path: root/include/configs
2005-03-16Adapt for U-Boot image size (new features enabled) on TQM5200wdenk
2005-03-15Update code for TQM8540 board (and 85xx in general):wdenk
- Change the name of the Ethernet driver: MOTO ENET -> ENET - Reformat boot messages - Enable redundant environment - Replace the -O2 optimization flag with -mno-string
2005-03-15Tune TQM8540 default configuration.LABEL_2005_03_15_0125wdenk
2005-03-14* Patch by David Brownell, 10 Mar 2005:wdenk
Restore copyright statements in OHCI drivers. * Add support for TQM8540 board
2005-03-14Patch by Detlev Zundel, 14 Mar 2005:wdenk
NC650: changed NAND flash addressing to using UPMB
2005-03-14INKA4x0: Allow initialization of LCD backlight dimming fromwdenk
"brightness" environment variable.
2005-03-06Add port initialization for digital I/O on INKA4x0LABEL_2005_03_06_0225wdenk
2005-03-04* Fix get_partition_info() parameter error in all other callswdenk
(common/cmd_ide.c, common/cmd_reiser.c, common/cmd_scsi.c). * Enable USB and IDE support for INKA4x0 board * Patch by Andrew Dyer, 28 February 2005: fix ext2load passing an incorrect pointer to get_partition_info() resulting in load failure for devices other than 0
2005-03-01Update for esd boards dp405 and hub405stroese
2005-02-27Add support for SRAM and 2 x Quad UARTs on INKA4x0 boardLABEL_2005_02_28_0050wdenk
2005-02-24Cleanup USB and partition defineswdenk
2005-02-24* Add support for ext2 filesystems and image timestamps to TQM5200 boardwdenk
* Add reset code for Coral-P on INKA4x0 board * Patch by Martin Krause, 28 Jun 2004: Update for TRAB board. * Fix some missing "volatile"s in MPC5xxx FEC driver
2005-02-03* Removed '--no-warn-mismatch' option from Makefile. This optionwdenk
makes 'ld' to overlook binary objects compatibility. * Moved $(PLATFORM_LIBS) from the library group (--start-group ... --end-group) outside of the group. This will make 'ld' to do _multiple_ search in the library group when resolving symbol references and do only a _single_ seach in libgcc.a after the group search. * Fix stability problems on CPC45 board again. * Make image detection for diskboot / usbboot / scsiboot more robust (also check header checksum)
2005-01-31* Update CPC45 board configuration.LABEL_2005_01_31_2245wdenk
* Add USB and PCI support for INKA4x0 board
2005-01-22Code cleanup.wdenk
2005-01-12* Patch by Robin Getz, 13 Oct 2004:wdenk
Add standalone application to change SMC91C111 MAC addresses, see examples/README.smc91111_eeprom * Patch by Xiaogeng (Shawn) Jin, 12 Oct 2004: Fix Flash support for ARM Integrator CP.
2005-01-12* Some Cleanup.wdenk
* Patch by Richard Woodruff, 10 Jan 2005: Update support for OMAP2420 (ARM11) and H4 board: o clean up and add new types to H4 memory probe code. o fix to work with internal boot. o added PRCM config III operation. o fix marginal flash timings. o add revison ATAG usage. o enable voltage scaling at power chip. o fix compile error for i2c. * Fix network problem (error when receiving multiple ARP packets)
2005-01-10Coding Style cleanupwdenk
2005-01-09* Patch by Daniel Poirot, 10 Oct 2004:wdenk
Add support for Wind River sbc405 board * Patch by Rainer Brestan, 12 Oct 2004: Make examples/Makefile more robust
2005-01-09* Patch by Sam Song, 11 October 2004:wdenk
- Add RESET/PREBOOT/AUTOBOOT support for RPXlite_DW board - Adjust CPU:BUS frequency ratio 1:1 when core frequency less than 50MHz * Patch by Sam Song, 10 Oct 2004: Fix a parameter error in run_command() in main.c
2005-01-09* Patches by Richard Woodruff, 01 Oct 2004:wdenk
add support for the TI OMAP2420 processor and its H4 reference board * Patch by Christian Pellegrin, 24 Sep 2004: Added support for NE2000 compatible (DP8390, DP83902) NICs.
2005-01-09* Patch by Leif Lindholm, 23 Sep 2004:wdenk
add support for the AMD db1550 board * Patch by Travis Sawyer, 15 Sep 2004: Add CONFIG_SERIAL_MULTI support for ppc4xx, update README.serial_multi
2005-01-09Patches by David Snowdon, 07 Sep 2004:wdenk
- add u-boot.hex target in the top level Makefile - add support for the UNSW/NICTA PLEB 2 board (pleb2) - use -mtune=xscale and -march=armv5 options for PXA
2005-01-09Patch by Florian Schlote, 08 Sep 2004:wdenk
Add support for SenTec-COBRA5272-board (Coldfire).
