path: root/include/cortina.h
2018-06-13net/phy/cortina: Add support for CS4223 PHYVicentiu Galanopulo
Add support for Cortina CS4223 10G PHY - As per the CS4223 specs, an EEPROM module is connected to the PHY. At startup the PHY reads the firmware line and tries to load the firmware into the internal memory. - This driver reads the EEPROM status and checks if firmware has been loaded Signed-off-by: Vicentiu Galanopulo <vicentiu.galanopulo@nxp.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2014-12-05net/phy: Add support for CS4315/CS4340 PHYShengzhou Liu
Add support for Cortina CS4315/CS4340 10G PHY. - This driver loads CS43xx firmware from NOR/NAND/SPI/SD device to initialize Cortina PHY. - Cortina PHY has non-standard offset of PHY ID registers, thus we define own get_phy_id() to override default get_phy_id(). - To define macro CONFIG_PHY_CORTINA will enable this driver. Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
