path: root/include/dataflash.h
2011-05-18ATMEL: fix dataflash (dirty) this file should be converted to struct SoC accessReinhard Meyer
Signed-off-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2008-08-09DataFlash: AT45DB021 fix and AT45DB081 supportSergey Lapin
Fix for page size of AT45DB021. Also adding bigger AT45DB081 which comes with some newer boards. Signed-off-by: Sergey Lapin <slapin@ossfans.org>
2008-07-10DataFlash AT45DB021 supportSergey Lapin
Some boards based on AT91SAM926X-EK use smaller DF chips to keep bootstrap, u-boot and its environment, using NAND or other external storage for kernel and rootfs. This patch adds support for small 1024x263 chip. Signed-off-by: Sergey Lapin <slapin@ossfans.org>
2008-04-18Clean up dataflash partitioningUlf Samuelsson
This patch removes the board dependent parts from "drivers/mtd/dataflash.c". Each board relying on this, will have the appropriate code in a new file, "partition.c" in the board directory. board Makefiles updated to use the file. The dataflash partitions are aligned on sector/page boundaries. The CONFIG_NEW_DF_PARTITION was used to create named partitions This is now the default operation, and the CONFIG variable is removed. Signed-off-by: Ulf Samuelsson <ulf@atmel.com>
2008-04-01Cleanup DataFlash partition handlingStelian Pop
DataFlash partition information has become a mess. This patch defines a single partition scheme for Atmel DataFlashes. This partition scheme will be used by all AT91CAP9 and AT91SAM9 boards. Signed-off-by: Stelian Pop <stelian@popies.net>
2007-08-14Coding style cleanup. Update CHANGELOG.Wolfgang Denk
2007-08-14Add MACH_TYPE records for several AT91 boards.Peter Pearse
Merge to two at45.c files into a common file, split to at45.c and spi.c Fix spelling error in DM9161 PHY Support. Initialize at91rm9200 board (and set LED). Add PIO control for at91rm9200dk LEDs and Mux. Change dataflash partition boundaries to be compatible with Linux 2.6. Signed-off-by: Peter Pearse <peter.pearse@arm.com> Signed-off-by: Ulf Samuelsson <ulf@atmel.com>
2004-01-02* Cleanup lowboot code for MPC5200wdenk
* Minor code cleanup (coding style) * Patch by Reinhard Meyer, 30 Dec 2003: - cpu/mpc5xxx/fec.c: added CONFIG_PHY_ADDR, added CONFIG_PHY_TYPE, - added CONFIG_PHY_ADDR to include/configs/IceCube.h, - turned debug print of PHY registers into a function (called in two places) - added support for EMK MPC5200 based modules * Fix MPC8xx PLPRCR_MFD_SHIFT typo * Add support for TQM866M modules * Fixes for TQM855M with 4 MB flash (Am29DL163 = _no_ mirror bit flash) * Fix a few compiler warnings
2003-12-06* Patch by Nicolas Lacressonnière, 12 Nov 2003:wdenk
update for for Atmel AT91RM9200DK development kit: - support for environment variables in DataFlash - Atmel DataFlash AT45DB1282 support * Patch by Jeff Carr, 11 Nov 2003: add support for new version of 8270 processors * Patches by George G. Davis, 05 Nov 2003: - only pass the ARM linux initrd tag to the kernel when an initrd is actually present - update omap1510inn configuration file
2003-06-16* Patch by Nicolas Lacressonniere, 11 Jun 2003:wdenk
Modifications for Atmel AT91RM9200DK ARM920T based development kit - Add Atmel DataFlash support for reading and writing. - Add possibility to boot a Linux from DataFlash with BOOTM command. - Add Flash detection on Atmel AT91RM9200DK (between Atmel AT49BV1614 and AT49BV1614A flashes) - Replace old Ethernet PHY layer functions - Change link address * Patch by Frank Smith, 9 Jun 2003: use CRIT_EXCEPTION for machine check on 4xx * Patch by Detlev Zundel, 13 Jun 2003: added implementation of the "carinfo" command in cmd_immap.c
