path: root/include/configs
2008-11-09Merge branch 'master' of git://git.denx.de/u-boot-at91Wolfgang Denk
2008-11-09Merge branch 'master' of git://git.denx.de/u-boot-coldfireWolfgang Denk
2008-11-04Custom AFEB9260 board supportSergey Lapin
This patch provides support for AFEB9260 board, a product of OpenSource hardware and software. Some commertial projects are made with this design. A board is basically AT91SAM9260-EK with some modifications and different peripherals and different parts used. Main purpose of this project is to gain experience in hardware design. More info: http://groups.google.com/group/arm9fpga-evolution-board (In Russian only, sorry). Subversion repository: svn://194.85.238.22/home/users/george/svn/arm9eb Signed-off-by: Sergey Lapin <slapin@ossfans.org>
2008-11-03ColdFire: Add MCF5301x CPU and M53017EVB supportTsiChung Liew
Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
2008-11-03ColdFire: Add SBF support for M52277EVBTsiChung Liew
Add serial boot support Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
2008-11-03ColdFire: Use CFI driver for M5272C3TsiChung Liew
2008-11-03ColdFire: Modules header files cleanupTsiChung Liew
Consolidate ATA, ePORT, QSPI, FlexCan, PWM, RNG, MDHA, SKHA, INTC, and FlexBus structures and definitions in immap_5xxx.h to more unify modules header files. Append DSPI support for m547x_8x. SSI cleanup. Remove USB Host structure from immap_539.h. Apply changes to use FlexBus structures in mcf52x2's cpu_init.c and platform configuration files. Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
2008-11-02TQM8260: use CFI flash driver instead of custom driver.Wolfgang Denk
2008-11-02mgsuvd: remove unused defines in config file.Heiko Schocher
2008-11-02Coding Style cleanup, update CHANGELOGWolfgang Denk
2008-11-01Merge branch 'master' of git://git.denx.de/u-boot-nand-flashWolfgang Denk
2008-10-31NAND: Add NAND support for MPC8536DS boardJason Jin
This patch defines 1M TLB&LAW size for NAND on MPC8536DS, assigns 0xffa00000 for CONFIG_SYS_NAND_BASE and adds other NAND supports in config file. It also moves environment(CONFIG_ENV_ADDR) outside of u-boot image. Singed-off-by: Jason Jin <Jason.Jin@freescale.com> Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-10-31NAND: Fix CONFIG_ENV_ADDR for MPC8572DSHaiying Wang
CONFIG_ENV_ADDR should be (CONFIG_SYS_MONITOR_BASE - CONFIG_ENV_SECT_SIZE). Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-10-31ppc4xx: Update PMC440 board configurationMatthias Fuchs
Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com> Signed-off-by: Stefan Roese <sr@denx.de>
2008-10-31ppc4xx: Merge xilinx-ppc440 and xilinx-ppc405 cfgRicardo Ribalda Delgado
Xilinx ppc440 and ppc405 have many similarities. This patch merge the config files of both infrastuctures Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@uam.es> Signed-off-by: Stefan Roese <sr@denx.de>
2008-10-31ppc4xx: Correctly configure the GPIO pin muxing on ArchesStefan Roese
Arches doesn't use PerCS3 but GPIO43, so let's configure the GPIO pin multiplexing correctly Signed-off-by: Stefan Roese <sr@denx.de>
2008-10-30Merge branch 'master' of git://git.denx.de/u-boot-mpc86xxWolfgang Denk
2008-10-3086xx: remove the unused definitionDave Liu
Signed-off-by: Dave Liu <daveliu@freescale.com>
2008-10-29NAND: Add support for MPC8572DS boardHaiying Wang
This patch defines 1M TLB&LAW size for NAND on MPC8572DS, assigns 0xffa00000 for CONFIG_SYS_NAND_BASE and adds other NAND supports in config file. It also moves environment(CONFIG_ENV_ADDR) outside of u-boot image, to make room for the increased code size with NAND enabled. Signed-off-by: Jason Jin <Jason.Jin@freescale.com> Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-10-27Merge branch 'master' of git://git.denx.de/u-boot-mpc85xxWolfgang Denk
2008-10-2486xx: Convert all fsl_pci_init users to new APIsKumar Gala
Converted MPC8610HCPD, MPC8641HPCN, and SBC8641D to use fsl_pci_setup_inbound_windows() and ft_fsl_pci_setup(). With these changes the board code is a bit smaller and we get dma-ranges set in the device tree for these boards. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Andrew Fleming-AFLEMING <afleming@freescale.com> Acked-by: Jon Loeliger <jdl@freescale.com>
2008-10-2485xx: Convert all fsl_pci_init users to new APIsKumar Gala
Converted ATUM8548, MPC8536DS, MPC8544DS, MPC8548CDS, MPC8568MDS, MPC8572DS, TQM85xx, and SBC8548 to use fsl_pci_setup_inbound_windows() and ft_fsl_pci_setup(). With these changes the board code is a bit smaller and we get dma-ranges set in the device tree for these boards. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Andrew Fleming-AFLEMING <afleming@freescale.com>
