Optional driver model handling integration.
(cherry picked from commit cbfa67a16b345cfb94840a41ee2fa0f728be296a)
It is useful in debug() statements to display the name of the uclass for a
device. Add a simple function to provide this.
On the raspberry pi, you can disable the serial port to gain dynamic frequency
scaling which can get handy at times.
However, in such a configuration the serial controller gets its rx queue filled
up with zero bytes which then happily get transmitted on to whoever calls
getc() today.
This patch adds detection logic for that case by checking whether the RX pin is
mapped to GPIO15 and disables the mini uart if it is not mapped properly.
That way we can leave the driver enabled in the tree and can determine during
runtime whether serial is usable or not, having a single binary that allows for
uart and non-uart operation.
Acked-by: Stephen Warren <swarren@wwwdotorg.org>
The ethoc device can be configured to have a private memory region
instead of having access to the main memory. In that case egress packets
must be copied into that memory for transmission and pointers to that
memory need to be passed to net_process_received_packet or returned from
the recv callback.
Signed-off-by: Max Filippov <jcmvbkbc@gmail.com>
Extract reusable parts from ethoc_init, ethoc_set_mac_address,
ethoc_send and ethoc_receive, move the rest under #ifdef CONFIG_DM_ETH.
Add U_BOOT_DRIVER, eth_ops structure and implement required methods.
Many SoCs allow power to be applied to or removed from portions of the SoC
(power domains). This may be used to save power. This API provides the
means to control such power management hardware.
We currently use dm_scan_fdt_node() to bind devices. It is an internal
function and it requires the caller to know whether we are pre- or post-
relocation.
This requirement has become quite common in drivers, so the current function
is not ideal.
Add a new function with fewer arguments, that does not require internal
headers. This can be used directly as a post_bind() method if needed.
Some SoCs have a single clock device. Provide a way to find it given its
driver name. This is handled by the linker so will fail if the name is not
found, avoiding strange errors when names change and do not match. It is
also faster than a string comparison.
The MXC UART IP can be run in DTE or DCE mode. This depends on the
board wiring and the pinmux used and hence is board specific. This
extends platform data with a new field to choose wheather DTE
mode shall be used.
Devices which use of-platdata have their own platdata. However, in many
cases the driver will have its own auto-alloced platdata, for use with the
device tree. The ofdata_to_platdata() method converts the device tree
settings to platdata.
With of-platdata we would not normally allocate the platdata since it is
provided by the U_BOOT_DEVICE() declaration. However this is inconvenient
since the of-platdata struct is closely tied to the device tree properties.
It is unlikely to exactly match the platdata needed by the driver.
In fact a useful approach is to declare platdata in the driver like this:
struct r3288_mmc_platdata {
struct dtd_rockchip_rk3288_dw_mshc of_platdata;
/* the 'normal' fields go here */
In this case we have dt_platadata available, but the normal fields are not
present, since ofdata_to_platdata() is never called. In fact driver model
doesn't allocate any space for the 'normal' fields, since it sees that there
is already platform data attached to the device.
To make this easier, adjust driver model to allocate the full size of the
struct (i.e. platdata_auto_alloc_size from the driver) and copy in the
of-platdata. This means that when the driver's bind() method is called,
the of-platdata will be present, followed by zero bytes for the empty
'normal field' portion.
A new DM_FLAG_OF_PLATDATA flag is available that indicates that the platdata
came from of-platdata. When the allocation/copy happens, the
DM_FLAG_ALLOC_PDATA flag will be set as well. The dtoc tool is updated to
output the platdata_size field, since U-Boot has no other way of knowing
the size of the of-platdata struct.
This is a flag. Adjust the name to be consistent with the other flags.
Some uclass ids are out of order. Per the comments, sort them
in alphabetical order.
This API helps to map physical register addresss pace of device to
virtual address space easily. Its just a wrapper around map_physmem()
with MAP_NOCACHE flag.
Signed-off-by: Vignesh R <vigneshr@ti.com>
Suggested-by: Simon Glass <sjg@chromium.org>
Reviewed-by: Jagan Teki <jteki@openedev.com>
Signed-off-by: Jagan Teki <jteki@openedev.com>
A reset controller is a hardware module that controls reset signals that
affect other hardware modules or chips.
