path: root/include/cpsw.h
2019-11-04net: ti: cpsw: convert to use dev/ofnode apiGrygorii Strashko
Conver TI CPSW driver to use dev/ofnode api. Signed-off-by: Grygorii Strashko <grygorii.strashko@ti.com> [trini: Add <dm/ofnode.h> to provide the prototype to ofnode] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-11-03net: ti: cpsw: add support for standard eth "max-speed" dt propertyGrygorii Strashko
This patch adds support for standard Ethernet "max-speed" DT property to allow PHY link speed limitation. Signed-off-by: Grygorii Strashko <grygorii.strashko@ti.com>
2019-04-12board: ti: am335x: Add platdata for cpsw in SPLFaiz Abbas
The SPL image overflows when cpsw dt nodes are added and SPL_OF_CONTROL is enabled. Use static platdata instead to save space. Signed-off-by: Faiz Abbas <faiz_abbas@ti.com>
2019-04-12net: ti: cpsw-common: Isolate getting syscon address from assigning macidFaiz Abbas
ti_cm_get_macid() is used to get a syscon node from the dt, read the efuse address and then assign the macid read from the address. Divide these two steps into separate functions one of which can be called from ofdata_to_platdata() while the other can be called from _probe(). This ensures that platdata can be assigned statically in a board file when OF_CONTROL is not enabled. Also add a macid_sel_compat in private data to get information about the macid byte placement. Signed-off-by: Faiz Abbas <faiz_abbas@ti.com>
2019-04-12net: ti: cpsw: Move cpsw_phy_sel() to _probe()Faiz Abbas
cpsw_phy_sel() is a configuration step that should not be in ofdata_to_platdata(). Add phy_sel_compat to the cpsw_platform_data structure so that it is accessible in _probe. Then move the call of cpsw_phy_sel() to _probe. Signed-off-by: Faiz Abbas <faiz_abbas@ti.com>
2018-09-25drivers: net: cpsw: add support to update phy addressSekhar Nori
On some boards using TI CPSW, it may be possible that PHY address was not latched correctly, and the actual address that the phy responds on is different from that set in device-tree. For example, see this problem report on beaglebone black: https://groups.google.com/d/msg/beagleboard/9mctrG26Mc8/1FuI_i5KW10J Add support to check for this condition and use the detected phy address when its safe to do so. Also, add a public API that exposes the phy address of a given slave. This can be used to update device-tree that is passed to Linux kernel. Signed-off-by: Sekhar Nori <nsekhar@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-10-13driver: net: cpsw: add support for RGMII id mode support and RMII clock ↵Mugunthan V N
source selection cpsw driver supports only selection of phy mode in control module but control module has more setting like RGMII ID mode selection, RMII clock source selection. So ported to cpsw-phy-sel driver from kernel to u-boot. Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2016-05-24drivers: net: cpsw: Add reading of DT phy-handle nodeDan Murphy
Add the ability to read the phy-handle node of the cpsw slave. Upon reading this handle the phy-id can be stored based on the reg node in the DT. The phy-handle also needs to be stored and passed to the phy to access any phy data that is available. Signed-off-by: Dan Murphy <dmurphy@ti.com> Tested-by: Mugunthan V N <mugunthanvnm@ti.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2016-05-24drivers: net: cpsw: add support for reading mac address from efuseMugunthan V N
Different TI platforms has to read with different combination to get the mac address from efuse. So add support to read mac address based on machine/device compatibles. The code is taken from Linux drivers/net/ethernet/ti/cpsw-common.c done by Tony Lindgren. Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2015-10-22drivers: net: cpsw: convert driver to adopt device driver modelMugunthan V N
adopt cpsw driver to device driver model Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2014-07-25drivers: net: cpsw: add support for using second port as ethernetMugunthan V N
Add support for using the second slave port of cpsw to be used as primary ethernet. Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com>
2014-03-04drivers: net: cpsw: add support to have phy address from cpsw platform dataMugunthan V N
Some platforms like AM437x have different EVMs with different phy addresses, so this patch adds support for passing phy address via cpsw plaform data. Also renamed phy_id to phy_addr so better understanding of the code. Reviewed-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com> [trini: Update BuR am335x_igep0033 pcm051_rev3 pcm051_rev1 cm_t335 pengwyn boards] Signed-off-by: Tom Rini <trini@ti.com>
2013-07-26drivers: net: cpsw: remove hard coding bd ram for cpswMugunthan V N
BD ram address may vary in various SOC, so removing the hardcoding and passing the same information through platform data Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com>
2012-09-01cpsw: add driver for cpsw ethernet deviceCyril Chemparathy
CPSW is an on-chip ethernet switch that is found on various SoCs from Texas Instruments. This patch adds a simple driver (based on the Linux driver) for this hardware module. This patch also adds support to clean and flush dcache during packet send and receive. Changes by Sandhya: Added support to clean and flush dcache during packet send/receive and added timeouts. Signed-off-by: Cyril Chemparathy <cyril@ti.com> Signed-off-by: Chandan Nath <chandan.nath@ti.com> Signed-off-by: Satyanarayana, Sandhya <sandhya.satyanarayana@ti.com> [Ilya: Cleaned cache handling, some style cleanup, some small fixes, use of internal RAM for descriptors] Signed-off-by: Ilya Yanok <ilya.yanok@cogentembedded.com>
