path: root/include/configs
2014-01-13Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2014-01-13ARM: pxa: Fix OneNAND window access on VPAC270Marek Vasut
Access the OneNAND 1KiB window on the VPAC270 as an SRAM instead of accessing it as a burst-RAM. This fixes a problem where the board failed to reboot sometimes as the CPU couldn't start executing from the OneNAND 1KiB window. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Tom Rini <trini@ti.com>
2014-01-13usb: exynos5: arndale: Add network supportInderpal Singh
Arndale board has AX88760, which is USB 2.0 Hub & USB 2.0 Ethernet Combo controller, connected to HSIC Phy of USB host controller via USB3503 hub. This patch uses board specific board_usb_init function to perform reset sequence for USB3503 hub and enables the relevant config options for network to work. Signed-off-by: Inderpal Singh <inderpal.singh@linaro.org> Signed-off-by: Chander Kashyap <chander.kashyap@linaro.org>
2014-01-10Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
Bringing in the MMC tree means that CONFIG_BOUNCE_BUFFER needed to be added to include/configs/exynos5-dt.h now. Conflicts: include/configs/exynos5250-dt.h Signed-off-by: Tom Rini <trini@ti.com>
2014-01-10zynq: Enable CONFIG_DEFAULT_DEVICE_TREEJagannadha Sutradharudu Teki
Enabled default dts files on respective pre-board config files this is way MAKEALL will works. and it's upto user to build specific dts by specifying at build time. $ make zynq_zc70x_config $ make --> with default dts zynq-zc702.dts or $ make DEVICE_TREE=zynq-zc702 --> Same configuration with zynq-zc706.dts Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2014-01-10zynq-common: Enable verified boot(RSA)Jagannadha Sutradharudu Teki
CONFIG_FIT_SIGNATURE - signature node support in FIT image CONFIG_RSA - RSA lib support Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2014-01-10dts: zynq: Add basic fdt supportJagannadha Sutradharudu Teki
This patch provides a basic fdt support for zynq u-boot. zynq-7000.dtsi-> initial arch dts file zynq-zed.dts -> initial zed board dts file more devices should be added in subsequent patches. u-boot build: once configuring of a board done for building dtb with zynq-zed.dts as an input zynq-uboot> make DEVICE_TREE=zynq-zed Enabled CONFIG_OF_SEPARATE for building dtb separately. There is a new binary called u-boot-dtb.bin which is a u-boot with devicetree supported. Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2014-01-10zynq-common: Define CONFIG_ENV_OVERWRITEJagannadha Sutradharudu Teki
Defined CONFIG_ENV_OVERWRITE, which allow to overwrite serial baudrate and ethaddr. Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2014-01-10zynq-common: Define flash env. partitionJagannadha Sutradharudu Teki
Last 128Kb sector of 1Mb flash is defined as u-boot environment partition. Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2014-01-10zynq-common: Change Env. Sector size to 128KbJagannadha Sutradharudu Teki
Changed Env. Sector size from 0x10000 to 128Kb Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2014-01-10zynq-common: Define default environmentJagannadha Sutradharudu Teki
Defined default env. for autoboot FIT image from respective boot devices. Default settings: fit_image=fit.itb load_addr=0x2000000 fit_size=0x800000 flash_off=0x100000 nor_flash_off=0xE2100000 Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2014-01-10zynq: Add support to find bootmodeJagannadha Sutradharudu Teki
Added support to find the bootmodes by reading slcr bootmode register. this can be helpful to autoboot the configurations w.r.t a specified bootmode. Added this functionality on board_late_init as it's not needed for normal initializtion part. Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2014-01-10zynq: Add zynq_zc770 xm012 board supportJagannadha Sutradharudu Teki
ZC770 is a complete development board based on the Xilinx Zynq-7000 All Programmable SoC, similar to ZC70x board but which has four different daughter cards, like XM010, XM011, XM012 and XM013 ZC770 XM012: - 1GB DDR3 - 64MiB Numonyx NOR flash - USB-UART Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com> Cc: Stefan Roese <sr@denx.de>
2014-01-10zynq: Add zynq_zc770 xm013 board supportJagannadha Sutradharudu Teki
ZC770 is a complete development board based on the Xilinx Zynq-7000 All Programmable SoC, similar to ZC70x board but which has four different daughter cards, like XM010, XM011, XM012 and XM013 ZC770 XM013: - 1GB DDR3 - 128 Mb Quad-SPI Flash(dual parallel) - USB-UART Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2014-01-10zynq: Add zynq_zc770 xm010 board supportJagannadha Sutradharudu Teki
