path: root/include/cpu.h
2020-05-03uclass: cpu: Add new API to get udevice for current CPUPeng Fan
When running on SoC with multiple clusters, the boot CPU may not be fixed, saying booting from cluster A or cluster B. Add a API that can return the udevice for current boot CPU. Cpu driver needs to implement is_current_cpu interface for this feature, otherwise the API only returns the first udevice in cpu uclass. Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Peng Fan <peng.fan@nxp.com> Signed-off-by: Ye Li <ye.li@nxp.com>
2020-04-16cpu: Support querying the address widthSimon Glass
Different CPUs may support different address widths, meaning the amount of memory they can address. Add a property for this to the cpu_info struct. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2018-12-18dm: cpu: Add timebase frequency to the platdataBin Meng
This adds a timebase_freq member to the 'struct cpu_platdata', to hold the "timebase-frequency" value in the cpu or /cpus node. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Lukas Auer <lukas.auer@aisec.fraunhofer.de> Reviewed-by: Anup Patel <anup@brainfault.org>
2018-09-18cpu: Add cpu_probe_all methodMario Six
Add a method to probe all CPUs of the board. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2018-09-18cpu: Fix cpu.h documentationMario Six
Documentation in cpu.h is not in kernel-doc format. Change it to comply with it. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2016-10-19cpu: Add get_vendor callbackAlexander Graf
The CPU udevice already has a few callbacks to retreive information about the currently running CPUs. This patch adds a new get_vendor() call that returns the vendor of the main CPUs. Signed-off-by: Alexander Graf <agraf@suse.de> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-10-19cpu: Add DMTF id and family fieldsAlexander Graf
For SMBIOS tables we need to know the CPU family as well as CPU IDs. This patches allocates some space for them in the cpu device and populates it on x86. Signed-off-by: Alexander Graf <agraf@suse.de> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-03-17cpu: Add support for microcode version and CPU IDSimon Glass
Some CPUs use microcode and each core can have a different version of microcode loaded. Also some CPUs support the concept of an integer ID used for identification purposes. Add support for these in the CPU uclass. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-07-14dm: cpu: Add a new get_count method to cpu uclassBin Meng
Introduce a new method 'get_count' in the UCLASS_CPU ops to get the number of CPUs in the system. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-29dm: Implement a CPU uclassSimon Glass
It is useful to be able to keep track of the available CPUs in a multi-CPU system. This uclass is mostly intended for use with SMP systems. The uclass provides methods for getting basic information about each CPU. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
