path: root/include/configs
2011-07-11powerpc/85xx: Add default usb mode and phy type to hwconfigRamneek Mehresh
Move to use hwconfig for usb mode & phy type instead of magic 'usb_phy_type' environment variable on the following platforms: MPC8536DS, P1020RDB, P1020RDB-PC, P1010RDB, P2020RDB, P2020RDB-PC, P2020RDB, P3041DS, P4080DS, & P5020DS. Signed-off-by: Ramneek Mehresh <ramneek.mehresh@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-07-11powerpc/corenet_ds: add back buffer write for NOR flashYork Sun
Enable buffer write for better performance. This platform uses a NOR flash chip which supports write buffer programming. CFI driver can query the buffer size and use it to program the flash for best performance. Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-07-11powerpc/85xx: Add basic support for P1023RDS boardRoy Zang
The P1023RDS board is the reference board for the P1023 SoC. Add support for booting it from NOR or NAND, with fixed 2G of DDR, PCIe, UART, I2C, etc. Signed-off-by: Roy Zang <tie-fei.zang@freescale.com> Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com> Signed-off-by: Chunhe Lan <Chunhe.Lan@freescale.com> Signed-off-by: Lei Xu <B33228@freescale.com> Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-07-11powerpc/85xx: Add NAND boot support for P3041/P5020DSShaohui Xie
When booting from NAND we get the environment and FMan ucode from NAND. Signed-off-by: Shaohui Xie <b21989@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-07-11qoriq/p1_p2_rdb: Add Dual Role USB support macro for P1020RDBRamneek Mehresh
Add CONFIG_HAS_FSL_DR_USB macro for P1020RDB Signed-off-by: Ramneek Mehresh <ramneek.mehresh@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-07-06powerpc/83xx: remove empty board_early_init_f()Timur Tabi
Remove an empty board_early_init_f() from the MPC8323ERD and MPC360ERDK boards. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2011-07-06mpc83xx: Add support for MergerBox boardAndre Schwarz
Includes board config file, documentation, maintainer and boards.cfg entries, and board specific files in vendor dir. Signed-off-by: Andre Schwarz <andre.schwarz@matrix-vision.de> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2011-07-04Add support for Network Space v2 and parentsSimon Guinot
This patch add support for the Network Space v2 board and parents, based on the Marvell Kirkwood 6281 SoC. This include Network Space (Max) v2 and Internet Space v2. Additional information is available at: http://lacie-nas.org/doku.php?id=network_space_v2 Signed-off-by: Simon Guinot <sguinot@lacie.com>
2011-07-04arm/km: add support for portl2 boardValentin Longchamp
This adds support for the keymile Kirkwood BEC portl2 board. This board relies on the km_arm (km_kirkwood) BEC. The egiga driver is configured for a 100M full-duplex, A/N off connnection to the backplane. This board has always ethernet present, because it is connected to the marvell switch similar to mgcoge3un. The reset_phy functionality is also the same to mgcoge3un. Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> Signed-off-by: Holger Brunck <holger.brunck@keymile.com> cc: Prafulla Wadaskar <prafulla@marvell.com> cc: Heiko Schocher <hs@denx.de>
2011-07-04arm/km: replace suenx targets with km_kirkwoodHolger Brunck
suen3 and suen8 were in first HW version quite different, but now they are from a u-boot point of view similar. So these two boards can use the same header file. Other keymile boards differ only in the usage of the PCI interface. Therefore a target km_kirkwood_pci was introduced. All targets use the same header file. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> cc: Prafulla Wadaskar <prafulla@marvell.com> cc: Heiko Schocher <hs@denx.de>
2011-07-04arm/km: use board KM_ENV_BUS for CONFIG_I2C_ENV_EEPROM_BUSValentin Longchamp
