path: root/include/ddr_spd.h
2010-07-26powerpc/8xxx: Enable DDR3 RDIMM supportyork
Enabled registered DIMMs using data from SPD. RDIMMs have registers which need to be configured before using. The register configuration words are stored in SPD byte 60~116 (JEDEC standard No.21-C). Software should read those RCWs and put into DDR controller before initialization. Signed-off-by: York Sun <yorksun@freescale.com>
2009-03-30fsl-ddr: add the DDR3 SPD infrastructureDave Liu
- support mirrored DIMMs, not support register DIMMs - test passed on P2020DS board with MT9JSF12872AY-1G1D1 - test passed on MPC8569MDS board with MT8JSF12864HY-1G1D1 Signed-off-by: Dave Liu <daveliu@freescale.com> Signed-off-by: Travis Wheatley <travis.wheatley@freescale.com>
2008-08-27Add proper SPD definitions for DDR1/2/3James Yang
Also adds helper functions for DDR1/2 to verify the checksum. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
