path: root/include/configs
2003-05-23Patch by Denis Peter, 19 Mai 2003:wdenk
add support for the MIP405-3 board
2003-05-23DHCP support added.stroese
2003-05-23PMC405 board added.stroese
2003-05-23Code cleanup.stroese
2003-05-23CPCI405AB (special version of esd CPCI405) board added.stroese
2003-05-23BUBINGA405EP board added (IBM PPC405EP Eval Board).stroese
2003-05-23ASH405 board added (PPC405EP based).stroese
2003-05-22* Patch by Dave Ellis, 22 May 2003:LABEL_2003_05_23_0055wdenk
Fix problem with only partially cleared .bss segment * Patch by Rune Torgersen, 12 May 2003: get PCI to work on a MPC8266ADS board; incorporate change to cpu/mpc8260/pci.c to enable overrides of PCI memory parameters
2003-05-21Add support for arbitrary bitmaps for TRAB's VFD command;LABEL_2003_05_22_2230wdenk
allow to pass boot bitmap addresses in environment variables; allow for zero boot delay
2003-05-20* Patch by David Updegraff, 22 Apr 2003:LABEL_2003_05_20_1630wdenk
update for CrayL1 board * Patch by Pantelis Antoniou, 21 Apr 2003: add boot support for ARTOS (a proprietary OS) * Patch by Steven Scholz, 11 Apr 2003: Add support for RTC DS1338 * Patch by Rod Boyce, 24 Jan 2003: Fix counting of extended partitions in diskboot command
2003-05-20Fix SDRAM timing on Purple boardwdenk
2003-05-18Add support for CompactFlash on ATC boardwdenk
(includes support for Intel 82365 and compatible PC Card controllers, and Yenta-compatible PCI-to-CardBus controllers)
2003-05-12Patch by Mathijs Haarman, 08 May 2003:LABEL_2003_05_12_2355wdenk
Add lan91c96 driver (tested on Lubbock and custom PXA250 board only)
2003-05-12Fix SDRAM initializationwdenk
2003-05-05Fix ATC board configuration and flash driverwdenk
2003-05-03* Add support for Promess ATC boardLABEL_2003_05_03_1700wdenk
* Patch by Keith Outwater, 28 Apr 2003: - Miscellaneous corrections and additions to GEN860T board specific code. - Added GEN860_SC variant to GEN860T. - Miscellaneous corrections to GEN860T documentation. - Correct duplicate entry in U-Boot CREDITS file. - Add GEN860T_SC entry in MAINTAINERS file. - Update CREDITS file with GEN860T_SC info. * Update Smiths Aerospace addresses in MAINTAINERS file * Fix error handling in hush's version of "run" command
2003-04-27* LWMON extensions:wdenk
- Splashscreen support - modem support - sysmon support - temperature dependend enabling of LCD * Allow booting from old "PPCBoot" disk partitions * Add support for TQM8255 Board / MPC8255 CPU
2003-04-20Make compile cleanwdenk
2003-04-20Compile fixeswdenk
2003-04-20* Make sure Block Lock Bits get cleared in R360MPI flash driverwdenk
* MPC823 LCD driver: Fill color map backwards, to allow for steady display when Linux takes over * Patch by Erwin Rol, 27 Feb 2003: Add support for RTEMS (this time for real). * Add support for "bmp info" and "bmp display" commands to load bitmap images; this can be used (for example in a "preboot" command) to display a splash screen very quickly after poweron. * Add support for 133 MHz clock on INCA-IP board
2003-04-12* Patch by Lutz Dennig, 10 Apr 2003:LABEL_2003_04_15_1900wdenk
Update for R360MPI board * Add new meaning to "autostart" environment variable: If set to "no", a standalone image passed to the "bootm" command will be copied to the load address (and eventually uncompressed), but NOT be started. This can be used to load and uncompress arbitrary data. * Set max brightness for MN11236 displays on TRAB board
2003-04-10Add support for TQM862L moduleswdenk
2003-04-08Prepare for 0.3.0 releaseU-Boot-0_3_0wdenk
* Add support for Purple Board (MIPS64 5Kc) * Add support for MIPS64 5Kc CPUs
2003-04-05* Patch by Arun Dharankar, 4 Apr 2003:LABEL_2003_04_05_0300wdenk