2008-10-2486xx: Enable 64-bit PCI resources on all Freescale boardsKumar Gala
2008-10-2485xx: Enable 64-bit PCI resources on all Freescale boardsKumar Gala
2008-10-2485xx: remove unused config definitionDave Liu
2008-10-24ppc4xx: New board avnet fx12 minimodulGeorg Schardt
This patch adds support for the avnet fx12 minimodul. It needs the "ppc4xx: Generic architecture for xilinx ppc405" patch from Ricardo. Signed-off-by: Georg Schardt <schardt@team-ctech.de> Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@uam.es> Signed-off-by: Stefan Roese <sr@denx.de>
2008-10-24ppc4xx: Generic architecture for xilinx ppc405(v3)Ricardo Ribalda Delgado
As "ppc44x: Unification of virtex5 pp440 boards" did for the xilinx ppc440 boards, this patch presents a common architecture for all the xilinx ppc405 boards. Any custom xilinx ppc405 board can be added very easily with no code duplicity. This patch also adds a simple generic board, that can be used on almost any design with xilinx ppc405 replacing the file ppc405-generic/xparameters.h This patch is prepared to work with the latest version of EDK (10.1) Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@uam.es> Signed-off-by: Stefan Roese <sr@denx.de>
2008-10-24ppc4xx: Disable DDR2 autocalibration on Kilauea for nowStefan Roese
Since the new autocalibration still has some problems on some Kilauea boards with 200MHz DDR2 frequency we disable the autocalibration and use the hardcoded values as done before. This seems to work reliably on all known DDR2 frequencies. After the autocalibration issue is fixed we will enable it again. Signed-off-by: Stefan Roese <sr@denx.de>
2008-10-21mpc83xx: add support for switching between USB Host/Function for MPC837XEMDSAnton Vorontsov
With this patch u-boot can fixup the dr_mode and phy_type properties for the Dual-Role USB controller. While at it, also remove #ifdefs around includes, they are not needed. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-10-21mpc83xx: add ELBC NAND support for the MPC837XEMDS boardsAnton Vorontsov
Though NAND chip is replaceable on the MPC837XE-MDS boards, the current settings don't work with the default chip on the board. Nevertheless Freescale's U-Boot sets the option register correctly, so I just dumped the register from the working u-boot. My guess is that the old settings were applicable for some pilot boards, not found in the production. This patch also enables FSL ELBC driver so that we could access the NAND storage in the u-boot. The NAND support costs about 45KB, so the u-boot no longer fits into two 128KB NOR flash sectors, thus we also have to adjust environment location: add another 128KB to the monitor length. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> It is due to hardware design and logic defect, that is the I/O[0:7] of NAND chip is connected to LAD[7:0], so when the NAND chip connected to nLCS3, you have to set up the OR3[BCTLD] = '1' for normal operation, otherwise it will have bus contention due to the pin 48/25 of U60 is enabled. Setup the OR3[BCTLD] = '1' , that meaning the LBCTL is not asserted upon access to the NAND chip, keep the default state. Acked-by: Dave Liu <daveliu@freescale.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-10-21mpc83xx: fix PCI scan hang on the standalone MPC837xE-MDS boardsAnton Vorontsov
The MPC837xE-MDS board's CPLD can auto-detect if the board is on the PIB, standalone or acting as a PCI agent. User's Guide says: - When the CPLD recognizes its location on the PIB it automatically configures RCW to the PCI Host. - If the CPLD fails to recognize its location then it is automatically configured as an Agent and the PCI is configured to an external arbiter. This sounds good. Though in the standalone setup the CPLD sets PCI_HOST flag (it's ok, we can't act as PCI agents since we receive CLKIN, not PCICLK), but the CPLD doesn't set the ARBITER_ENABLE flag, and without any arbiter bad things will happen (here the board hangs during any config space reads). In this situation we must disable the PCI. And in case of anybody really want to use an external arbiter, we provide "pci_external_aribter" environment variable. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-10-21mpc83xx: add SGMII riser module support for the MPC8378E-MDS boardsAnton Vorontsov