This patch defines a standard API that connects reset clients (i.e. the
drivers for devices affected by reset signals) to drivers for reset
controllers/providers. Initially, DT is the only supported method for
connecting the two.
The DT binding specification (reset.txt) was taken from Linux kernel
v4.5's Documentation/devicetree/bindings/reset/reset.txt.
A mailbox is a hardware mechanism for transferring small message and/or
notifications between the CPU on which U-Boot runs and some other device
such as an auxilliary CPU running firmware or a hardware module.
This patch defines a standard API that connects mailbox clients to mailbox
providers (drivers). Initially, DT is the only supported method for
connecting the two.
The DT binding specification (mailbox.txt) was taken from Linux kernel
v4.5's Documentation/devicetree/bindings/mailbox/mailbox.txt.
The current reset API implements a method to reset the entire system.
In the near future, I'd like to introduce code that implements the device
tree reset bindings; i.e. the equivalent of the Linux kernel's reset API.
This controls resets to individual HW blocks or external chips with reset
signals. It doesn't make sense to merge the two APIs into one since they
have different semantic purposes. Resolve the naming conflict by renaming
the existing reset API to sysreset instead, so the new reset API can be
called just reset.
This will allow a driver's bind function to use the driver data. One
example is the Tegra186 GPIO driver, which instantiates child devices
for each of its GPIO ports, yet supports two different HW instances each
with a different set of ports, and identified by the udevice_id .data
field.
Provide an api to check whether the given device or machine is
compatible with the given compat string which helps in making
decisions in drivers based on device or machine compatible.
Idea taken from Linux.
Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com>
Reviewed-by: Joe Hershberger <joe.hershberger@ni.com>
Some devices have a name that is stored in allocated memory. At present
there is no mechanism to free this memory when the device is unbound.
Add a device flag to track whether a name is allocated and a function to
add the flag. Free the memory when the device is unbound.
This started as 'ahci' and was renamed to 'disk' during code review. But it
seems that this is too generic. Now that we have a 'blk' uclass, we can use
that as the generic piece, and revert to ahci for this.
Boards can now use DM serial driver, or still legacy mcf uart
driver version.
Signed-off-by: Angelo Dureghello <angelo@sysam.it>
On some platforms (e.g. x86), the return value of dev_get_addr() can't
be assigned to a pointer type variable directly. As there might be a
difference between the size of fdt_addr_t and the pointer type. On
x86 for example, "fdt_addr_t" is 64bit but "void *" only 32bit. So
assigning the register base directly in dev_get_addr() results in this
compilation warning:
warning: cast to pointer from integer of different size
This patch introduces the new function dev_get_addr_ptr() that
returns a pointer to the 'reg' address that can be used by drivers
in this case.
This function parses the reg property based on an index found in the
reg-names property. This is required for bindings that are written
using reg-names rather than hard-coding indices in reg.
Qualcom processors use proprietary bus to talk with PMIC devices -
SPMI (System Power Management Interface).
On wiring level it is similar to I2C, but on protocol level, it's
multi-master and has simple autodetection capabilities.
This commit adds simple uclass that provides bus read/write interface.
Signed-off-by: Mateusz Kulikowski <mateusz.kulikowski@gmail.com>
The RPi3 typically uses the regular UART for high-speed communication with
the Bluetooth device, leaving us the mini UART to use for the serial
console. Add support for this UART so we can use it.
Signed-off-by: Stephen Warren <swarren@wwwdotorg.org>
For Raspberry Pi, we had the input clock rate to the pl011 fixed in
the rpi.c file, but it may be changed by firmware due to user changes
to config.txt. Since the firmware always sets up the uart (default
115200 output unless the user changes it), we can just skip our own
uart init to simplify the boot process and more reliably get serial
output.
Signed-off-by: Eric Anholt <eric@anholt.net>
Tested-by: Stephen Warren <swarren@wwwdotorg.org>
Add a uclass for block devices. These provide block-oriented data access,
supporting reading, writing and erasing of whole blocks.
