path: root/include/dm/uclass-id.h
2019-07-05dm: Add a No-op uclassJean-Jacques Hiblot
This uclass is intended for devices that do not need any features from the uclass, including binding children. This will typically be used by devices that are used to bind child devices but do not use dm_scan_fdt_dev() to do it. That is for example the case of several USB wrappers that have 2 child devices (1 for device and 1 for host) but bind only one at a any given time. Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2019-05-05dm: cache: Create a uclass for cacheDinh Nguyen
The cache UCLASS will be used for configure settings that can be found in a CPU's L2 cache controller. Add a uclass and a test for cache. Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Dinh Nguyen <dinguyen@kernel.org>
2019-02-19dm: Fix typo 'Watchdot' -> 'Watchdog'Chris Packham
Signed-off-by: Chris Packham <judge.packham@gmail.com>
2018-12-13dm: sound: Create a uclass for soundSimon Glass
The sound driver pulls together the audio codec and i2s drivers in order to actually make sounds. It supports setup() and play() methods. The sound_find_codec_i2s() function allows locating the linked codec and i2s devices. They can be referred to from uclass-private data. Add a uclass and a test for sound. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-12-13dm: sound: Create a uclass for i2sSimon Glass
The i2s bus is commonly used with audio codecs. It provides a way to stream digital data sychronously in both directions. U-Boot only supports audio output, so this uclass is very simple, with a single tx_data() method. Add a uclass and a test for i2s. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-12-13dm: sound: Create a uclass for audio codecsSimon Glass
An audio codec provides a way to convert digital data to sound and vice versa. Add a simple uclass which just supports setting the parameters for the codec. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-12-10Merge tag 'for-master-20181210' of git://git.denx.de/u-boot-rockchipTom Rini
Improvements: - init DRAM for RK322x in SPL - add FAN53555 PMIC/regulator driver - update MicroCrystal RV3029 driver to Kconfig and sync from Linux - add bootcount uclass and first DM-driver for bootcount
2018-12-10Merge branch 'master' of git://git.denx.de/u-boot-usbTom Rini
- DWC3 and UDC cleanup
2018-12-10bootcount: add uclass for bootcountPhilipp Tomsich
The original bootcount methods do not provide an interface to DM and rely on a static configuration for I2C devices (e.g. bus, chip-addr, etc. are configured through defines statically). On a modern system that exposes multiple devices in a DTS-configurable way, this is less than optimal and a interface to DM-based devices will be desirable. This adds a simple driver that is DM-aware and configurable via DTS. If ambiguous (i.e. multiple bootcount-devices are present) the /chosen/u-boot,bootcount-device property can be used to select one bootcount device. Initially, this provides support for the following DM devices: * RTC devices Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Tested-by: Klaus Goger <klaus.goger@theobroma-systems.com>
2018-12-07dm: usb: create a new UCLASS ID for USB gadget devicesJean-Jacques Hiblot
UCLASS_USB_DEV_GENERIC was meant for USB devices connected to host controllers, not gadget devices. Adding a new UCLASS for gadget devices alone. Also move the generic DM code for USB gadgets in a separate file for clarity. Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com>
2018-12-06dm: Add Hardware Spinlock classBenjamin Gaignard
This is uclass for Hardware Spinlocks. It implements two mandatory operations: lock and unlock and one optional relax operation. Signed-off-by: Benjamin Gaignard <benjamin.gaignard@linaro.org> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Patrice Chotard <patrice.chotard@st.com>
2018-12-05dm: (re)sort uclass ids alphabeticallyPhilipp Tomsich
The comment in uclass-id.h states that "U-Boot uclasses start here - in alphabetical order" but the subsequent list is not sorted alphabetically. This reestablishes order. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2018-11-29dm: sandbox: i2c: Add a new 'emulation parent' uclassSimon Glass
