* Add PCI support for SL8245 board
* Support IceCube board configurations with 1 x AMD AM29LV065 (8 MB)
or 1 x AM29LV652 (two LV065 in one chip = 16 MB);
Run IPB at 133 Mhz; adjust the MII clock frequency accordingly
* Set BRG_CLK on PM825/826 to 64MHz (VCO_OUT / 4, instead of 16 MHz)
to allow for more accurate baudrate settings
(error now 0.7% at 115 kbps, instead of 3.5% before)
* Patch by Andreas Mohr, 4 Sep 2003:
Fix a lot of spelling errors
* Add support for P3G4 board
* Fix problem with MGT5100 FEC driver: add "early" MAC address
initialization
According to the MPC8260 User's Manual, PCI_MODE signal should be
reflected in SCCR register, and local bus pins configuration is taken
from HRCW and appears in SIUMCR. For some reason it does not work
this way, so the only possibility to detect if the board is
configured in PCI mode is to check the BCSR. This patch sets SCCR and
SIUMCR according to the BCSR.
add support for Adder II MPC852T module
fix TI Innovator/OMAP1510 pin configs
* Patches by Kshitij, 18 Aug 2003
- add support for arm926ejs cpu core
- add support for TI OMAP 1610 Innovator Board
(because of better response to iprobe command); fix problem with
"reset" command
* Fix RAM size detection for RMU board
* Implement "reset" for MGT5100/MPC5200 systems
allow selection of clock frequency as "make" target
* Implement memory autosizing code for IceCube boards
* Configure network port on INCA-IP for autonegotiation
* Fix overflow problem in network timeout code
* Patch by Richard Woodruff, 8 Aug 2003:
Allow crc32 to be used at address 0x000 (crc32_no_comp, too).
disable clocks_in_mhz, enable boot count limit
* Patch by Brad Parker, 02 Aug 2003:
fix sc520_cdp problems
* Implement Boot Cycle Detection (Req. 2.3 of OSDL CGL Reqirements)
* Allow erase command to cross flash bank boundaries
Add support for LynuxWorks Kernel Downloadable Images (KDIs).
Both LynxOS and BlueCat linux KDIs are supported.
* Patch by Richard Woodruff, 25 Jul 2003:
use more reliable reset for OMAP/925T
* Patch by Nye Liu, 25 Jul 2003:
fix typo in mpc8xx.h
* Patch by Richard Woodruff, 24 Jul 2003:
Fixes for cmd_nand.c:
- Fixed null dereferece which could result in incorrect ECC values.
- Added support for devices with no Ready/Busy signal hooked up.
- Added OMAP1510 read/write protect handling.
- Fixed nand.h's ECCPOS. A conflict existed with POS5 and badblock
for non-JFFS2.
- Switched default ECC to be JFFS2.
* Provide consistent interface to standalone applications to access
the 'global_data' structure
Provide a doc/README.standalone more useful to users/developers.
* Make IceCube MGT5100 FEC driver work
applications: instead of using (PPC-specific) system calls we now
use a jump table; please see doc/README.standalone for details
* Patch by Dave Westwood, 24 Jul 2003:
added support for Unity OS (a proprietary OS)
add delay to get I2C working with "imm" command and s3c24x0_i2c.c
* Patch by Richard Woodruff, 17 July 03:
- Fixed bug in OMAP1510 baud rate divisor settings.
* Patch by Nye Liu, 16 July 2003:
MPC860FADS fixes:
- add MPC86xADS support (uses MPC86xADS.h)
- add 866P/T core support (also MPC859T/MPC859DSL/MPC852T)
o PLPRCR changes
o BRG changes (EXTAL/XTAL restricted to 10MHz)
o don't trust gclk() software measurement by default, depend on
CONFIG_8xx_GCLK_FREQ
- add DRAM SIMM not installed detection
- use more "correct" SDRAM initialization sequence
- allow different SDRAM sizes (8xxADS has 8M)
- default DER is 0
- remove unused MAMR defines from FADS860T.h (all done in fads.c)
- rename MAMR/MBMR defines to be more consistent. Should eventually
be merged into MxMR to better reflect the PowerQUICC datasheet.