A common pattern is to call uclass_first_device() and then check if it
actually returns a device. Add a new function which does this, returning
an error if there are no devices in that uclass.
This patch adds support for stm32f7 family usart peripheral.
Signed-off-by: Vikas Manocha <vikas.manocha@st.com>
Implement a DMA uclass so that the devices like ethernet, spi,
mmc etc can offload the data transfers from/to the device and
memory.
For testing it is useful to be able to select the font size and the console
driver for sandbox. Add this information to platform data and copy it to
the video device when needed.
This function is not used as the use case for it did not eventuate. Remove
it to avoid confusion.
Add a uclass ID for a disk controller. This can be used by AHCI/SATA or
other controller types. There are no operations and no interface so far,
but it is possible to probe a SATA device.
Add a uclass for the northbridge / SDRAM controller found on some older
Intel chipsets.
It seems likely that at some point we will want a generic interrupt uclass.
But this is a big undertaking as it involves unifying code across multiple
architectures.
As a first step, create a simple IRQ uclass and a driver for x86. This can
be generalised later as required.
Adjust pirq_init() to probe this driver, which has the effect of creating
routing tables and setting up the interrupt routing. This is a start
towards making interrupts fit better with driver model.
The current DisplayPort uclass is too specific. The operations it provides
are shared with other types of output devices, such as HDMI and LVDS LCD
displays.
Generalise the uclass so that it can be used with these devices as well.
Adjust the uclass to handle the EDID reading and conversion to
display_timing internally.
Also update nyan-big which is affected by this.
LCD panels can usefully be modelled as their own uclass. They can be probed
(which powers them up ready for use). If they have a backlight, this can be
enabled.
LCD panels normally have a backlight which can be controlled to illuminate
the LCD contents. Add a uclass to support this. Initially it only has a
method to enable the backlight.
Add a uclass that supports Pulse Width Modulation (PWM) devices. It
provides methods to enable/disable and configure the device.
It is sometimes useful to be able to find a device before probing it,
perhaps to set up some platform data for it. Allow finding by of_offset
also.
GPIO drivers want to be able to show if a pin is enabled for input, output,
or is being used by another function. Some drivers can easily find this
and the code is included in the driver. For some SoCs this is more complex.
Conceptually this should be handled by pinctrl rather than GPIO. Most
pinctrl drivers will have this feature anyway.
Add a method by which a GPIO driver can obtain the pin mux value given a
GPIO reference. This avoids repeating the code in two places.
Some devices need special sequences to be used when starting up. Add a
uclass for this. Drivers can be added to provide specific features as
needed.
Add a function which produces a flags word from a few common PIN_CONFIG
settings. This is useful for simple pinctrl drivers that don't need to worry
about drive strength, etc.
Add tests that check that the video console is working correcty. Also check
that text output produces the expected result. Test coverage includes
character output, wrapping and scrolling.
Acked-by: Anatolij Gustschin <agust@denx.de>
The existing LCD/video interface suffers from conflating the bitmap display
with text output on that display. As a result the implementation is more
complex than it needs to me.
We can support multiple text console drivers. Create a separate uclass to
support this, with its own API.
U-Boot has separate code for LCDs and 'video' devices. Both now use a
very similar API thanks to earlier work by Nikita Kiryanov. With the driver-
model conversion we should unify these into a single uclass.
Unfortunately there are different features supported by each. This
implementation provides for a common set of features which should serve
most purposes. The intent is to support:
- bitmap devices with 8, 16 and 32 bits per pixel
- text console wih white on black or vice versa
- rotated text console
- bitmap display (BMP format)
More can be added as additional boards are ported over to use driver model
for video.
The name 'video' is chosen for the uclass since it is more generic than LCD.
Another option would be 'display' but that would introduce a third concept
to U-Boot which seems like the wrong approach.
The existing LCD and video init functions are not needed now, so this uclass
makes no attempt to implement them.
The change ports NXP LPC32xx 14-clock UART device driver to driver
model.
Signed-off-by: Vladimir Zapolskiy <vz@mleia.com>
Add new api to get device address based on index.
Acked-by: Jagan Teki <jteki@openedev.com>
[Rebased on master]