Sandbox i2c works using emulation drivers which are currently children of the i2c device: rtc_0: rtc@43 { reg = <0x43>; compatible = "sandbox-rtc"; emul { compatible = "sandbox,i2c-rtc"; }; }; In this case the emulation device is attached to i2c bus on address 0x43 and provides the Real-Time-Clock (RTC) functionality. However this is not ideal, since every device on an I2C bus has a child device. This is only really the case for sandbox, but we want to avoid special-case code for sandbox. A better approach seems to be to add a separate node on the bus, an 'emulation parent'. This can be given a bogus address (such as 0xff) and hides all the emulators away. Then we can use a phandle to point from the device to the correct emualtor, and only on sandbox. The code to find an emulator does not interfere with normal i2c operation. Add a new UCLASS_I2C_EMUL_PARENT uclass which allows finding an emulator given a bus, and finding a bus given an emulator. This will be used in a follow-on patch. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-11-29dm: core: Put UCLASS_SIMPLE_BUS in orderSimon Glass
This is currently at the top in the space for internal use. But this uclass is used outside driver model and test code. Move it into the correct alpha order. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-11-14dm: Add a new uclass driver for VirtIO transport devicesBin Meng
This adds a new virtio uclass driver for “virtio” [1] family of devices that are are found in virtual environments like QEMU, yet by design they look like physical devices to the guest. The uclass driver provides child_pre_probe() and child_post_probe() methods to do some common operations for virtio device drivers like device and driver supported feature negotiation, etc. [1] http://docs.oasis-open.org/virtio/virtio/v1.0/virtio-v1.0.pdf Signed-off-by: Tuomas Tynkkynen <tuomas.tynkkynen@iki.fi> Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-10-07Add UCLASS_TEE for Trusted Execution EnvironmentJens Wiklander
Adds a uclass to interface with a TEE (Trusted Execution Environment). A TEE driver is a driver that interfaces with a trusted OS running in some secure environment, for example, TrustZone on ARM cpus, or a separate secure co-processor etc. The TEE subsystem can serve a TEE driver for a Global Platform compliant TEE, but it's not limited to only Global Platform TEEs. The over all design is based on the TEE subsystem in the Linux kernel, tailored for U-Boot. Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Igor Opaniuk <igor.opaniuk@linaro.org> Signed-off-by: Jens Wiklander <jens.wiklander@linaro.org>
2018-09-30Merge git://git.denx.de/u-boot-dmTom Rini
2018-09-29Merge branch 'master' of git://git.denx.de/u-boot-videoTom Rini
2018-09-29drivers: Add board uclassMario Six
Since there is no canonical "board device" that can be used in board files, it is difficult to use DM function for board initialization in these cases. Hence, add a uclass that implements a simple "board device", which can hold devices not suitable anywhere else in the device tree, and is also able to read encoded information, e.g. hard-wired GPIOs on a GPIO expander, read-only memory ICs, etc. that carry information about the hardware. The devices of this uclass expose methods to read generic data types (integers, strings, booleans) to encode the information provided by the hardware. Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Mario Six <mario.six@gdsys.cc>
2018-09-28W1-EEPROM: Add an W1-EEPROM uclass for 1 wire EEPROMsMaxime Ripard
We might want to access data stored onto one wire EEPROMs. Create a framework to provide a consistent API. Signed-off-by: Maxime Ripard <maxime.ripard@bootlin.com> [eugen.hristev@microchip.com: reworked patch] Signed-off-by: Eugen Hristev <eugen.hristev@microchip.com>
2018-09-28w1: Add 1-Wire uclassMaxime Ripard
We might want to use 1-Wire devices connected on boards such as EEPROMs in U-Boot. Provide a framework to be able to do that. Signed-off-by: Maxime Ripard <maxime.ripard@bootlin.com> [eugen.hristev@microchip.com: reworked] Signed-off-by: Eugen Hristev <eugen.hristev@microchip.com>
2018-09-28common: Generic loader for file systemTien Fong Chee
This is file system generic loader which can be used to load the file image from the storage into target such as memory. The consumer driver would then use this loader to program whatever, ie. the FPGA device. Signed-off-by: Tien Fong Chee <tien.fong.chee@intel.com>
2018-09-28drivers: Add OSD uclassMario Six
Some devices offer a text-based OSD (on-screen display) that can be programmatically controlled (i.e. text displayed on). Add a uclass to support such devices. Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Mario Six <mario.six@gdsys.cc>
2018-08-11axi: Add AXI sandbox driver and simple emulatorMario Six
Add test infrastructure and tests for the AXI uclass. Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Mario Six <mario.six@gdsys.cc>