This is defined for all km_kirkwood boards and was not used up to now. This value was the same for all boards but it could be changed for some boards (and thus needs to be defined for every board). Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> Signed-off-by: Holger Brunck <holger.brunck@keymile.com> cc: Prafulla Wadaskar <prafulla@marvell.com> cc: Heiko Schocher <hs@denx.de>
2011-07-04arm/km: remove unneeded defineHolger Brunck
CONFIG_ENV_SIZE for NAND was later in this file overwritten because we have the environment in i2c eeprom, so remove this define. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> cc: Prafulla Wadaskar <prafulla@marvell.com> cc: Heiko Schocher <hs@denx.de>
2011-07-04arm/km: fix u-boot.kwb build breakageHolger Brunck
commit 010a958b (arm/km: remove CONFIG_SYS_KWD_CONFIG from keymile-common.h) breaks building keymile arm targets, when u-boot.kwb tries to generate the binary with mkimage. A simple make <board> or MAKEALL succeeded because it don't try to build the kirwood binary at the end. Due this commit we use the CONFIG_SYS_KWD_CONFIG from the arch-kirkwood/config.h and it was removed from the board config. But it was forgotten to include the header. Now the header is included in km_arm.h. Some other defines were obsolete due to this include, these are also removed in this commit. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> cc: Valentin Longchamp <valentin.longchamp@keymile.com> cc: Prafulla Wadaskar <prafulla@marvell.com> cc: Heiko Schocher <hs@denx.de>
2011-07-04atstk100x: switch to common cfi driverAndreas Bießmann
This patch removes the board implemenatation for flash driver which can now safely switched to the common cfi driver. Compile tested for all atstk100x boards, runtime tested on atstk1002. Signed-off-by: Andreas Bießmann <biessmann@corscience.de>
2011-07-04cpuat91: use atmel_usartAndreas Bießmann
Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> Cc: Eric Bénard <eric@eukrea.com>
2011-07-04eb_cpux9k2: use atmel_usartAndreas Bießmann
Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> CC: Jens Scharsig <js_at_ng@scharsoft.de> Acked-by: Jens Scharsig<js_at_ng@scharsoft.de> Tested-by: Jens Scharsig<js_at_ng@scharsoft.de> (for eb_cpux9k2 board)
2011-07-04at91rm9200ek: use atmel_usartAndreas Bießmann
2011-07-04arm920t/at91: use new clock.c featuresAndreas Bießmann
This patch enables the new clock features from arm920t/at91/clock.c. This is an required step to get at91rm9200_usart replaced by atmel_usart driver. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> Cc: Jens Scharsig <js_at_ng@scharsoft.de> Cc: Eric Bénard <eric@eukrea.com>
2011-07-04MX53: Add initial support for MX53ARDFabio Estevam
2011-07-04arm: Update jadecpu boardMatthias Weisser
Enable dcache and arch memset/memcpy for speed reasons Remove of config.mk and some environment overwrites Some generic cleanup Signed-off-by: Matthias Weisser <weisserm@arcor.de>
2011-07-04arm: omap2: apollon: fix broken buildIgor Grinberg
Define CONFIG_SYS_SDRAM_BASE to physical SDRAM address and CONFIG_SYS_INIT_SP_ADDR to physical SRAM address Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Cc: Kyungmin Park <kyungmin.park@samsung.com>
2011-07-04arm: Tegra2: GPIO: enable GPIO for Tegra2 boardsTom Warren
Signed-off-by: Tom Warren <twarren@nvidia.com>
2011-07-04VCMA9: various cleanups/code style fixesDavid Müller (ELSOFT AG)
Signed-off-by: David Müller <d.mueller@elsoft.ch>
2011-07-04VCMA9: use CFI driver (and remove the old one)David Müller (ELSOFT AG)
2011-07-04VCMA9: remove unneeded config.mkDavid Müller (ELSOFT AG)
2011-07-04armv7: adapt omap4 to the new cache maintenance frameworkAneesh V
adapt omap4 to the new layered cache maintenance framework Signed-off-by: Aneesh V <aneesh@ti.com>
2011-07-04armv7: rename cache related CONFIG flagsAneesh V
