gustschin <agust@denx.de>
2016-01-20dm: video: Add a uclass for the text consoleSimon Glass
The existing LCD/video interface suffers from conflating the bitmap display with text output on that display. As a result the implementation is more complex than it needs to me. We can support multiple text console drivers. Create a separate uclass to support this, with its own API. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Anatolij Gustschin <agust@denx.de>
2016-01-20dm: video: Add a video uclassSimon Glass
U-Boot has separate code for LCDs and 'video' devices. Both now use a very similar API thanks to earlier work by Nikita Kiryanov. With the driver- model conversion we should unify these into a single uclass. Unfortunately there are different features supported by each. This implementation provides for a common set of features which should serve most purposes. The intent is to support: - bitmap devices with 8, 16 and 32 bits per pixel - text console wih white on black or vice versa - rotated text console - bitmap display (BMP format) More can be added as additional boards are ported over to use driver model for video. The name 'video' is chosen for the uclass since it is more generic than LCD. Another option would be 'display' but that would introduce a third concept to U-Boot which seems like the wrong approach. The existing LCD and video init functions are not needed now, so this uclass makes no attempt to implement them. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Anatolij Gustschin <agust@denx.de>
2016-01-13serial: lpc32xx hsuart: port driver to driver modelVladimir Zapolskiy
The change ports NXP LPC32xx 14-clock UART device driver to driver model. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-01-13dm: core: Add a new api to get indexed device addressMugunthan V N
Add new api to get device address based on index. Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com> Acked-by: Jagan Teki <jteki@openedev.com> [Rebased on master] Signed-off-by: Jagan Teki <jteki@openedev.com>
2016-01-12dm: core: Add option to configure an offset for the address translationStefan Roese
Some platforms need to ability to configure an offset to the standard addresses extracted from the device-tree. This patch allows this by adding a function to DM to configure this offset (if needed). Signed-off-by: Stefan Roese <sr@denx.de> Acked-by: Simon Glass <sjg@chromium.org> Cc: Simon Glass <sjg@chromium.org> Fixed space before tab: Signed-off-by: Simon Glass <sjg@chromium.org>
2015-12-12stm32: Convert serial driver to DMKamil Lulko
Signed-off-by: Kamil Lulko <kamil.lulko@gmail.com> Cc: Simon Glass <sjg@chromium.org> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-11-19Revert "dm: Export device_remove_children / device_unbind_children"Simon Glass
This reverts commit bb52b367f6ca4a3a918e77737f4ff6a1089912d9. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-11-19dm: core: Add safe device iteration macrosSimon Glass
Add iteration macros which support unbinding a device within the loop. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-11-19dm: usb: Add support for USB keyboards with driver modelSimon Glass
Switch USB keyboards over to use driver model instead of scanning with the horrible usb_get_dev_index() function. This involves creating a new uclass for keyboards, although so far there is no API. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-11-12dm: implement a MTD uclassThomas Chou
Implement a Memory Technology Device (MTD) uclass. It should include most flash drivers in the future. Though no uclass ops are defined yet, the MTD ops could be used. The NAND flash driver is based on MTD. The CFI flash and SPI flash support MTD, too. It should make sense to convert them to MTD uclass. Signed-off-by: Thomas Chou <thomas@wytron.com.tw>
2015-11-02dm: adc: add simple ADC uclass implementationPrzemyslaw Marczak
This commit adds: - new uclass id: UCLASS_ADC - new uclass driver: drivers/adc/adc-uclass.c The new uclass's API allows for ADC operation on: * single-channel with channel selection by a number * multti-channel with channel selection by bit mask ADC uclass's functions: * single-channel: - adc_start_channel() - start channel conversion - adc_channel_data() - get conversion data - adc_channel_single_shot() - start/get conversion data * multi-channel: - adc_start_channels() - start selected channels conversion - adc_channels_data() - get conversion data - adc_channels_single_shot() - start/get conversion data for channels selected by bit mask * general: - adc_stop() - stop the conversion - adc_vdd_value() - positive reference Voltage value with polarity [uV] - adc_vss_value() - negative reference Voltage value with polarity [uV] - adc_data_mask() - conversion data bit mask The device tree can provide below constraints/properties: - vdd-polarity-negative: if true: Vdd = vdd-microvolts * (-1) - vss-polarity-negative: if true: Vss = vss-microvolts * (-1) - vdd-supply: phandle to Vdd regulator's node - vss-supply: phandle to Vss regulator's node And optional, checked only if the above corresponding, doesn't exist: - vdd-microvolts: positive reference Voltage [uV] - vss-microvolts: negative reference Voltage [uV] Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Cc: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2015-10-27Merge git://git.denx.de/u-boot-dmTom Rini
2015-10-23dm: core: Tidy up comments in device.hSimon Glass