* Patch by Yuli Barcohen, 16 Jul 2003:
support new Motorola PQ2FADS-ZU evaluation board which replaced
MPC8260ADS and MPC8266ADS
- added support for arm925t cpu core
- added support for TI OMAP 1510 Innovator Board
- add I2C support for s3c2400 systems (trab board)
- (re-) add "ping" to command table
* Fix handling of "slow" POST routines
- Correct flash and JFFS2 support for MPC8260ADS
- fix PVR values and clock generation for PowerQUICC II family
(8270/8275/8280)
* Patch by Bernhard Kuhn, 08 Jul 2003:
- add support for M68K targets
* Patch by Ken Chou, 3 Jul:
- Fix PCI config table for A3000
- Fix iobase for natsemi.c
(PCI_BASE_ADDRESS_0 is the IO base register for DP83815)
* Allow to enable "slow" POST routines by key press on power-on
* Fix temperature dependend switching of LCD backlight on LWMON
* Tweak output format for LWMON
* Add support for TQM823M, TQM850M, TQM855M and TQM860M modules
* Add support for Am29LV160ML, Am29LV320ML, and Am29LV640ML
mirror bit flash on TQM8xxM modules
(autoscript, bmp, bsp, fat, mmc, nand, portio, ...)
- Allow to call sysmon function interactively
- PIC on LWMON board needs delay after power-on
- Add missing RSR definitions for MPC8xx
- Improve log buffer handling: guarantee clean reset after power-on
- Add support for EXBITGEN board
- Add support for SL8245 board
- remove trailing white space, trailing empty lines, C++ comments, etc.
- split cmd_boot.c (separate cmd_bdinfo.c and cmd_load.c)
* Patches by Kenneth Johansson, 25 Jun 2003:
- major rework of command structure
(work done mostly by Michal Cendrowski and Joakim Kristiansen)
- logdl
- csb226
- innokom
* Patch by Pantelis Antoniou, 25 Jun 2003:
update NetVia with V2 board support
Update for MPC8260ADS board
* Patch by Murray Jensen, 23 Jun 2003:
- cleanup of GCC 3.x compiler warnings
(0xf5000000, to be specific). The reason is that the RTC first gets
accessed before MMU is initialized and, consequently, it needs to be
placed at physical addresses which are later mapped to the same
virtual addresses (like 0xf5000000 physical is mapped to 0xf5000000
virtual).
- hymod update
- cleanup (especially for gcc-3.x compilers)
Fix clock divider rounding problem in drivers/serial.c
* Patch by Ken Chou, 19 June 2003:
Added support for A3000 SBC board (Artis Microsystems Inc.)
- Hymod board database mods: add "who" field and new xilinx chip types
- provide new "init_cmd_timeout()" function so code external to
"common/main.c" can use the "reset_cmd_timeout()" function before
entering the main loop
- add DTT support for adm1021 (new file dtt/adm1021.c; config
slightly different. see include/configs/hymod.h for an example
(requires CONFIG_DTT_ADM1021, CONFIG_DTT_SENSORS, and
CFG_DTT_ADM1021 defined)
- add new "eeprom_probe()" function which has similar args and
behaves in a similar way to "eeprom_read()" etc.
- add 8260 FCC ethernet loopback code (new "eth_loopback_test()"
function which is enabled by defining CONFIG_ETHER_LOOPBACK_TEST)
- gdbtools copyright update
- ensure that set_msr() executes the "sync" and "isync" instructions
after the "mtmsr" instruction in cpu/mpc8260/interrupts.c
- 8260 I/O ports fix: Open Drain should be set last when configuring
- add SIU IRQ defines for 8260
- allow LDSCRIPT override and OBJCFLAGS initialization: change to
config.mk to allow board configurations to override the GNU
linker script, selected via the LDSCRIPT, make variable, and to
give an initial value to the OBJCFLAGS make variable
- 8260 i2c enhancement:
o correctly extends the timeout depending on the size of all
queued messages for both transmit and receive
o will not continue with receive if transmit times out
o ensures that the error callback is done for all queued tx
and rx messages
o correctly detects both tx and rx timeouts, only delivers one to
the callback, and does not overwrite an earlier error
o logic in i2c_probe now correct
- add "vprintf()" function so that "panic()" function can be
technically correct
- many Hymod board changes
- add support for Logotronic DL datalogger board
- cleanup serial line after kermit binary download
- add debugX macro (debug level support)
- update mach-types.h to latest arm.linux.org.uk master list.