Add IDMA example code (tested on 8260 only) * Add support for Purple Board (MIPS64 5Kc) * Add support for MIPS64 5Kc CPUs * Fix missing setting of "loadaddr" and "bootfile" on ARM and MIPS * Patch by Denis Peter, 04 Apr 2003: - update MIP405-4 board * Patches by Denis Peter, 03 April 2003: - fix PCI IRQs on MPL boards - fix two more un-relocated pointer problems * Fix behaviour of "run" command: - print error message iv variable does not exist - terminate processing of arguments in case of error * Patches by Peter Figuli, 10 Mar 2003 - Add support for BTUART on PXA platform - Add support for WEP EP250 (PXA) board * Fix flash problems on INCA-IP; add tool to allow bruning images to flash using a BDI2000 * Implement fix for I2C Edge Conditions problem for all boards that use the bit-banging driver (common/soft_i2c.c) * Add patches by Robert Schwebel, 31 Mar 2003: - csb226 board: bring in sync with innokom/memsetup.S - csb226 board: fix MDREFR handling - misc doc fixes / extensions - innokom board: cleanup, MDREFR fix in memsetup.S, config update - add BOOT_PROGRESS to armlinux.c
2003-04-04U-Boot version environment variable "ver" added (CONFIG_VERSION_VARIABLE).stroese
2003-03-31* Patch by Martin Winistoerfer, 23 Mar 2003wdenk
- Add port to MPC555/556 microcontrollers - Add support for cmi customer board with Intel 28F128J3A, 28F320J3A or 28F640J3A flash. * Patch by Rick Bronson, 28 Mar 2003: - fix common/cmd_nand.c
2003-03-28Patches by Dave Ellis, 18 Mar 2003 for SXNI855T board:wdenk
- fix SRAM and SDRAM memory sizing - add status LED support - add MAC address for second (SCC1) ethernet port Update default environment for TQM8260 board
2003-03-27* Add support for MIPS32 4Kc CPUswdenk
* Add support for INCA-IP Board
2003-03-26Make compile clean, fix the usual small problems.LABEL_2003_03_26_1300wdenk
2003-03-26* Patch by Rick Bronson, 16 Mar 2003:wdenk
Add support for Atmel AT91RM9200DK w/NAND * Patches by Robert Schwebel, 19 Mar 2003: - use arm-linux-gcc as default compiler for ARM - fix i2c fixup code - fix missing baudrate setting - added $loadaddr / CFG_LOAD_ADDR support to loadb - moved "ignoring trailing characters" _before_ u-boot wants to print out diagnostics messages; removes bogus characters at the end of transmission * Patch by John Zhan, 18 Mar 2003: Add support for SinoVee Microsystems SC8xx boards * Patch by Rolf Offermanns, 21 Mar 2003: ported the dnp1110 related changes from the current armboot cvs to current u-boot cvs. smc91111 does not work. problem marked in smc91111.c, grep for "FIXME". * Patch by Brian Auld, 25 Mar 2003: Add support for STM flash chips on ebony board * Add PCI support for MPC8250 Boards (PM825 module) * Patch by Stefan Roese, 25 Mar 2003:
2003-03-25*** empty log message ***LABEL_2003_03_25_1830wdenk
2003-03-25Add PCI support for MPC8250 Boards (PM825 module)wdenk
2003-03-25esd PCI405 updated.stroese
2003-03-20CPCI4052 update (support for revision 3).stroese
2003-03-14* Avoid flicker on the TRAB's VFD by synchronizing the enable withwdenk
the HSYNC/VSYNC. Requires new CPLD code (Version 101 for Rev. 100 boards, version 153 for Rev. 200 boards). * Patch by Vladimir Gurevich, 12 Mar 2003: Fix relocation problem of statically initialized string pointers in common/cmd_pci.c * Patch by Kai-Uwe Blöm, 12 Mar 2003: Cleanup & bug fixes for JFFS2 code: - the memory mangement was broken. It caused havoc on malloc by writing beyond the block boundaries. - the length calculation for files was wrong, sometimes resulting in short file reads. - data copying now optionally takes fragment version numbers into account, to avoid copying from older data. See doc/README.JFFS2 for details.