Correct a few nits found in a recent review. Expand the comments in dev_get_driver_data() to make it clearer. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-10-23dm: core: Remove a comment about dropping per_child_auto_alloc_sizeSimon Glass
This has proven useful and we no-longer intend to remove it. Drop the comment. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-10-23dm: core: Tidy up devres commentsSimon Glass
Adjust the devres comments to be consistent with the rest of the file, and add one for the struct udevice member. Also rename the 'p' parameter to 'ptr' to avoid single-character names. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-10-23dm: core: Fix device flag whitespaceSimon Glass
Line up the flag values in the code for easier readability. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-10-23dm: core: Adjust device.h header file orderSimon Glass
Move a few functions around so that the ordering is consistent. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-10-23dm: Rename dev_get_parentdata() to dev_get_parent_priv()Simon Glass
The current name is inconsistent with other driver model data access functions. Rename it and fix up all users. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Joe Hershberger <joe.hershberger@ni.com>
2015-10-23dm: implement a Miscellaneous uclassThomas Chou
Implement a Miscellaneous uclass with generic read or write operations. This class is used only for those do not fit other more general classes. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Acked-by: Simon Glass <sjg@chromium.org>
2015-10-23dm: implement a Timer uclassThomas Chou
Implement a Timer uclass to work with lib/time.c. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Acked-by: Simon Glass <sjg@chromium.org>
2015-10-22drivers: Introduce a simplified remoteproc frameworkNishanth Menon
Many System on Chip(SoC) solutions are complex with multiple processors on the same die dedicated to either general purpose of specialized functions. Many examples do exist in today's SoCs from various vendors. Typical examples are micro controllers such as an ARM M3/M0 doing a offload of specific function such as event integration or power management or controlling camera etc. Traditionally, the responsibility of loading up such a processor with a firmware and communication has been with a High Level Operating System(HLOS) such as Linux. However, there exists classes of products where Linux would need to expect services from such a processor or the delay of Linux and operating system being able to load up such a firmware is unacceptable. To address these needs, we need some minimal capability to load such a system and ensure it is started prior to an Operating System(Linux or any other) is started up. NOTE: This is NOT meant to be a solve-all solution, instead, it tries to address certain class of SoCs and products that need such a solution. A very simple model is introduced here as part of the initial support that supports microcontrollers with internal memory (no MMU, no execution from external memory, or specific image format needs). This basic framework can then (hopefully) be extensible to other complex SoC processor support as need be. Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Nishanth Menon <nm@ti.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-09-16dm: pci: Add an inline API to test if a device is on a PCI busBin Meng
Introduce device_is_on_pci_bus() which can be utilized by driver to test if a device is on a PCI bus. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-09-02pinctrl: Add the concept of peripheral IDsSimon Glass
My original pinctrl patch operating using a peripheral ID enum. This was shared between pinmux and clock and provides an easy way to specify a device that needs to be controlled, even it is does not (yet) have a driver within driver model. Masahiro's new simple pinctrl gets around this by providing a set_state_simple() pinctrl method. By passing a device to that call the peripheral ID becomes unnecessary. If the driver needs it, it can calculate it itself and use it internally. However this does not solve the problem for peripheral clocks. The 'pure' solution would be to pass a driver to the clock uclass also. But this requires that all devices should have a driver, and a struct udevide. Also a key optimisation of the clock uclass is allowing a peripheral clock to be set even when there is no device for that clock. There may be a better way to achive the same goal, but for now it seems expedient to add in peripheral ID to the pinctrl uclass. Two methods are added - one to get the peripheral ID and one to select it. The existing set_state_simple() is effectively the union of these. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-08-31pinctrl: add pin control uclass supportMasahiro Yamada