ZC770 is a complete development board based on the Xilinx Zynq-7000 All Programmable SoC, similar to ZC70x board but which has four different daughter cards, like XM010, XM011, XM012 and XM013 ZC770 XM010: - 1Gb DDR3 - 1Mb SST SPI flash - 128 Mb Quad-SPI Flash - 8 Mb SST SI flash - Full size SD/MMC card cage - 10/100/1000 Ethernet - USB-UART Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2014-01-10zynq: Add zynq microzed board supportJagannadha Sutradharudu Teki
MicroZed is a low-cost development board based on the Xilinx Zynq-7000 All Programmable SoC. APSOC: - XC7Z010-1CLG400C Memory: - 1 GB of DDR3 SDRAM - 128Mb of QSPI flash(S25FL128SAGBHI200) - Micro SD card interface Communication: - 10/100/1000 Ethernet - USB 2.0 - USB-UART User I/O: - 100 User I/O (50 per connector) - Configurable as up to 48 LVDS pairs or 100 single-ended I/O Misc: - Xilinx PC4 JTAG configuration port - PS JTAG pins accessible via Pmod - 33.33 MHz oscillator - User LED and push switch For more info - http://zedboard.org/product/microzed Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2014-01-10zynq: zc70x: Add Catalyst 24WC08 EEPROM config supportJagannadha Sutradharudu Teki
Adds configurations for Catalyst 24WC08 EEPROM, which is present on the zynq boards. Enable EEPROM support for zc70x boards. Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2014-01-10zynq-common: Define exact TEXT_BASEJagannadha Sutradharudu Teki
Defined TEXT_BASE for u-boot starts from 0x4000000 w.r.t zynq memory-map. Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2014-01-10zynq: Move CONFIG_SYS_SDRAM_SIZE to pre-board configsJagannadha Sutradharudu Teki
CONFIG_SYS_SDRAM_SIZE is specific to a board hence moved to specific pre-config board files. Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2014-01-10zynq: Add zynq zed board supportJagannadha Sutradharudu Teki
Zed is a complete development board based on the Xilinx Zynq-7000 All Programmable SoC. APSOC: - XC7Z020-CLG484-1 Memory: - 512 MB DDR3 - 256 Mb Quad-SPI Flash( - Full size SD/MMC card cage Connectivity: - 10/100/1000 Ethernet - USB OTG (Device/Host/OTG) - USB-UART Expansion: - FMC (Low Pin Count) - Pmod. headers (2x6) Video/Display: - HDMI output (1080p60 + audio) - VGA connector - 128 x 32 OLED - User LEDs (9) User inputs: - Slide switches (8) - Push button switches (7) Audio: - 24-bit stereo audio CODEC - Stereo line in/out - Headphone - Microphone input Analog: - Xilinx XADC header - Supports 4 analog inputs - 2 Differential / 4 Single-ended Debug: - On-board USB JTAG programming port - ARM Debug Access Port (DAP) For more info - http://zedboard.org/product/zedboard Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2014-01-10zynq: Add zynq zc70x board supportJagannadha Sutradharudu Teki
The Zynq-7000 APSOC zc702 and zc706 enabled complte embedded processing includes ASIC and FPGA design. ZC702-: APSOC: - XC7Z020-CLG484-1 Memory: - DDR3 Component Memory 1GB - 16MB Quad SPI Flash - IIC - 1 KB EEPROM Connectivity: - Gigabit Ethernet GMII, RGMII and SGMII. - USB OTG - Host USB - IIC Bus Headers/HUB - 1 CAN with Wake on CAN - USB-UART Video/Display: - HDMI Video OUT - 8X LEDs Control & I/O: - 3 User Push Buttons - 2 User Switches - 8 User LEDs For more info on zc702 board: - http://www.xilinx.com/products/boards-and-kits/EK-Z7-ZC702-G.htm ZC706-: APSOC: - XC7Z045 FFG900 -2 AP SoC Memory: - DDR3 Component Memory 1GB (PS) - DDR3 SODIM Memory 1GB (PL) - 2X16MB Quad SPI Flash (dual parallel) - IIC - 1 KB EEPROM Connectivity: - PCIe Gen2x4 - SFP+ and SMA Pairs - GigE RGMII Ethernet (PS) - USB OTG 1 (PS) - Host USB - IIC Bus Headers/HUB (PS) - 1 CAN with Wake on CAN (PS) - USB-UART Video/Display: - HDMI 8 color RGB 4.4.4 1080P-60 OUT - HDMI IN 8 color RGB 4.4.4 Control & I/O: - 2 User Push Buttons/Dip Switch, 2 User LEDs - IIC access to GPIO - SDIO (SD Card slot) - 3 User Push Buttons, 2 User Switches, 8 User LEDs For more info on zc706 board: - http://www.xilinx.com/products/boards-and-kits/EK-Z7-ZC706-G.htm Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2014-01-10zynq-common: Rename zynq with zynq-commonJagannadha Sutradharudu Teki
zynq.h -> zynq-common.h, zynq-common is Common configuration options for all Zynq boards. zynq.h is no longer exists hense removed from boards.cfg Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2014-01-10zynq: Add GEM0, GEM1 configs supportJagannadha Sutradharudu Teki