2018-08-11drivers: Add AXI uclassMario Six
Add a uclass for AXI (Advanced eXtensible Interface) busses, and a driver for the gdsys IHS AXI bus on IHS FPGAs. Signed-off-by: Mario Six <mario.six@gdsys.cc> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-07-19dm: SMEM (Shared memory) uclassRamon Fried
This is a uclass for Shared memory manager drivers. A Shared Memory Manager driver implements an interface for allocating and accessing items in the memory area shared among all of the processors. Signed-off-by: Ramon Fried <ramon.fried@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2018-04-01core: ofnode: Fix translation for #size-cells == 0Mario Six
Commit 286ede6 ("drivers: core: Add translation in live tree case") made dev_get_addr always use proper bus translations for addresses read from the device tree. But this leads to problems with certain busses, e.g. I2C busses, which run into an error during translation, and hence stop working. It turns out that of_translate_address() and fdt_translate_address() stop the address translation with an error when they're asked to translate addresses for busses where #size-cells == 0 (comment from drivers/core/of_addr.c): * Note: We consider that crossing any level with #size-cells == 0 to mean * that translation is impossible (that is we are not dealing with a value * that can be mapped to a cpu physical address). This is not really specified * that way, but this is traditionally the way IBM at least do things To fix this case, we check in both the live-tree and non-live tree-case, whether the bus of the device whose address is about to be translated has size-cell size zero. If this is the case, we just read the address as a plain integer and return it, and only apply bus translations if the size-cell size if greater than zero. Signed-off-by: Mario Six <mario.six@gdsys.cc> Signed-off-by: Martin Fuzzey <mfuzzey@parkeon.com> Reported-by: Martin Fuzzey <mfuzzey@parkeon.com> Fixes: 286ede6 ("drivers: core: Add translation in live tree case") Reviewed-by: Simon Glass <sjg@chromium.org>
2018-01-22efi_driver: EFI block driverHeinrich Schuchardt
This patch provides * a uclass for EFI drivers * a EFI driver for block devices For each EFI driver the uclass * creates a handle * adds the driver binding protocol The uclass provides the bind, start, and stop entry points for the driver binding protocol. In bind() and stop() it checks if the controller implements the protocol supported by the EFI driver. In the start() function it calls the bind() function of the EFI driver. In the stop() function it destroys the child controllers. The EFI block driver binds to controllers implementing the block io protocol. When the bind function of the EFI block driver is called it creates a new U-Boot block device. It installs child handles for all partitions and installs the simple file protocol on these. The read and write functions of the EFI block driver delegate calls to the controller that it is bound to. A usage example is as following: U-Boot loads the iPXE snp.efi executable. iPXE connects an iSCSI drive and exposes a handle with the block IO protocol. It calls ConnectController. Now the EFI block driver installs the partitions with the simple file protocol. iPXE uses the simple file protocol to load Grub or the Linux Kernel. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> [agraf: add comment on calloc len] Signed-off-by: Alexander Graf <agraf@suse.de>
2017-09-10block: ide: Fix block read/write with driver modelBin Meng
This converts the IDE driver to driver model so that block read and write are fully functional. Fixes: b7c6baef ("x86: Convert MMC to driver model") Reported-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2017-08-13dm: blk: part: Add UCLASS_NVME and IF_TYPE_NVMEZhikang Zhang
This adds a new uclass id and block interface type for NVMe. Signed-off-by: Zhikang Zhang <zhikang.zhang@nxp.com> Signed-off-by: Wenbin Song <wenbin.song@nxp.com> Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Signed-off-by: Jon Nettleton <jon@solid-run.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-07-11dm: core: Test uclass_first/next_device() on probe failureSimon Glass
Add some tests which check the behaviour of uclass_first_device() and uclass_next_device() when probing of a device fails. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-09drivers: phy: add generic PHY frameworkJean-Jacques Hiblot