This involves configuring the SerDes and fixing up the flags and PHY addresses for the TSECs. For Linux we also fix up the device tree. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-10-21mpc83xx: mpc8360emds: rework LBC SDRAM setupAnton Vorontsov
Currently 64M of LBC SDRAM are mapped at 0xF0000000 which makes it difficult to use (b/c then the memory is discontinuous and there is quite big memory hole between the DDR/SDRAM regions). This patch reworks LBC SDRAM setup so that now we dynamically place the LBC SDRAM near the DDR (or at 0x0 if there isn't any DDR memory). With this patch we're able to: - Boot without external DDR memory; - Use most "DDR + SDRAM" setups without need to support for sparse/discontinuous memory model in the software. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-10-21Merge branch 'master' of git://git.denx.de/u-boot-ppc4xxWolfgang Denk
2008-10-21ppc4xx: Add GDSys neo 405EP board supportDirk Eibach
Signed-off-by: Dirk Eibach <eibach@gdsys.de> Signed-off-by: Stefan Roese <sr@denx.de>
2008-10-21ppc4xx: Update configs for Netstal boardsNiklaus Giger
I reorganized my config files, putting the common stuff into netstal-common.h (got the idea by looking a amcc-common.h from Stefan). Added stuff to boot the new powerpc linux via NFS (only tested with HCU4). Signed-off-by: Niklaus Giger <niklaus.giger@netstal.com> Signed-off-by: Stefan Roese <sr@denx.de>
2008-10-21ppc4xx: Add AMCC Arches board support (dual 460GT)Adam Graham
The Arches Evaluation board is based on the AMCC 460GT SoC chip. This board is a dual processor board with each processor providing independent resources for Rapid IO, Gigabit Ethernet, and serial communications. Each 460GT has it's own 512MB DDR2 memory, 32MB NOR FLASH, UART, EEPROM and temperature sensor, along with a shared debug port. The two 460GT's will communicate with each other via shared memory, Gigabit Ethernet and x1 PCI-Express. Signed-off-by: Adam Graham <agraham@amcc.com> Signed-off-by: Victor Gallardo <vgallardo@amcc.com> Signed-off-by: Stefan Roese <sr@denx.de>
2008-10-21TQM8260: environment in flash instead EEPROM, baudrate 115kWolfgang Denk
Several customers have reported problems with the environment in EEPROM, including corrupted content after board reset. Probably the code to prevent I2C Enge Conditions is not working sufficiently. We move the environment to flash now, which allows to have a backup copy plus gives much faster boot times. Also, change the default console initialization to 115200 bps as used on most other boards. Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-10-18mgcoge: add redundant environment sectorHeiko Schocher
2008-10-18mgsuvd: update size of environmentHeiko Schocher
2008-10-18Enabled the Freescale SGMII riser card on 8536DSJason Jin
Signed-off-by: Jason Jin <Jason.jin@freescale.com>
2008-10-18Enabled the Freescale SGMII riser card on 8572DSLiu Yu
This patch based on Andy's work. Including command 'pixis_set_sgmii' support. Signed-off-by: Liu Yu <yu.liu@freescale.com>
2008-10-18Make pixis_set_sgmii more general to support MPC85xx boards.Liu Yu
The pixis sgmii command depend on the FPGA support on the board, some 85xx boards support SGMII riser card but did not support this command, define CONFIG_PIXIS_SGMII_CMD for those boards which support the sgmii command. Not like 8544, 8572 has 4 eTsec so that the other two's pixis bits are not supported by 8544. Therefor, define PIXIS_VSPEED2_MASK and PIXIS_VCFGEN1_MASK in header file for both boards. Signed-off-by: Liu Yu <yu.liu@freescale.com>
2008-10-18Add ddr interleaving suppport for MPC8572DS boardHaiying Wang
* Add board specific parameter table to choose correct cpo, clk_adjust, write_data_delay, 2T based on board ddr frequency and n_ranks. * Set odt_rd_cfg and odt_wr_cfg based on the dimm# and CS#. * Set memory controller interleaving mode to bank interleaving, and disable bank(chip select) interleaving mode by default, because the default on-board DDR DIMMs are 2x512MB single-rank. * Change CONFIG_ICS307_REFCLK_HZ from 33333333 to 33333000. Signed-off-by: James Yang <James.Yang@freescale.com> Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com>
2008-10-1885xx: Enable interrupt and setexpr commands on Freescale 85xx boardsKumar Gala
2008-10-18mgsuvd: fix compiler warning when using soft_i2c driverHeiko Schocher
2008-10-18mgsuvd: fix coding styleHeiko Schocher
2008-10-18mgcoge: added CONFIG_FIT to support the new u-boot image formatHeiko Schocher
2008-10-18mgsuvd, mgcoge: added BOOTCOUNT feature.Heiko Schocher
