path: root/include/dfu.h
2013-10-20dfu:core: Export dfu_{get|free}_buf functionsLukasz Majewski
Define the dfu_get_buf() and dfu_free_buf() as global functions. They are necessary for zero copy buffer management, when DFU backend is used for storing data. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com>
2013-10-20dfu:core: Find DFU alt setting number by passing its nameLukasz Majewski
New function - dfu_get_alt() - has been added to dfu core. If present, it returns alt setting's number corresponding to passed name. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com>
2013-09-24usb:g_dnl:dfu: Download gadget and DFU function code clean upLukasz Majewski
The download gadget code and DFU function lacks of proper declarations for the case when a target board wants to use only one of available usb functions. Moreover the relevant declarations have been moved to consistent localization (like <dfu.h>). Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Cc: Marek Vasut <marex@denx.de>
2013-09-24dfu: ram supportAfzal Mohammed
DFU spec mentions it as a method to upgrade firmware (software stored in writable non-volatile memory). It also says other potential uses of DFU is beyond scope of the spec. Here such a beyond the scope use is being attempted - directly pumping binary images from host via USB to RAM. This facility is a developer centric one in that it gives advantage over upgrading non-volatile memory for testing new images every time during development and/or testing. Directly putting image onto RAM would speed up upgrade process. This and convenience was the initial thoughts that led to doing this, speed improvement over MMC was only 1 second though - 6 sec on RAM as opposed to 7 sec on MMC in beagle bone, perhaps enabling cache and/or optimizing DFU framework to avoid multiple copy for ram (if worth) may help, and on other platforms and other boot media like NAND maybe improvement would be higher. And for a platform that doesn't yet have proper DFU suppport for non-volatile media's, DFU to RAM can be used. Another minor advantage would be to increase life of mmc/nand as it would be less used during development/testing. usage: <image name> ram <start address> <size> eg. kernel ram 0x81000000 0x1000000 Downloading images to RAM using DFU is not something new, this is acheived in openmoko also. DFU on RAM can be used for extracting RAM contents to host using dfu upload. Perhaps this can be extended to io for squeezing out register dump through usb, if it is worth. Signed-off-by: Afzal Mohammed <afzal.mohd.ma@gmail.com> Cc: Heiko Schocher <hs@denx.de> Cc: Marek Vasut <marex@denx.de> Cc: Lukasz Majewski <l.majewski@samsung.com> Cc: Pantelis Antoniou <panto@antoniou-consulting.com> Cc: Gerhard Sittig <gsi@denx.de> Acked-by: Marek Vasut <marex@denx.de> Acked-by: Lukasz Majewski <l.majewski@samsung.com> Acked-by: Heiko Schocher <hs@denx.de>
2013-09-24dfu: unify mmc/nand read/write ops enumAfzal Mohammed
MMC and NAND independently defines same enumerators for read/write. Unify them by defining enum in dfu header. RAM support that is being added newly also can make use of it. Signed-off-by: Afzal Mohammed <afzal.mohd.ma@gmail.com> Cc: Heiko Schocher <hs@denx.de> Cc: Marek Vasut <marex@denx.de> Cc: Lukasz Majewski <l.majewski@samsung.com> Cc: Pantelis Antoniou <panto@antoniou-consulting.com> Acked-by: Lukasz Majewski <l.majewski@samsung.com> Acked-by: Marek Vasut <marex@denx.de> Acked-by: Heiko Schocher <hs@denx.de>
2013-09-24dfu: Extract common DFU code to handle "dfu_alt_info" environment variableLukasz Majewski
New dfu_init_env_entities() function has been extracted from cmd_dfu.c and stored at dfu core. This is a dfu centric code, so it shall be processed in the core. Change-Id: I756c5de922fa31399d8804eaadc004ee98844ec2 Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Tested-by: Heiko Schocher <hs@denx.de>
2013-09-24dfu: Make maximum DFU file size equal to default DFU data bufferLukasz Majewski