Replace the cache related CONFIG flags with more meaningful names. Following are the changes: CONFIG_L2_OFF -> CONFIG_SYS_L2CACHE_OFF CONFIG_SYS_NO_ICACHE -> CONFIG_SYS_ICACHE_OFF CONFIG_SYS_NO_DCACHE -> CONFIG_SYS_DCACHE_OFF Signed-off-by: Aneesh V <aneesh@ti.com> V2: * Changed CONFIG_L2_OFF -> CONFIG_SYS_NO_L2CACHE V4: * Changed all three flags to the final names suggested as above and accordingly changed the commit message
2011-06-27Minor coding style fixes.Wolfgang Denk
2011-06-23Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
* 'master' of git://git.denx.de/u-boot-arm: run arm_pci_init after relocation IXP42x PCI rewrite update/fix PDNB3 board update/fix IXDP425 / IXDPG425 boards add dvlhost (dLAN 200 AV Wireless G) board IXP NPE: add support for fixed-speed MII ports update/fix AcTux4 board update/fix AcTux3 board update/fix AcTux2 board update/fix AcTux1 board use -ffunction-sections / --gc-sections on IXP42x support CONFIG_SYS_LDSCRIPT on ARM fix "depend" target in npe directory Fix IXP code to work after relocation was added trigger hardware watchdog in IXP42x serial driver add support for IXP42x Rev. B1 and newer add XScale sub architecture (IXP/PXA) to maintainer list Conflicts: arch/arm/lib/board.c Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-06-23update/fix PDNB3 boardMichael Schwingen
Signed-off-by: Michael Schwingen <michael@schwingen.org>
2011-06-23update/fix IXDP425 / IXDPG425 boardsMichael Schwingen
2011-06-23add dvlhost (dLAN 200 AV Wireless G) boardMichael Schwingen
2011-06-23update/fix AcTux4 boardMichael Schwingen
2011-06-23update/fix AcTux3 boardMichael Schwingen
2011-06-23update/fix AcTux2 boardMichael Schwingen
2011-06-23update/fix AcTux1 boardMichael Schwingen
2011-06-22ARM: drop unsupported 'trab' boardWolfgang Denk
The 'trab' board configuration is broken, and there is nobody who is interested and willing to fix it. Drop it. This includes support for VFD displays which have always been used by this board only. Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-06-21Build fix/update of AFEB9260Sergey Lapin
Make AFEB9260 build again. Based on fix for AT91SAM9260EK. Signed-off-by: Sergey Lapin <slapin@ossfans.org>
2011-06-21cpu9260/9G20: fix board supportEric Benard
Signed-off-by: Eric Bénard <eric@eukrea.com>
2011-06-21AT91 rework: fix TOP9000 files to build againReinhard Meyer
Fix EMK TOP9000 board to build again: - changes required due to ATMEL rework Signed-off-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2011-06-21AT91 rework: fix at91sam(9260/9g20/9xe)ek board port to build again:Reinhard Meyer
Make ATMEL's at91sam9260/9g20/9xe-ek boards build again Signed-off-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2011-06-21Add support for Bluewater Systems Snapper 9260/9G20 modulesRyan Mallon
Add support for Bluewater Systems AT91 based Snapper 9260 and 9G20 single board computer modules. Includes NAND flash and Ethernet support. Signed-off-by: Ryan Mallon <ryan@bluewatersys.com>
2011-06-21update arm/at91rm9200 work with rework rework110202Jens Scharsig
* convert at91rm9200ek and eb_cpux9k2 board to ATMEL_xxx name scheme * Fix: timer.c compile error io.h not found with arm/at91rm9200 * update arm920t/at91 to ATMEL_xxx name scheme * update arm920t/at91 soc lib * update at91_emac driver Signed-off-by: Jens Scharsig <js_at_ng@scharsoft.de> Tested-by: Andreas Bießmann <andreas.devel@gmail.com>
2011-06-21mx31pdk: Add DHCP commandFabio Estevam
2011-06-21imx31_phycore: Fix build by using new relocation schemeFabio Estevam
2011-06-21mx1ads: Fix build by using new relocation schemeFabio Estevam
2011-06-21MX31: QONG: drop config.mkStefano Babic
Remove obsolete config.mk from QONG board. Signed-off-by: Stefano Babic <sbabic@denx.de>
2011-06-21omap730p2: fix build breaksAneesh V
Provide SDRAM base address and use SRAM for initial stack Signed-off-by: Aneesh V <aneesh@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-06-21omap2420h4: fix build breaksAneesh V
2011-06-21omap1610inn: fix build breaksAneesh V