- rewrite of the S3C24X0 register definitions stuff
- "driver" for the built-in S3C24X0 RTC
* Patches by Yuli Barcohen, 12 Jun 2003:
- Add MII support and Ethernet PHY initialization for MPC8260ADS board
- Fix incorrect SIUMCR initialisation caused by wrong Hard Reset
configuration word supplied by FPGA on some MPC8260ADS boards
* Patch by Pantelis Antoniou, 10 Jun 2003:
Unify status LED interface
Modifications for Atmel AT91RM9200DK ARM920T based development kit
- Add Atmel DataFlash support for reading and writing.
- Add possibility to boot a Linux from DataFlash with BOOTM command.
- Add Flash detection on Atmel AT91RM9200DK
(between Atmel AT49BV1614 and AT49BV1614A flashes)
- Replace old Ethernet PHY layer functions
- Change link address
* Patch by Frank Smith, 9 Jun 2003:
use CRIT_EXCEPTION for machine check on 4xx
* Patch by Detlev Zundel, 13 Jun 2003:
added implementation of the "carinfo" command in cmd_immap.c
* Patches by Kyle Harris, 13 Mar 2003:
- Add FAT partition support
- Add command support for FAT
- Add command support for MMC
- Add Intel PXA support for video
- Add Intel PXA support for MMC
- Enable MMC and FAT for lubbock board
- Other misc changes for lubbock board
* Add support for TQM862L at 100/50 MHz
* Patch by Pantelis Antoniou, 02 Jun 2003:
major reconstruction of networking code;
add "ping" support (outgoing only!)
add support for the MIP405T board
- Added support for custom keyboards, initialized by defining a
board-specific drv_keyboard_init as well as defining CONFIG_KEYBOARD .
- Added support for the RBC823 board.
- cpu/mpc8xx/lcd.c now automatically calculates the
Horizontal Pixel Count field.
* Fix alignment problem in BOOTP (dhcp_leasetime option)
[pointed out by Nicolas Lacressonnière, 2 Jun 2003]
* Patch by Mark Rakes, 14 May 2003:
add support for Intel e1000 gig cards.
* Patch by Nye Liu, 3 Jun 2003:
fix critical typo in MAMR definition (include/mpc8xx.h)
* Fix requirement to align U-Boot image on 16 kB boundaries on PPC.
* Patch by Klaus Heydeck, 2 Jun 2003
Minor changes for KUP4K configuration
Fixed rarp boot method for IA32 and other little-endian CPUs.
* Patch by Marc Singer, 28 May 2003:
Added port I/O commands.
* Patch by Matthew McClintock, 28 May 2003
- cpu/mpc824x/start.S: fix relocation code when booting from RAM
- minor patches for utx8245
* Patch by Daniel Engström, 28 May 2003:
x86 update
* Patch by Dave Ellis, 9 May 2003 + 27 May 2003:
add nand flash support to SXNI855T configuration
fix/extend nand flash support:
- fix 'nand erase' command so does not erase bad blocks
- fix 'nand write' command so does not write to bad blocks
- fix nand_probe() so handles no flash detected properly
- add doc/README.nand
- add .jffs2 and .oob options to nand read/write
- add 'nand bad' command to list bad blocks
- add 'clean' option to 'nand erase' to write JFFS2 clean markers
- make NAND read/write faster
* Patch by Rune Torgersen, 23 May 2003:
Update for MPC8266ADS board
instead CFG_MONITOR_LEN is now only used to determine _at_compile_
_time_ (!) if the environment is embedded within the U-Boot image,
or in a separate flash sector.
* Cleanup CFG_DER #defines in config files (wd maintained only)
add support for the MIP405-3 board