2003-03-06* Patches by David Müller, 31 Jan 2003:LABEL_2003_03_06_2255wdenk
- minimal setup for CardBus bridges - add EEPROM read/write support in the CS8900 driver - add support for the builtin I2C controller in the Samsung s3c24x0 chips - add support for MPL's VCMA9 (Samsung s3c2410 based) board * Patch by Steven Scholz, 04 Feb 2003: add support for RTC DS1307 * Patch by Reinhard Meyer, 5 Feb 2003: fix PLPRCR/SCCR init sequence on 8xx to allow for changes of EBDF by software * Patch by Vladimir Gurevich, 07 Feb 2003: "API-compatibility patch" for 4xx I2C driver
2003-03-06* Patches by Robert Schwebel, 06 Mar 2003:wdenk
- fix bug in BOOTP code (must use NetCopyIP) - update of CSB226 port - clear BSS segment on XScale - added support for i2c_init_board() function - update to the Innokom plattform * Extend support for redundand environments for configurations where environment size < sector size
2003-03-06* Patch by Rune Torgersen, 13 Feb 2003:LABEL_2003_03_06_0200wdenk
Add support for Motorola MPC8266ADS board * Patch by Kyle Harris, 19 Feb 2003: patches for the Intel lubbock board: memsetup.S - general cleanup (based on Robert's csb226 code) flash.c - overhaul, actually works now lubbock.c - fix init funcs to return proper value * Patch by Kenneth Johansson, 26 Feb 2003: - Fixed off by one in RFTA calculation. - No need to abort when LDF is lower than we can program it's only minimum timing so clamp it to what we can do. - Takes function pointer to function for reading the spd_nvram. Usefull for faking data or hardcode a module without the nvram. - fix other user for above change - fix some comments. * Patches by Brian Waite, 26 Feb 2003: - fix port for evb64260 board - fix PCI for evb64260 board - fix PCI scan * Patch by Reinhard Meyer, 1 Mar 2003: Add support for EMK TOP860 Module * Patch by Yuli Barcohen, 02 Mar 2003: Add SPD EEPROM support for MPC8260ADS board
2003-03-06* Patch by Robert Schwebel, 21 Jan 2003:LABEL_2003_03_06_0050wdenk
- Add support for Innokom board - Don't complain if "install" fails - README cleanup (remove duplicated lines) - Update PXA header files * Add documentation for existing POST code (doc/README.POST) * Patch by Laudney Ren, 15 Jan 2003: Fix handling of redundand environment in "tools/envcrc.c" * Patch by Detlev Zundel, 28 Feb 2003: Add bedbug support for 824x systems * Add support for 16 MB flash configuration of TRAB board * Patch by Erwin Rol, 27 Feb 2003: Add support for RTEMS * Add image information to README * Fix dual PCMCIA slot support (when running with just one slot populated) * Add VFD type detection to trab board * extend drivers/cs8900.c driver to synchronize ethaddr environment variable with value in the EEPROM
2003-02-28* Add support for 16 MB flash configuration of TRAB boardLABEL_2003_02_28_0150wdenk
* Patch by Erwin Rol, 27 Feb 2003: Add support for RTEMS * Add image information to README * Fix dual PCMCIA slot support (when running with just one slot populated) * Add VFD type detection to trab board * extend drivers/cs8900.c driver to synchronize ethaddr environment variable with value in the EEPROM * Start adding MIPS support files
2003-02-18CPCIISER4 configuration updated.stroese
2003-02-14Add "pcidelay" environment variable (in ms, enabled via CONFIG_PCI_BOOTDELAY).stroese
2003-01-17* Add dual ethernet support on PM826wdenk
* Add support for LXT971 PHY on PM826 * Patch by Tord Andersson, 16 Jan 2003: Fix flash sector count for TQM8xxL * Fix I2C EEPROM problem on ICU862 board (would only write the first 16 bytes out of each 32 byte block)
2003-01-13Add support for V37 boardLABEL_2003_01_14_0055wdenk
(patch by Jón Benediktsson, 11 Dec 2002)
2003-01-11* Restrict baudrate settings on LWMON to higher speedsLABEL_2003_01_11_1050wdenk
when watchdog is on * Update baudrate in bd_info when it gets changed * Add watchdog trigger points while waiting for serial port (so far only 8xx -- needed on LWMON with 100ms watchdog) * Improve command line tool to access the U-Boot's environment (figuration of the utility, using a config file)
2002-12-28Adjust LWMON environment to current requirementsLABEL_2002_12_28_1700wdenk
2002-12-20* Switch LWMON board default config from FRAM to EEPROM;LABEL_2002_12_21_0040wdenk
in POST, EEPROM shows up on 8 addresses
2002-12-17* Use 1-byte-read instead of -write for iprobe() functionwdenk
Add i2c commands to PM826 config * extend I2C POST code: check for list on known addresses
2002-12-08* Improve log buffer code; use "loglevel" to decide which messageswdenk
to log on the console, too (like in Linux); get rid of "logstart"