The PHY framework provides a set of APIs to control a PHY. This API is derived from the linux version of the generic PHY framework. Currently the API supports init(), deinit(), power_on, power_off() and reset(). The framework provides a way to get a reference to a phy from the device-tree. Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-05-08dm: Simple Watchdog uclassmaxims@google.com
This is a simple uclass for Watchdog Timers. It has four operations: start, restart, reset, stop. Drivers must implement start, restart and stop operations, while implementing reset is optional: It's default implementation expires watchdog timer in one clock tick. Signed-off-by: Maxim Sloyko <maxims@google.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-04-18sysreset: psci: support system reset in a generic way with PSCIMasahiro Yamada
If the system is running PSCI firmware, the System Reset function (func ID: 0x80000009) is supposed to be handled by PSCI, that is, the SoC/board specific reset implementation should be moved to PSCI. U-Boot should call the PSCI service according to the arm-smccc manner. The arm-smccc is supported on ARMv7 or later. Especially, ARMv8 generation SoCs are likely to run ARM Trusted Firmware BL31. In this case, U-Boot is a non-secure world boot loader, so it should not be able to reset the system directly. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-12-20dm: Add support for scsi/sata based devicesMichal Simek
All sata based drivers are bind and corresponding block device is created. Based on this find_scsi_device() is able to get back block device based on scsi_curr_dev pointer. intr_scsi() is commented now but it can be replaced by calling find_scsi_device() and scsi_scan(). scsi_dev_desc[] is commented out but common/scsi.c heavily depends on it. That's why CONFIG_SYS_SCSI_MAX_DEVICE is hardcoded to 1 and symbol is reassigned to a block description allocated by uclass. There is only one block description by device now but it doesn't need to be correct when more devices are present. scsi_bind() ensures corresponding block device creation. uclass post_probe (scsi_post_probe()) is doing low level init. SCSI/SATA DM based drivers requires to have 64bit base address as the first entry in platform data structure to setup mmio_base. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-12-09Revert "Merge branch 'master' of git://www.denx.de/git/u-boot-microblaze"Tom Rini
This reverts commit 3edc0c252257e4afed163a3a74aba24a5509b198, reversing changes made to bb135a0180c31fbd7456021fb9700b49bba7f533.
2016-12-08dm: Add support for scsi/sata based devicesMichal Simek
All sata based drivers are bind and corresponding block device is created. Based on this find_scsi_device() is able to get back block device based on scsi_curr_dev pointer. intr_scsi() is commented now but it can be replaced by calling find_scsi_device() and scsi_scan(). scsi_dev_desc[] is commented out but common/scsi.c heavily depends on it. That's why CONFIG_SYS_SCSI_MAX_DEVICE is hardcoded to 1 and symbol is reassigned to a block description allocated by uclass. There is only one block description by device now but it doesn't need to be correct when more devices are present. scsi_bind() ensures corresponding block device creation. uclass post_probe (scsi_post_probe()) is doing low level init. SCSI/SATA DM based drivers requires to have 64bit base address as the first entry in platform data structure to setup mmio_base. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Simon Glass <sjg@chromium.org> Series-changes: 2 - Use CONFIG_DM_SCSI instead of mix of DM_SCSI and DM_SATA Ceva sata has never used sata commands that's why keep it in SCSI part only. - Separate scsi_scan() for DM_SCSI and do not change cmd/scsi.c - Extend platdata Series-changes: 3 - Fix scsi_scan return path - Fix header location uclass-internal.h - Add scsi_max_devs under !DM_SCSI - Add new header device-internal because of device_probe() - Redesign block device creation algorithm - Use device_unbind in error path - Create block device with id and lun numbers (lun was there in v2) - Cleanup dev_num initialization in block device description with fixing parameters in blk_create_devicef - Create new Kconfig menu for SATA/SCSI drivers - Extend description for DM_SCSI - Fix Kconfig dependencies - Fix kernel doc format in scsi_platdata - Fix ahci_init_one - vendor variable Series-changes: 4 - Fix Kconfig entry - Remove SPL ifdef around SCSI uclass - Clean ahci_print_info() ifdef logic
2016-07-27Add a power domain framework/uclassStephen Warren
