path: root/include/dm/util.h
2015-08-06devres: add debug command to dump device resourcesMasahiro Yamada
This new command can dump all device resources associated to each device. The fields in every line shows: - The address of the resource - The size of the resource - The name of the release function - The stage in which the resource has been acquired (BIND/PROBE) Currently, there is no driver using devres, but if such drivers are implemented, the output of this command should look like this: => dm devres - root_driver - soc - extbus - serial@54006800 bfb541e8 (8 byte) devm_kmalloc_release BIND bfb54440 (4 byte) devm_kmalloc_release PROBE bfb54460 (4 byte) devm_kmalloc_release PROBE - serial@54006900 bfb54270 (8 byte) devm_kmalloc_release BIND - gpio@55000000 - i2c@58780000 bfb5bce8 (12 byte) devm_kmalloc_release PROBE bfb5bd10 (4 byte) devm_kmalloc_release PROBE - eeprom bfb54418 (12 byte) devm_kmalloc_release BIND Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-07-21dm: Move the tree/uclass dump code into its own fileSimon Glass
In SPL it is sometimes useful to be able to obtain a dump of the current driver model state. Since commands are not available, provide a way to directly call the functions to output this information. Adjust the existing commands to use these functions. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-11-21dm: Disable dm_warn() in SPLSimon Glass
Since this function can use up quite a bit of space for its strings, disable it by default in SPL. Use CONFIG_DM_WARN to re-enable it. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@ti.com>
2014-10-22dm: fix include guardMasahiro Yamada
Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-03-04dm: Add base driver model supportSimon Glass
Add driver model functionality for generic board. This includes data structures and base code for registering devices and uclasses (groups of devices with the same purpose, e.g. all I2C ports will be in the same uclass). The feature is enabled with CONFIG_DM. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Marek Vasut <marex@denx.de> Signed-off-by: Pavel Herrmann <morpheus.ibis@gmail.com> Signed-off-by: Viktor Křivák <viktor.krivak@gmail.com> Signed-off-by: Tomas Hlavacek <tmshlvck@gmail.com>