Zynq ethernet controller support two GEM's like CONFIG_ZYNQ_GEM0 and CONFIG_ZYNQ_GEM1 enabled both so-that the respective board will define these macros based on their usage. Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2014-01-10zynq: Add UART0, UART1 configs supportJagannadha Sutradharudu Teki
Zynq uart controller support two serial ports like CONFIG_ZYNQ_SERIAL_UART0 and CONFIG_ZYNQ_SERIAL_UART1 enabled both so-that the respective board will define these macros based on their usage. Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2014-01-10zynq: Enable cache optionsJagannadha Sutradharudu Teki
- Enable cache command - Turn-off L2 cache - Turn-on D-cache Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2014-01-10zynq: Minor config cleanupJagannadha Sutradharudu Teki
Cleanups mostly on: - Add comments - Re-order configs - Remove #define CONFIG_ZYNQ_SDHCI Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2014-01-10zynq: Cleanup on memory configsJagannadha Sutradharudu Teki
Cleanup on memory configuration options: - Add comment - Re-order configs Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2014-01-10zynq: Cleanup on miscellaneous configsJagannadha Sutradharudu Teki
Cleanup on miscellaneous configurable options: - Rename SYS_PROMPT as "zynq-uboot" - Add comment - Re-order configs Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2014-01-10zynq: Enable Boot FreeBSD/vxWorksJagannadha Sutradharudu Teki
This enabled Boot FreeBSD/vxWorks from an ELF image support Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2014-01-10zynq: Enable CONFIG_FIT_VERBOSEJagannadha Sutradharudu Teki
Enabled fit_format_{error,warning}() Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2014-01-09Merge branch 'master' of git://git.denx.de/u-boot-mmcTom Rini
2014-01-09Merge branch 'master' of git://git.denx.de/u-boot-shTom Rini
2014-01-09arm64: board support of vexpress_aemv8aDavid Feng
Signed-off-by: David Feng <fenghua@phytium.com.cn> Signed-off-by: Bhupesh Sharma <bhupesh.sharma@freescale.com>
2014-01-09mmc/dwmmc: use bounce buffer for data exchange between CPU and MMC controllerAlexey Brodkin
Bounce buffer implementation takes care of proper data buffer alignemt and correct flush/invalidation of data cache at once so we no longer depend on input data variety and make sure CPU and MMC controller deal with expected data in case of enabled data cache. Bounce buffer requires to add its definition (CONFIG_BOUNCE_BUFFER) in board configuration, otherwise corresponding library won't be compiled and linker will fail to build resulting executable. Difference since v1 - fixed compile-time warning with type casting to "void *": Slight edit to remove UTF8 characters in the commit message. Acked-by: Jaehoon Chung <jh80.chung@samsung.com> Tested-by: Jaehoon Chung <jh80.chung@samsung.com> Acked-by: Pantelis Antoniou <panto@antoniou-consulting.com> ==== passing argument 2 of 'bounce_buffer_start' discards 'const' qualifier from pointer target type ==== Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com> Cc: Mischa Jonker <mjonker@synopsys.com> Cc: Alim Akhtar <alim.akhtar@samsung.com> Cc: Rajeshwari Shinde <rajeshwari.s@samsung.com> Cc: Jaehoon Chung <jh80.chung@samsung.com> Cc: Amar <amarendra.xt@samsung.com> Cc: Kyungmin Park <kyungmin.park@samsung.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Simon Glass <sjg@chromium.org> Cc: Pantelis Antoniou <panto@antoniou-consulting.com> Cc: Andy Fleming <afleming@gmail.com>
2014-01-09sh: sh4: Remove CONFIG_SH4A definition from source codeNobuhiro Iwamatsu
SH4 and SH4A are compatible. But some instructions are different from these. In Linux kernel, It is treated as a separate CPU, but for now, I think that there is no need to divide especially in the U-Boot. This removes CONFIG_SH4A definition from source code, SH4A is treated as SH4. And this fix white space. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-01-08sandbox: tpm: Add TPM emulationSimon Glass
Add a simple TPM emulator for sandbox. It only supports a small subset of TPM operations. However, these are enough to perform common tasks. Note this is an initial commit to get this working, but it could use cleaning up (for example constants instead of open-coded values). Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Simon Glass <sjg@chromium.org>
2014-01-08sandbox: block driver using host file/device as backing storeHenrik Nordström