This creates a new framework for handling of pin control devices, i.e. devices that control different aspects of package pins. This uclass handles pinmuxing and pin configuration; pinmuxing controls switching among silicon blocks that share certain physical pins, pin configuration handles electronic properties such as pin- biasing, load capacitance etc. This framework can support the same device tree bindings, but if you do not need full interface support, you can disable some features to reduce memory foot print. Typically around 1.5KB is necessary to include full-featured uclass support on ARM board (CONFIG_PINCTRL + CONFIG_PINCTRL_FULL + CONFIG_PINCTRL_GENERIC + CONFIG_PINCTRL_PINMUX), for example. We are often limited on code size for SPL. Besides, we still have many boards that do not support device tree configuration. The full pinctrl, which requires OF_CONTROL, does not make sense for those boards. So, this framework also has a Do-It-Yourself (let's say simple pinctrl) interface. With CONFIG_PINCTRL_FULL disabled, the uclass itself provides no systematic mechanism for identifying the peripheral device, applying pinctrl settings, etc. They must be done in each low-level driver. In return, you can save much memory footprint and it might be useful especially for SPL. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-08-31dm: core: allow device_bind() to not return a device pointerMasahiro Yamada
This is useful when we want to bind a device, but do not need the pointer to the device. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-08-31dm: tpm: Add a uclass for Trusted Platform ModulesSimon Glass
Add a new uclass for TPMs which uses almost the same TIS (TPM Interface Specification) as is currently implemented. Since init() is handled by the normal driver model probe() method, we don't need to implement that. Also rename the transfer method to xfer() which is a less clumbsy name. Once all drivers and users are converted to driver model we can remove the old code. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Christophe Ricard<christophe-h.ricard@st.com> Reviewed-by: Heiko Schocher <hs@denx.de>
2015-08-31dm: simplify uclass_foreach_dev() implementationMasahiro Yamada
This can be simply written with list_for_each_entry(), maybe this macro was not necessary in the first place. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-08-31serial: uniphier: drop platform data supportMasahiro Yamada
This driver is enabled only for UniPhier SoCs and ARCH_UNIPHIER now selects OF_CONTROL and SPL_OF_CONTROL. This driver no longer needs to support platform data configuration. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-08-18of: clean up OF_CONTROL ifdef conditionalsMasahiro Yamada
We have flipped CONFIG_SPL_DISABLE_OF_CONTROL. We have cleansing devices, $(SPL_) and CONFIG_IS_ENABLED(), so we are ready to clear away the ugly logic in include/fdtdec.h: #ifdef CONFIG_OF_CONTROL # if defined(CONFIG_SPL_BUILD) && !defined(SPL_OF_CONTROL) # define OF_CONTROL 0 # else # define OF_CONTROL 1 # endif #else # define OF_CONTROL 0 #endif Now CONFIG_IS_ENABLED(OF_CONTROL) is the substitute. It refers to CONFIG_OF_CONTROL for U-boot proper and CONFIG_SPL_OF_CONTROL for SPL. Also, we no longer have to cancel CONFIG_OF_CONTROL in include/config_uncmd_spl.h and scripts/Makefile.spl. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Linus Walleij <linus.walleij@linaro.org>
2015-08-18dm: drop CONFIG_DM_DEVICE_REMOVE from uncmd listMasahiro Yamada
We do not want to compile the DM remove code for SPL. Currently, we undef it in include/config_uncmd_spl.h (for C files) and in scripts/Makefile.uncmd_spl (for Makefiles). This is really ugly. This commit demonstrates how we can deprecate those two files. Use $(SPL_) for the entry in the Makfile and CONFIG_IS_ENABLED() in C files. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-08-06dm: core: Fix a typo in the uclass_get_device_by_name() commentSimon Glass
This function comment has a typo. Fix it. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-08-06dm: core: Add a way to set a device nameSimon Glass
Some devices are bound entirely by probing and do not have the benefit of a device tree to give them a name. This is very common with PCI and USB. In most cases this is fine, but we should add an official way to set a device name. This should be called in the device's bind() method. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-08-06devres: add debug command to dump device resourcesMasahiro Yamada
This new command can dump all device resources associated to each device. The fields in every line shows: - The address of the resource - The size of the resource - The name of the release function - The stage in which the resource has been acquired (BIND/PROBE) Currently, there is no driver using devres, but if such drivers are implemented, the output of this command should look like this: => dm devres - root_driver - soc - extbus - serial@54006800 bfb541e8 (8 byte) devm_kmalloc_release BIND bfb54440 (4 byte) devm_kmalloc_release PROBE bfb54460 (4 byte) devm_kmalloc_release PROBE - serial@54006900 bfb54270 (8 byte) devm_kmalloc_release BIND - gpio@55000000 - i2c@58780000 bfb5bce8 (12 byte) devm_kmalloc_release PROBE bfb5bd10 (4 byte) devm_kmalloc_release PROBE - eeprom bfb54418 (12 byte) devm_kmalloc_release BIND Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-08-06devres: make Devres optional with CONFIG_DEVRESMasahiro Yamada
Currently, Devres requires additional 16 byte for each allocation, which is not so insignificant in some cases. Add CONFIG_DEVRES to make this framework optional. If the option is disabled, devres functions fall back to non-managed variants. For example, devres_alloc() to kzalloc(), devm_kmalloc() to kmalloc(), etc. Because devres_head is also surrounded by an ifdef conditional, there is no memory overhead when CONFIG_DEVRES is disabled. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Suggested-by: Simon Glass <sjg@chromium.org> Acked-by: Simon Glass <sjg@chromium.org>