Many SoCs allow power to be applied to or removed from portions of the SoC (power domains). This may be used to save power. This API provides the means to control such power management hardware. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-07-11dm: Sort the uclass id in alphabetical orderBin Meng
Some uclass ids are out of order. Per the comments, sort them in alphabetical order. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-06-19Add a reset driver framework/uclassStephen Warren
A reset controller is a hardware module that controls reset signals that affect other hardware modules or chips. This patch defines a standard API that connects reset clients (i.e. the drivers for devices affected by reset signals) to drivers for reset controllers/providers. Initially, DT is the only supported method for connecting the two. The DT binding specification (reset.txt) was taken from Linux kernel v4.5's Documentation/devicetree/bindings/reset/reset.txt. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-05-26Add a mailbox driver framework/uclassStephen Warren
A mailbox is a hardware mechanism for transferring small message and/or notifications between the CPU on which U-Boot runs and some other device such as an auxilliary CPU running firmware or a hardware module. This patch defines a standard API that connects mailbox clients to mailbox providers (drivers). Initially, DT is the only supported method for connecting the two. The DT binding specification (mailbox.txt) was taken from Linux kernel v4.5's Documentation/devicetree/bindings/mailbox/mailbox.txt. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-05-26Rename reset to sysresetStephen Warren
The current reset API implements a method to reset the entire system. In the near future, I'd like to introduce code that implements the device tree reset bindings; i.e. the equivalent of the Linux kernel's reset API. This controls resets to individual HW blocks or external chips with reset signals. It doesn't make sense to merge the two APIs into one since they have different semantic purposes. Resolve the naming conflict by renaming the existing reset API to sysreset instead, so the new reset API can be called just reset. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-05-17dm: Rename disk uclass to ahciSimon Glass
This started as 'ahci' and was renamed to 'disk' during code review. But it seems that this is too generic. Now that we have a 'blk' uclass, we can use that as the generic piece, and revert to ahci for this. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-04-01drivers: Add SPMI bus uclassMateusz Kulikowski
Qualcom processors use proprietary bus to talk with PMIC devices - SPMI (System Power Management Interface). On wiring level it is similar to I2C, but on protocol level, it's multi-master and has simple autodetection capabilities. This commit adds simple uclass that provides bus read/write interface. Signed-off-by: Mateusz Kulikowski <mateusz.kulikowski@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2016-03-14dm: blk: Add a block-device uclassSimon Glass
Add a uclass for block devices. These provide block-oriented data access, supporting reading, writing and erasing of whole blocks. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Stephen Warren <swarren@nvidia.com>
2016-02-23dm: implement a DMA uclassMugunthan V N
Implement a DMA uclass so that the devices like ethernet, spi, mmc etc can offload the data transfers from/to the device and memory. Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Jagan Teki <jteki@openedev.com>
2016-01-24ahci: Add a disk-controller uclassSimon Glass
Add a uclass ID for a disk controller. This can be used by AHCI/SATA or other controller types. There are no operations and no interface so far, but it is possible to probe a SATA device. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-01-24dm: x86: Add a northbridge uclassSimon Glass
Add a uclass for the northbridge / SDRAM controller found on some older Intel chipsets. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-01-24dm: x86: Create a driver for x86 interruptsSimon Glass
It seems likely that at some point we will want a generic interrupt uclass. But this is a big undertaking as it involves unifying code across multiple architectures. As a first step, create a simple IRQ uclass and a driver for x86. This can be generalised later as required. Adjust pirq_init() to probe this driver, which has the effect of creating routing tables and setting up the interrupt routing. This is a start towards making interrupts fit better with driver model. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