Provide a way to use any host file or device as a block device in U-Boot. This can be used to provide filesystem access within U-Boot to an ext2 image file on the host, for example. The support is plumbed into the filesystem and partition interfaces. We don't want to print a message in the driver every time we find a missing device. Pass the information back to the caller where a message can be printed if desired. Signed-off-by: Henrik Nordström <henrik@henriknordstrom.net> Signed-off-by: Simon Glass <sjg@chromium.org> - Removed change to part.c get_device_and_partition() Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Simon Glass <sjg@chromium.org>
2014-01-08Merge branch 'u-boot-ti/master' into 'u-boot-arm/master'Albert ARIBAUD
2014-01-08ARM: omap5_uevm: Enable 8-bit eMMC accessLubomir Popov
All prerequisites are already available, so why not enable 8-bit access - it is a matter of a define in the board file only. Signed-off-by: Lubomir Popov <l-popov@ti.com> Acked-by: Pantelis Antoniou <panto@antoniou-consulting.com>
2014-01-08sh: sh2: Change CONFIG_SYS_HZ to CONFIG_SH_CMT_CLK_FREQNobuhiro Iwamatsu
CONFIG_SYS_HZ of SH2 is not used as frequency of base timer. This is the correct clock of CMT. This changes from CONFIG_SYS_HZ to CONFIG_SH_CMT_CLK_FREQ, in order to use CONFIG_SYS_HZ as clock of CMT. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
2014-01-08sh: sh4: remove CONFIG_SH4 definition from board configNobuhiro Iwamatsu
CONFIG_SH4 was already defined in arch/sh/sh4/config.mk. This removes CONFIG_SH4 from board config files of SH4. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-01-08sh: sh3: remove CONFIG_SH3 definition from board configNobuhiro Iwamatsu
CONFIG_SH3 was already defined in arch/sh/sh3/config.mk. This removes CONFIG_SH3 from board config files of SH3. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-01-08sh: sh2: remove CONFIG_SH2 definition from board configNobuhiro Iwamatsu
CONFIG_SH2 was already defined in arch/sh/sh2/config.mk. This removes CONFIG_SH2 from board config files of SH2. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-01-08sh: delete redundant CONFIG_SH definitionMasahiro Yamada
CONFIG_SH is defined in arch/sh/config.mk. It is not necessary to define it in each board header config header file. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-01-07arm: omap: cm_t35: enable gpio bank 5 clocks explicitlyNikita Kiryanov
Following commit "arm: omap3: Enable clocks for peripherals only if they are used" (f33b9bd3984fb11e1d8566a866adc5957b1e1c9d) it is now necessary to enable clocks for GPIO banks explicitly. On cm_t35, GPIO bank 5 is necessary for scf0403 lcd support. Enable GPIO bank 5 clocks. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Tom Rini <trini@ti.com> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2014-01-07ARM: twister: add missing gpio clock initJeroen Hofstee
Commit f33b9bd3984fb11e1d8566a866adc5957b1e1c9d breaks boards which do not explicitly enable the gpio clocks. This causes the twister spl to hang, since it uses the no longer enabled gpio 55. Add CONFIG_OMAP3_GPIO_2 to unbrick the board. Cc: Stefano Babic <sbabic@denx.de> Cc: Tapani Utriainen <tapani@technexion.com> Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl> Acked-by: Stefano Babic <sbabic@denx.de>
2014-01-07ARM: tam3517-common: fix nand spl bootJeroen Hofstee
commit f9095aac793aa8917ab9b915c5d449e6dc8d3d30, "mtd: nand: omap: add CONFIG_NAND_OMAP_ECCSCHEME for selection of ecc-scheme" removed CONFIG_SPL_NAND_SOFTECC from the tam3517 common config, causing the spl nand boot to fail. Add it back, so derived boards boot again. Cc: Pekon Gupta <pekon@ti.com> Cc: Scott Wood <scottwood@freescale.com> Cc: Raphael Assenat <raph@8d.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Tapani Utriainen <tapani@technexion.com> Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl> Acked-by: Stefano Babic <sbabic@denx.de>
2014-01-07TI:omap3: Drop omap3_zoom2Tom Rini
The omap3_zoom2 board has not been updated for a correct CONFIG_SYS_HZ and Tom Rix's email has long been bouncing. Signed-off-by: Tom Rini <trini@ti.com>
2014-01-07cam_enc_4xx: Set CONFIG_SYS_NAND_MAX_OOBFREE / CONFIG_SYS_NAND_MAX_ECCPOSTom Rini
With the changes to make OOBFREE/ECCPOS configurable but default to larger, we need to set these config options for the space savings they provide. Cc: Scott Wood <scottwood@freescale.com> Cc: Heiko Schocher <hs@denx.de> Signed-off-by: Tom Rini <trini@ti.com>
2014-01-06Merge branch 'master' of git://git.denx.de/u-boot-mpc85xxTom Rini