2005-01-09* Patch by Kurt Stremerch, 03 Sep 2004:wdenk
Add Xilinx Spartan2E family FPGA support * Patch by Jeff Angielski, 02 Sep 2004: Add Added support for H2 revision of the EP8260 board. Fixed formatting for some of the EP8260 related source files.
2005-01-09* Patch by Jon Loeliger, 02 Sep 2004:wdenk
Reset monitor size back to 256 so environment can be written to flash on MPC85xx ADS and CDS releases. * Patch by Paolo Broggini, 02 Sep 2004: Make BSS clearing on ARM systems more robust * Patch by Yue Hu and Joe, 01 Sep 2004: - add PCI support for ixp425; - add EEPRO100 suppor tfor ixdp425 board. * Fix problem with protected sector detection in driver/cfi_flash.c
2004-12-31* Code cleanup, mostly for GCC-3.3.xwdenk
* Cleanup confusing use of CONFIG_ETH*ADDR - ust his only to pre-define a MAC address; use CONFIG_HAS_ETH* to enable support for additional ethernet addresses. * Cleanup drivers/i82365.c - avoid duplication of code * Fix bogus "cannot span across banks" flash error message * Add support for CompactFlash for the CPC45 Board.
2004-12-19* Fix problems with CMC_PU2 flash driver.LABEL_2004_12_19_2240wdenk
* Adjust INKA 4x0 default settings
2004-12-19Renamed UC100 => uc100LABEL_2004_12_19_1100wdenk
2004-12-19Cleanup: avoid trigraph warning in fs/ext2/ext2fs.c; rename UC100 -> uc100wdenk
2004-12-18Add support for UC100 boardLABEL_2004_12_18_2335wdenk
2004-12-16Code cleanup.wdenk
2004-12-16esd config files updatedstroese
2004-12-16Add support for INKA4X0 boardwdenk
2004-12-14Cleanup for CMC_PU2 boardwdenk
2004-12-12Patch by Martin Krause, 27 Oct 2004:wdenk
- add support for "STK52xx" board (including PS/2 multiplexer) - add hardware detection for TQM5200
2004-11-24* Fix udelay() on AT91RM9200 for delays < 1 ms.LABEL_2004_11_25_0035wdenk
* Enable long help on CMC PU2 board; fix reset issue; increase CPU speed from 179 to 207 MHz.
2004-11-21* Update for AT91RM9200DK and CMC_PU2 boards:wdenk
- Enable booting directly from flash - fix CMC_PU2 flash driver * Fix mkimage usage message
2004-11-17Map SRAM on NC650 boardLABEL_2004_11_17_2222wdenk
2004-11-02Work around for Ethernet problems on Xaeniax boardwdenk
2004-10-28Patch by TsiChung Liew, 23 Sep 2004:wdenk
- add support for MPC8220 CPU - Add support for Alaska and Yukon boards
2004-10-24* Fix configuration for ERIC board (needs more room)wdenk
* Adjust MIPS compiler options at run-time depending on tools version ("-march=4kc -mtune=4kc -Wa,-mips_allow_branch_to_undefined" for new, "-mcpu=4kc" for old tools)
2004-10-19Add passing of the command line and memory size information to theLABEL_2004_10_20_0020wdenk
kernel on xaeniax board.
2004-10-17Code cleanup for GCC-3.3.x compilerswdenk
2004-10-11CleanupLABEL_2004_10_12_0110wdenk
2004-10-11* Enable NAND flash support for NC650 board.wdenk
* Patch by Thomas Lange 07 Oct 2004: Updated README for DBAu1x00 boards to match current status
2004-10-11* Patch by Philippe Robin, 28 Sept 2004:wdenk
Fix Flash support for Versatile. * Patch by Roger Blofeld, 16 Sep 2004: Fix timeout for DHCP command retry
2004-10-11Fix CFG_HZ problems on AT91RM9200 systemswdenk
[Remember: CFG_HZ should be 1000 on ALL systems!]
2004-10-10* Patch by Gridish Shlomi, 30 Aug 2004:wdenk
- Add support to revA version of PQ27 and PQ27E. - Reverted MPC8260ADS baudrate back to original 115200 * Patch by Hojin, 17 Sep 2004: Fix typo in cfi_flash.c * Patch by Mark Jonas, 09 September 2004: mtest's data line test (with CFG_ALT_MEMTEST set) returned a wrong error message * Patch by Mark Jonas, 31 August 2004: Added option CFG_XLB_PIPELINING to enable XLB pipelining. This improves FTP performance for MPC5200 systems. Enabled for IceCube by default.
2004-10-10* Patch by Michael Bendzick, 30 Aug 2004:wdenk
- Improve platform.S code for omap1510inn that detects whether code is running from SDRAM or not. Patch allows SDRAM to be configured if code is running out of SRAM at 0x20000000. * Patch by Frederick Klatt, 30 Aug 2004: Add support for the Wind River SBC8540/SBC8560 boards