Up till now the DFU maximum file size (to be written to e.g. eMMC) was different from the DFU data buffer size. It caused errors when one buffer was smaller than data to be written. Now, the maximum DFU file size is equal to default DFU buffer size. In spite of this, user is still able to manually adjust those default values. Change-Id: Ied75d0f7b59588ebd79dae9a22af801d36622216 Signed-off-by: Lukasz Majewski <l.majewski@samsung.com>
2013-08-26dfu, nand, ubi: add partubi alt settings for updating ubi partitionHeiko Schocher
updating an ubi partition needs a completely erased mtd partition, see: http://lists.infradead.org/pipermail/linux-mtd/2011-May/035416.html So, add partubi alt setting for the dfu_alt_info environment variable to mark this partition as an ubi partition. In case we update an ubi partition, we erase after flashing the image into the partition, the remaining sektors. Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Pantelis Antoniou <panto@antoniou-consulting.com> Cc: Tom Rini <trini@ti.com> Cc: Lukasz Majewski <l.majewski@samsung.com> Cc: Kyungmin Park <kyungmin.park@samsung.com> Cc: Marek Vasut <marex@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Scott Wood <scottwood@freescale.com>
2013-07-29dfu: Implementation of target reset after communication with dfu-util's -R ↵Lukasz Majewski
switch This patch extends dfu code to support transmission with -R switch specified at dfu-util. When -R is specified, the extra USB_REQ_DFU_DETACH request is sent after successful data transmission. Then dfu resources are released and reset command is issued. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2013-06-30dfu: make data buffer size configurableHeiko Schocher
Dfu transfer uses a buffer before writing data to the raw storage device. Make the size (in bytes) of this buffer configurable through environment variable "dfu_bufsiz". Defaut value is configurable through CONFIG_SYS_DFU_DATA_BUF_SIZE Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Pantelis Antoniou <panto@antoniou-consulting.com> Cc: Tom Rini <trini@ti.com> Cc: Lukasz Majewski <l.majewski@samsung.com> Cc: Kyungmin Park <kyungmin.park@samsung.com> Cc: Marek Vasut <marex@denx.de> Cc: Wolfgang Denk <wd@denx.de> Acked-by: Tom Rini <trini@ti.com>
2013-04-10dfu: NAND specific routines for DFU operationPantelis Antoniou
Support for NAND storage devices to work with the DFU framework. Signed-off-by: Pantelis Antoniou <panto@antoniou-consulting.com> Signed-off-by: Tom Rini <trini@ti.com> Acked-by: Scott Wood <scottwood@freescale.com>
2013-04-10dfu: Change indentation of defines in <dfu.h>Tom Rini
2013-04-10dfu: Support larger than memory transfers.Pantelis Antoniou
Previously we didn't support upload/download larger than available memory. This is pretty bad when you have to update your root filesystem for example. This patch removes that limitation (and the crashes when you transfered any file larger than 4MB) by making raw image writes be done in chunks and making file maximum size be configurable. The sequence number is a 16 bit counter; make sure we handle rollover correctly. This fixes the wrong transfers for large (> 256MB) images. Also utilize a variable to handle initialization, so that we don't rely on just the counter sent by the host. Signed-off-by: Pantelis Antoniou <panto@antoniou-consulting.com> Signed-off-by: Tom Rini <trini@ti.com>
2013-04-08dfu: Increase DFU buffer size from 4MiB to 8MiBŁukasz Majewski
Increase size of DMA buffer from 4MiB to 8MiB. This is necessary due to uImage size increase. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2012-09-01dfu: DFU backend implementationLukasz Majewski
New, separate driver at ./drivers/dfu has been added. It allows platform and storage independent operation of DFU. It has been extended to use new MMC level of command abstraction. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Cc: Marek Vasut <marex@denx.de>
